rodgerc
Everything posted by rodgerc
  1. Scott Burgess at YCAB does mine biennially.
  2. All of a sudden I’m questioning my long term support for self-declared medicals. 😳
  3. rodgerc
    elvis's jetstar motorhome
    Low aspect ratio wings…I bet it rolls like a dice
  4. It probably won’t kill you, but as your mother warned you, it’ll likely send you blind.
  5. If you have a crash and it’s determined you didn’t declare a (known) condition that contributed to the accident, irrespective of whether you’re flying on a Class 1, Class 2 (incl. Basic Class 2) or a Class 5 medical, you’re in strife.
  6. Well I think we still need the Australian Defence Force….
  7. Looks like a very nicely built aircraft CharlyT. 👍
  8. Photos taken inside the hangar at night….No power connected to the hangar just yet.
  9. Whilst I never pass up an opportunity to take a shot at CASA, the system worked flawlessly for me....Easier than ordering a Sunday night pizza from Uber.
  10. Move over ROTAX…..move over PEUGEOT
  11. There is no blanket requirement for TSO’d instruments in 19-XXXX amateur built RA-Aus or experimental GA to fly in controlled airspace. Here’s a reference: https://raaus.com.au/wp-content/uploads/2023/10/raap-14-can-i-fly-in-controlled-airspace.pdf
  12. It’s likely aimed at the owners of C150’s, Tomahawks and Air Tourers who have had recent exchanges with CASA medical staff.
  13. The precise wording on the RA website is: “There are currently 3232 active aircraft in the RAAus fleet.” Since registrants are invoiced annually, I’d interpret “active” to mean “currently registered”, but I’ve been wrong before today.
  14. 3,232 as of 26 January 2024
  15. They become unsecured creditors and wait in line with all the other creditors for a refund.
  16. The Oxford Reference Dictionary’s entry for “Legend”: A traditional story sometimes popularly regarded as historical but not authenticated. On that basis he likely qualifies, although I’m now going to look up “Popularly”. Move along please folks, there’s nothing to see here.
  17. JG3 is active on this forum
  18. Just reread my post and realised I used 790N instead of 700N….Despite the error, the outcome remains the same.
  19. If it were me, I’d initially keep life simple by sticking with all 22001 dimensions except the OD. Some (very) basic stuff assuming a 70kg engine and prop combo….Call it 700 Newtons for simplicity. Original mount net area 790mm^2 x 4off = 3,160mm^2. Compressive stress = 790N/3,160mm^2 = 250kPa With a 1-1/2” OD the total bearing area increases to 4,216mm^2 or 33% more. So compressive stress decreases to 790N/4,216mm^2 = 187kPa. By implication, the compressive strain on the mounts will also be decreased by about 1/3 and along the way, you’ll have increased the surface area to dissipate all that vibration (kinetic energy) heat into the aluminium mounting rails. Naturally, the back-up washers will also need to be increased in diameter. It’s pretty easy to cast urethane and there’s a bunch of videos on YouTube showing people doing it at home….Search “casting polyurethane bushings” and pour yourself a drink. If you’re still unsure of your ability (it’s easy) then pop over to 33 Holloway Dr Bayswater and talk to Melbourne Polyurethane.
  20. Would you be able to crib an extra 1/4” on the diameter of the mount? (I.e. Dimension A) If yes, then personally I’d try that by having a custom set cast in 80A durometer PUR before switching to a stiffer (higher modulus) compound….It would improve the vibration dampening characteristics of the engine mount. When comparing the dimensions of the 22001 rubber components with the Lord mounts used on a (albeit considerably heavier) Conti 0-200, it does seem to be rather a big ask.
  21. I’d be inclined to look at a larger mount rather than a stiffer compound. Simply on the basis of force/area = pressure. (Stress) For information only, the (during construction) pics below are the RANS bed-mount installation in my Raven. After ~90h flying over 18 months they are standing up very well with no noticeable compression set/sag. I suspect they are natural rubber of around 80A durometer.
  22. For what it’s worth, my AeroVee powered Waiex’s engine mounts were replaced at every annual, because after a year and 25-35h flying they were pretty well shot. I suspect they were EPDM of around Shore A, 80 hardness. Given thermoset urethane is readily available and easy to cast in a silicone mould, have you considered casting your own larger mounts from polyurethane to spread the load?
  23. I can see the threshold of an airport from my front door where hangars cost 6 times more than the one that I drive 1 hour to/from at least once a week. Happy to drive.
