skippydiesel
Members-
69
Reregistering an RAA aircraft
skippydiesel replied to Geoff_H's topic in Aircraft General Discussion
Addressing me? Yes I crashed my Zephyr on landing on a very dodgy farm strip - now about 5 years ago. I am still ashamed of the poor decisions I made and the damage caused to a truly astonishing little aircraft. The Zephyr has been put back into the air, by her new owner.π -
Regarding private landing strip
skippydiesel replied to RegularPerson's topic in AUS/NZ General Discussion
As stated, gusting wings can impact on aircraft performance close to the ground. It's part of the pilots job/training to accommodate this phenomena. Generally wind does not cause an aircraft to stall. The prudent pilot will configure & increase the aircraft approach speed, to better handle gusting conditions. In the unlikly event of a stall on approach to landing, the aircraft will still have forward speed - it would need to stall at some distance from your home to hit it AND is likly to divert from its original flight path ie away from your home π -
As stated earlier, aircraft take-off & land into wind (headwind) as this reduces the distance required and reduces the ground speed. Tailwind takeoffs/Landings can & are done - personally I would not try over 10 knots (18.5 kph). Once airborne the aircraft responds to its own airspeed (is independent of wind speed), however when close to the ground, sudden changes to wind speed & direction (gusting) can have a significant effect on aircraft performance. Commuting; While many fantasise about the potential commuting via small (fixed wing) aircraft, combining business & pleasure, the reality is its an unreliable mode of transport, that is only feasible in relativly benign weather conditions. Logistically it also has problems, in that a vehicle must be available, at at least one end of the trip (unless the pilot/pax can walk from the landing ground to work).π -
Dermot McD, Suggest you join the Rotax Owners Forum https://www.rotax-owner.com/en/forum- Your questions will be answered by very experienced people and you will have access to the latest Installation, Maintenance (Line & Heavy), Operator, Manuals.π
Me thinks you are showing your age - flight engineers not so much in demand these daysπ -
Very good! So not the C172 listed in your bio? My last aircraft had a 30 knot stall speed, I could still manage to control engine speed (5200-5500 rpm) with attitude and climb out at 1000 +ft /minute. I think most pilots are trained to adjust power/ attitude at around 500 ft (assuming no additional risk factors) Dont know your experince/training however you should know that best angle of climb (VX) creates its own risks that must be measured against best rate of climb (VY). If you are consistently operating your engine below optimum (min 5200 rpm) there is an elevated risk of premature failure. There may also be problems quickly achieving a good glide speed, in the event of engine failure, due to high initial angle of attack.π -
To the best of my understanding , you have no legal right to the airspace over your home. Nor am I aware of amy any general legal restriction to landing on your own property or that of a cooperting owner. This is not the end of the story - Most pilots do not wish to antagonise their neighbours and will if possible adjust their flight path to accommodate your concerns. It would seem that you have raised the matter with the pilot neighbour, without a mutually acceptable outcome - unfortunate for both parties. While the risk to your house & its occupants has been elevated, above pre landing activity, by your neighbour - it may not be as significantly more so than your emotive portrayal would suggest. The perception (fear) of elevated risk, by the public, from aircraft flying overhead, is greatly exaggerated. This fear has to a large extent been fueled by hysterical & inaccurate media reporting. Aircraft rarely hit buildings and almost never fall straight down (even when stalled). I don't know your house location or its surrounds, therefore what its existing risks may be eg could it be at the bottom of a steep hill, justabout where a vehicle brake failure causes it to impact your house, flood/fire prone area, surrounded by trees that may fall /drop limbs create an elevated fire risk, is its electrical/gas supply systems all in good safe condition, do molds grow on the ceiling of some rooms, etc? How do you know the aircraft is at 150 ft above your house? Most people are very bad judges of aircraft altitude. Unless you are able to substantiate the height, do not mention it as a known measurement. How frequent is this aircarft activity? 1/day/week/month - goes to the quiet enjoyment of your property and that of your neighbour. I assume your neighbour owns or has permission to land on the property, as landing on a private property, without permission, is against the law (forced/emergency landing excepted). There can be no harm, hopefully some good in you making another attempt to discuss the matter with your neighbour - try and avoid emotive arguments (children in bedrooms, assumed heights) and go for what most people would agree is the presumed right to the quiet enjoyment of your home & property. If your neighbour is unable/unwilling to compromise, I can only suggest an appeal to your local council- they may have some restrictions on aircraft landing on private land. π -
"5200 rpm is the minimum recommended" - True! Also true, that a higher rpm is likly to be easier on the engine. "The static rpm will depend on the propeller and aircraft speed" - This statement is not correct. Static means not moving (aircraft usually tied down). Static rpm is measured at WOT, has nothing to do with a conventional propeller type/make (unless one of the new fandangled E props) rather the prop blade pitch setting. "I get about 5300 rpm static but only 5200 on climb out." - Without more details, & assuming you are not using an E prop, I would guess your Climb Out attitude is too steep. Lower the nose of the aircraft to allow for more airspeed and higher engine/prop rpm. Your engine will thank you for it.π -
Interesting! Pretty comprehensive list with a couple of oddities; "Change oil filter or air filter". Why not both? "Replenishment of hydraulic fluid." Why not replacement as well? π -
What oil do you use in your Rotax 912ULS?
