coljones
Everything posted by coljones
  1. 747s and A380s at 1500ft aren't too bad. We get them all the time, mainly packing jetsetters from the Western Suburbs, North Shore and Blue Mountains off on annual holidays or bringing in another shipment of flowers or smartphones. Probably the worst are the choppers chasing hoons up Paramatta Rd every night. The noise from small strips isn't excessive. It might be intrusive but that is the cost of living in a society. Everyone does something intrusive, society can't avoid it.
  2. I suspect that the process becomes convoluted and people don't line up for a medical or CASA keeps demanding more tests until the applicant gives up. Not unreasonable but it distorts the stats. There probably should be column for "applications not proceeded with" along with "applications declined"
  3. According to the discussion paper the owner of the field can apply to put it on the map in which case CTAF or 126.7 would apply.
  4. You presume that the costs to RAA vary by complexity and weight of aircraft. Would you care to lay out your theory of the cost faced by RAA in registering each aircraft type?
  5. February 2017 | Civil Aviation Safety Authority Review of medical certification standards | Civil Aviation Safety Authority
  6. Do you have a superior solution for "a bad rule"
  7. It would be good if one could also pick and choose from among the parties policies. Most parties policies only have, at best, support from less than 25% of the population but are claimed as a "mandate" by the winning party. If they can't win a vote in the Senate it is pretty obvious that the majority don't support it.
  8. That's why the big birds have all that TSO stuff, ADSB, and other majik IFF and avoidance stuff. Maybe some of the area frequencies could be decoupled and/or have more boundaries. 124.55 and the other metro areas probably have too big an area. Out beyond the sandstone curtain area frequencies are very quiet. Actually 124.55 isn't too bad. YSBK is worse, especially when arrival, departures and circuits all get coupled together even though they are on different frequencies. I don't listen into the Mascot transmissions so I don't know how busy that gets.
  9. But hopefully the other plane flying along, up the creek, at 1000ft (or even 500), who doesn't know the other plane is there, will hear the calls and either divert or call and identify with intentions.
  10. check this link out Tutorial: Australian airspace regulations There are more formal tables, perhaps in the VFR Guide. It is better to contact the tower or the official documentation for an authoritative guide.
  11. There used to be a document called "Sydney Basin VFG" which was quite comprehensive. Have a look at this video which flies you through part of the Bankstown procedures and uses the standard radio calls in use at YSBK. I'm not sure who "Roger" is but it is highly unlikely to be any where near YSBK (tongue in cheek) as most calls from the tower will require a positive response so that the tower understand s that the pilot understands what they have just been told what to do.
  12. Ah Bruce, a very good instructor!! Where are you flying the Tomahawk?
  13. Go and see what they have at Concept Aviation at Bankstown - M-F and till about 3pm on Saturday. They have a full range of books, charts, nav stuff, uniforms and trinkets.
  14. Thanks, Obviously a doubling up of symbols. In the case of Helensberg and Stanwell Park there are VFR points pointing back to the red stars but the red stars are not identified in the LEGEND nor are the rocks. Perhaps a note to airservices before they are all made redundant.
  15. The asterisk s indicate "NAV AID LIMITATION (See ERSA) and in this spot ,and further south, indicates that down below the cliffs can probably can't get accurate NAV Aids. The red stars indicate a VFR APPROACH POINT, usually a black/white diamond but this is off set with a pointer back to the true approach point, the red star. Cheers
  16. Speak to Dave. He will steer you in the right direction - small steps. There is also the value Dyson-Holland RPC Book. He also has a RPC to RPL conversion book & test exams.
  17. Warnervale?
  18. https://m.facebook.com/SydFlyingClub/photos/a.418708648181958.128748.412371688815654/1406626922723454/?type=3&source=48&__tn__=E
  19. Seems like the exemptions might allow more latitude than I thought. CASA EX28/15 - Exemption — solo flight training using ultralight aeroplanes registered with the RAA at Bankstown Aerodrome
  20. Some people just can't resist a good fiddle. Having water plumbing around slows them down considerably.
  21. Try to do all of your endos, including have, in RAA first as you can bag them all at once at a low price. You will do a flight review for the RPL and it will cover all the endos you bring over rather than doing more exams and flight tests inside RPL.
  22. Are you presuming that "Nikasil" TM is the be all and end all. It might only be one among equals - a bit like the original hoover. Or a Rum and Coke. Or Cocaine
  23. An RPC with all the endos will be much cheaper than an RPL with the same endos. Conversion to PPL will still cost. You will find the test for a PPL will be harder than for either a RPL or a RPC. Any hours you do in RAA will still count towards a PPL and any experience you pick up flying RAA will always be of use. I'm not sure what the diff is between AAA and Clambacks but AAA will probably be teaching in a aerobatic type plane to an aerobatic standard whereas Clambacks will be teaching in a Piper or Cessna. All schools offer a "Trial introduction Flight (TIF)" $150 for an hour in RAA or $200 for 45mins in GA. Be aware that at Bankstown it takes a while to taxy before takeoff and this comes out of the 45 mins. It felt as though half my licence was earned taxying. Also try www.sfcaero.com.au Try to compare the components of what is being offered not just the bottom line. If you just do a TIF at a Range of places you can evaluate the schools and instructors and quizz them about their offerings, their expectations of you and your potential. You will build up hours and skills with each TIF, nothing ever gets written off.
