J.P. Instruments - EDM-700-6c EGT/CHT
The EDM-700-6c Basic is a self contained, 2 1/4" panel mount, self-diagnostic system that monitors all engine temperatures plus 2-TIT's, CDT, Oil temp. and OAT! This system also has an automatic lean find mode, while the voltage is checked for problems three times per second. Consider these Advantages:
Computer Assisted Diagnostics for trouble shooting entire cockpit system. Problem codes are displayed.
Simultaneous bar graph & scanning of alphanumeric display.
Resolution, all temperatures in one degree, with selectable ºC or ºF.
Supplied with JPI's well known grounded "fast response" probes.
Variable Scaling for bar graphs.
Alphanumeric scanning display for EGT, CHT, OAT, OIL, CDT, IAT and 2 TIT''s (for twin turbo engines).
Normalize mode for accurate trend monitoring in flight.
Calculates Span highest to lowest.
Identifies cylinder with greatest span.
Voltage displayed with high / low limits.
Oil Temperature in one degree intervals with Hi / Low limits.
Lean Find Mode automatically finds the first EGT to peak.
Shock Cooling: cool rate calculated and displayed in degrees per minute.
Identifies cylinder with greatest Shock Cooling.
OAT in ºC or ºF with pilot selectable SCAN RATE.
Only "bar graph" gauge made in USA.
TSO QUALITY, FAA STC and TSO approved.
Two Year electronics warranty. $1856.72 USD
