skippydiesel
  1. I think all four are brokers ie not insurerse. In the event of a claim it is the insurers who pay out or not, in in hole or part.😈
  2. Just my opinion: Foxbat's are grossly overpriced, for what is a very ordinary aircraft. Many others with similar characteristics, can be had a much lower price, new or preloved. Once again a triumph of marketing over reality. 😈
  3. As I keep saying, I like lights, so support your decision to fit them. Unfortunatly I think your rational, for doing so, is just a wee bit suspect. "I saw him because he had his wingtip strobes on and he was against a fairly dark land/sea background at around 5:00 pm." The above statement supports my position - for lights to be effective ie seen by a pilot in the air they must be viewed in marginal light conditions and/or contrasting background - not your typical day VFR environment. Further; On the day in question when was "last light" in your part of Australia? Given the light conditions described, were you flying in day VFR? I would speculate: Most, if not all aviation authorities would not hesitate to legislate, for day VFR aircraft to have lights, if there was a sceric of evidence to show that such laws would have a significant posative impact on safety.😈
  4. The problem with stories like this is that Rgmwa already knew, in which direction to look for the Mooney, THANKS TO GOOD RADIO COMMUNICATION. His assertion "I saw his strobes much more quickly than I would have been able to see him otherwise at that time of day" is completely undermined by his good listening & the Mooney pilots transmissions. How can anyone possibly know that it would have taken a longer/shorter time, to see the other aircraft without empirical study. We would all like lights to be a wonderful safety feature but it just ain't so for day VFR.😈
  5. Media is reporting, officials speculating a bid strike causing undercarriage to fail???? Taking advice from the Russian????😈
  6. " I notice a NO FLOW of fuel in the fuel filters" I do not understand this statement. Is there an electronic fuel pressure sensor/read out, involved or is this some sort of sight glass with a fuel flow indicator in it?😈
  7. The point is, that there is little evidence that lights "....makes you more visible...." in day VFR conditions, when being viewed by a pilot in the air. Sure people on the ground can see you "....in the circuit", how does this significantly improve airborne safety? I agree " they are a nice-to-have".😈
  8. I am not against aircraft light, I like them for their aesthetic show off appeal. Safety is always a hot topic, almost all will have their opinion and personal standard (comfort zone). In the real world we all make judgements constantly/risk assessment - can I get through the lights, when they have turned orange, start across the pedestrian crossing as the red light goes on, walk outside in a thunderstorm, ride a bicycle on a public road, etc. etc , ad infinitum. My point is, at what stage do you say this is not a cost effective enhancement?? Onetrack will install his lights to get that last drop of perceived safety - great. Me - One day, if I am feeling a little richer than today (after Christmas) I may install lights for the shear fun/bravado of them - they do look good. Fun aside , my transceiver & transponder(s) confer real safety benefits, not just for me,t all other aircraft in my vicinity. Forget the pretty lights - All aircraft should have a transponder with a listening channel capacity All aircraft, operating in congested airspace, should have a functioning transponder. Preferably an ADSB IN/OUT bluetoothed to something like Oz Runways 😈
  9. More power to you! Just don't get too peeved when you see an identical fitting at,say, 1/2 the price from an automotive supplier. The example I gave of AN fuel line fittings is something you can inspect yourself - unless certified aircraft, why pay for a piece of paper that in no way improves the quality of the product, its efficiency, durability or safety in use. Other "things" may have standards that you can research eg oil /coolant/fuel hose - I guess if you feel it's necessary to go the extra certified aviation paper mile you will do so and if it somehow makes you feel more confidence in your work - great!😈
  10. "............I am guessing that it didnt come with release paperwork either..." Important if you are building/maintaining a certified aircraft - otherwise just more costly fire lighting material. I have purchased "stuff" from automotive performance supplier, at a much lower price, than an identical looking product, from an aviation supplier (with documentation) at higher cost. Example AN fuel fittings from: https://automotivesuperstore.com.au/aeroflow?srsltid=AfmBOoqy1ftIqkGp6QZrWnhDnTNelL8m1Jj5vjy8SUTp1DaI39HtiVXK 😈
  11. Disagree all you like - Aircraft lights show up very well against a contrasting background. Most often this will be when viewed from the ground, leading supporter to point out how well they catch the eye. In normal VFR conditions it has been demonstrated time & time again, they have little/no effect when viewed from the air (by pilot) Ground based vehicles/hazard warning lights, are almost always viewed against a background. The studies that have been done on this topic, relate to GA /certified aircraft. Some of the experimental LED systems deliver much higher lumens (?) than the certified equivalents however this is not going to significantly change the research, which is about the human eyes lack of ability to see airborne objects, from an aircraft. Supporters will wax lyrical about lights delivering enhanced visibility at dawn/dusk, mist, etc - all non VFR environments. I like lights and wished they were a more effective system for enhancing visibility BUT a wish isn't a fact.