skippydiesel replied to ozzietriker's topic in Engines and Props
I apologies if you feel aggrieved - I understood the subject to be about the amount of oil required & the cost - "You'll likely do first change at 25 hours and the purge will use a little oil (I'd don't reuse what is collected during purge. Therefore you will need at least 9 litres first fill, 25 hours change and stock on hand for next 50 hourly." The general thrust of your statement, I agree with - need more than the 3 L approximate capacity. I used about 12L + over the first 50 hrs. Your statement about purging & the amount of oil, is not as I have experienced (now on my second Rotax 912ULS & some 1000+ hrs). As a possible new engine strategy, I offered my approach (Rotax advise at least one less oil change). I stand by my advice and intente.π -
Sorry, I disagree. Rotax have a recommended STATIC (tied down/aircraft not moving) engine speed of 5200 rpm @ WOT. As you have an In -Flight - Adjustable (IFA) prop I would suggest that you set your system (prop pitch and in cockpit selector) to Fine /Take-Off mode, and re do your test. Adjust pitch and or in cockpit selector to achieve something close to 5200 rpm @ WOT/Static. 5200 rpm Static will likly give you a Take-Off & Climb-Out engine speed of around 5800 rpm. This is the Rotax max admissible rpm, for 5 minutes and will give you best performance/safety, in this phase of operation. Ideally, when your feel safe to do so, you can change your prop to Climb mode - at WOT this should be limited, by pitch setting, to 5500 rpm (continuous). Lower rpm can be achieved (minimum 5200) by reducing throttle and or increasing attitude. Over several test runs you will determine best airspeed/climb if not already specified in POH (RAA have a comprehensive test document (pdf) that may assist you) Again when you elect to change your prop to Cruise mode - your rpm will be that which you have set the system for (Max 5500 rpm) - most will go for better economy and have a rpm in the 5000-5500 rpm range (all at WOT). As PIC you will likly not Cruise very much at WOT, choosing a lower more economical engine power setting, however engine speeds should stay within the 5000-5550 rpm range. To optimise your prop settings for your airframe, record INFLIGHT Mode, Engine Speed, Air Speed, Altitude (or density altitude) & fuel flow (if no fuel flow indicator, average fuel consumed) - make adjustments and repeat until satisfied. Aircraft load, density altitude, wind speed/direction, runway surface conditions will all impact on performance.π -
Rotax recommended oil & filter change interval is 100 hrs. I did my first new engine change at 5 hrs + filter change. Second @ 25 hrs oil only. Third @ 50 hrs + filter. From then on oil only at 50 hr intervals - filter @ 100 hr. The"PURGE" has little or nothing to do with oil change intervals per say - its to remove air from the system. Should only need to be done for a new engine (never run) & removal/replacement of oil hoses. The very small amount of oil, that is collected during this process, can be returned to the engine.π The standard refill is 3 L, however it would be wise to have at least another litre on hand, incase your system takes more or you spill some. You will need a little extra (probably 100-200ml) for topping up / 50 hrs. Total 4 L (MINIMUM) . $21/L is not a bad price. Last carton I purchased was about $20/L delivered. You will do a lot of research to get a few $ lower. I split the cost/carton with another Rotax user. Be Warned! There was a Vic supplier offering for about $16/L - then jacking the delivery cost so high, ended up being one of the most expensive.π -
It is highly likly that the maximum static rpm (fine pitch) should be 5200 rpm. Your taxi test at WOT / 3800 rpm / course (maximum) pitch , serves no useful, purpose and is likely to be placing excessive stress on the engine/gearbox. At flight cruise speed /course pitch, I would anticipate that your engine would be delivering 5000-5500 rpm.π -
To the east of my (limited) knowledge; Existing rules- Only factory built aircraft (subject to one form of certification or another) can be used for hire/reward. As such. the owner/operator can not legally make any modifications to the aircraft without manufactures/factory authorisation. Some factories are more flexible on this matter than others. Owners wishing to investigate changes to their aircraft, should contact the factory seeking approval to do so.π -
I also stand to be corrected ; As stated earlier - An owner can not do own maintenance ,on an aircraft that is to be used for hire or reward . As I understand it this includes factory (Reg 24, etc) built aircraft. Sorry don't seem to be able to remove the undeling function.π -
Morgan aeroworks cheetah sierra 100
skippydiesel replied to Motobellini1098's topic in Aircraft General Discussion
You or your W&B person can set whatever datum point you choose. Common locations are spinner tip (unreliable as spinner can be changed) leading edge of wing. π -
An owner can not do own own maintenance ,on an aircraft that is to be used for hire or reward (that includes instructing) - The only exception being, if you built the aircraft, then you can be instructed in it and do the maintenance.π -
Germany to Oz by Mooney β’ 4 part trip vid
skippydiesel replied to Garfly's topic in Trips/Events/Seats
Anyone care to respond to my questions??π -
Typical bureaucratic contradiction - goes to interpretation by inspector. π -
Eprops on Rotax 912 fitting tool
skippydiesel replied to Blueadventures's topic in Engines and Props
I use "Crow Foot" adapters: π -
Hard to judge. He was in cruise, 25/hr @ 11000 ft, I think he said. No indicated/true airspeed given. No climb fuel consumption given. To make a useful comparison, the fuel consumption for a the whole trip needs to be used. If it hold true to conventional wisdom, it wont come into its efficiency own, until it gets up into the high teens mid twenties. Then you have to go down the O2 or pressurisation track $$$$$$$$$$$$$$$$$$$$π
Hope you only had very low pressure in the tyres.300 kg +/-) wont get the trailer springs to soften the ride.π
Transponder ADSB
skippydiesel replied to skippydiesel's topic in Instruments, Radios and Electronics
SkyView 2 . I have been annoyed at the strange ticking noise that emanates from the SK2 - apparently others have also found this problem. I had my SK2 "stuck" on the perspex/canopy, on the passenger side, just aft of the instrument panel. Turning my head will pick up or loose the tick. Need to move head to maintain visual scan, so tick comes & goes. Putting my open hand up against the SK2 will blank the tick. A sheet if aluminium foil has some damping effect - but difficult to keep in a position that does not interfere with SK2 performance. Tried a ferrite spike suppressor, left by the Telecom man, years ago - seems to work ??? May need to try diffrent locations on headset lead. Relocated SK2 to my side of the cockpit. Much closer to me/headset but further from headset jack. Best so far, hardly any tick at all. For SK2 tick sufferers, try placing it in diffrent positions (always with a "view" of the sky) - with luck the tick may vanishπ -
Just back from 1.2 hrs - bit lumpy a 3,000ft , below . Veeeery nice at 5500 ft above cloud. Went for the simple/cheap fix first - removed electrical plug from sensor, enlarged existing slot in rubber seal, rodded (meaning vigorously poked a bit of safety wire) the existing 1.5 mm hole in casing (previously drilled by me) Fuel pressure remained as expected, through climb/descent, various other manoeuvres including several stalls. Happy (for the moment)π
Painting is a skill. A "once in a blue moon" amature will never reach the standards of a professional painter. DO NOT DESPAIR - an amature can achivea reult that they can be proud of, at a fraction of the price a professional would demand Obsessive surface preparation and careful masking will pay off in the finished product. . Take the time to thoroughly research; the paint you want to use - for an aircraft, try to go with a high pigment density to minimise the amount of paint to get a good coverage. Consider extra elasticizer (if not an aircraft paint) to accomodate for surface movement. what you need in the way of suitable equipments (compressor/regulators ,safety stuff), including materials eg abrasives/ thinners/prepaint surface cleaners environment - spray booth/ room, temperature & humidity read & understand the paint specification sheet. Mixing ratios (& order) is very important. I like to do my ratios by weight (digital scales) others by volume (graduated cylinders) do not skimp on mixing containers, etc the "gun" need not be a top of the line - many amateurs have achieve excellent results with a carefully chosen chepo. Practise to not only get your technique right, also to fine tune the gun settings. Always do a small/short practise run just before committing, to check gun settings. Take the time to set up your preparation area - have everything you will need accessible. Do not skimp on materials. They are expensive however an avoidable "cock up" is more expensive.π