  12. Cant speak for VH/GA however as RA is still strictly VFR the answer is - No lights of any description/function are not required. As for IBobs inference that lights will somehow assist in See & Avoid, the short answer is also an enfactic No. In air to air (pilot looking out) lights have been found to be completely ineffective, except when viewed against a contrasting background eg dark cloud. Having said the above, I do like lights, for their esthetic/look at at me, appeal.😈
  13. Sling 4 seats should be compared with GA 4 seat aircraft, not RAA 2 seat. Do your homework: a base specification A factory built ATEC Faeta 912 ULS, T tail, Max TO 600 kg, Empty weight 300 kg (nominal), 2x50L wing tanks, would set you back well under $200,000 Au, about 6-9 months ago (no longer agent, so a bit of a guess) I would expect the kit to be significantly less. Au Dollar plummeted since then. Nothing wrong with Sling aircraft, however they do have an excellent marketing department. In many ways the aircraft version of a Harley, 90 % advertising. The Faeta using same engine, (very similar in appearance) cruises 15 Kn faster, Stalls 11 Kn slower and has a higher "payload"
  14. The word aspirational comes to mind. I believe this to be a marketing term, meaning BS😈
  15. Hmm! Thats two civilian airliners, in recent times. They must be immensely proud of their military capabilities😈
  16. My T tail Zephyr had a relativly small (to my eye) horizontal stabiliser (with elevator) and a large rudder. Aesthetically I didnt much like the concept but grew to appreciate it. Great rudder and elevator authority, right down & through the stall - couldn't ask for better. X wind landings/TO handled with ease. Aside from aesthetics, why do most gliders and a few small powered aircraft have aT tail, while most do not?
  17. ATEC are supposed to have made one, special order, tailwheel variant of the Faeta (original T tail). Last I heard, a few years back, it was for sale in Greece. ATEC were very disappointed in the ground handling characteristics of the aircraft & are said to have vowed never to build another. No expert; I have been told that a tail wheel varent, of the same nose wheel aircraft, may have a small cruise speed advantage, for a significant ground handling penalty. Further; A well faired fixed undercarriage, will usually come close to the same cruise speed, as an equivalent retractable, without the weight and complexity penalty of the latter.
  18. True! Unfortunatly all too often at, even below, circuit height. ERSA sais not below 2500 ft, the most pedantic overfly at 2500 ft - so aircraft inbound to, The Oaks/Camden, at same altitude - not good!
  19. Like you, I overfly prior to landing however I am usually well over the 500 ft minimum above circuit height - more in line with 1000 ft. Reason; not all pilots are so disciplined to be at circuit height +/-
  20. Of course. If transmit &/or receive failed and you intended to land at a CTAF, I think an overfly, well above circuit height, to visually assess aircraft activity & circuit direction may have been the prudent choice, rather than a join at circuit height, to what may be the up/down wind leg. There are several possible/legitimate circuit joining strategies at The Oaks, the most common is to join X wind from "the dead side" which is over The Oaks town itself.😈
  21. The wind on the ground was only intermittently moving the two windsox's. There was an established circuit pattern direction, 18 . Subject to making sure there was no possibility of conflict, 36 could have been used. There were reports of turbulence aloft (?ft) . There were 3 Jabs, from The Oaks, aloft at the time. One some distance away (not in circuit but in CTAF). One landing on 18, at about the time of the accident. The accident Jab which had done a "go round" on 18
  22. For people looking for 17mm coolant hose alternative to RoTax; I have no experince with Mackay however they have a good reputation. Catalogue Section 3 Pages 42-44 https://www.westernfilters.net.au/content/pdfs/mackay_HosePics_2014.pdf?srsltid=AfmBOopBWYE-XWZDeYC4lUVzsbvP9OrGpbFbRoOdLBcNEMsFavPgQKfc Most are pre formed, so you will have to match/cut where necessary (PN CH4195 seems to be the only straight). FYI Some 16mm ID may fit . Gates PN 19489, 19488, 19497, 19498, 19545 may also fit. All pre-formed with 16mm (0.66") ID, Meet SAE 20R3 Type EC Class D1&D2, -40C to +135C NOTE: Make sure that any hose you intend to purchase meets/exceeds Rotax specifications
  23. Not that it's going to change anything ; The way I see it, our (Au) system of compensation favours the legal industry and deep pockets. It inherently expensive, on various levels and potentially unjust. Unlike some enlightened societies, our system of "justice" is adversarial. Compensation payment are awarded by the court, even where the "at fault party" is not contesting the claim, by the injured party. The main beneficiaries in all of this are the ambulance chasers/lawyers. More enlightened systems remove the need for an injured party to make a claim against the at fault. Instead they make a claim to an impartial committee who rule on the matter. The committee will also rule on the culpability of the at fault, where appropriate referring the criminally negligent for prosecution/court. One of the "flow on" effects of our system is the fear generated in the public, of being sued. This plays into the hands of another unproductive group, the insurance industry. Why we allow ourselves to be "milked" without complaint, by two non productive parasitic industries, is beyond me.😈
  24. I guess so. Its rumoured that the C180 was scheduled for a refurb, part of which was a brand new transponder (ADSB - Out) sitting on a desk at Shellharbour/W Gong. As for See & Avoid - Yes this is very much the party line and will likly remain so, for aircraft without ADSB - IN plus automated aircraft proximity warning. I endeavour to be a good See & Avoid pilot, aided by Comms, OzRunwys + SE2 (very recent) BUT am a skeptic, as to its efficacy, without having some sort of clue as to where tool look in the first instance.
