Blueadventures
  1. Medical standard would be first on the list and not much more.
  2. Ian Thanks for the great forum and look forward to the new version. Like Ibob and I'm sure most others will the forum posts still be viewable, if not is there a way of saving the topics especially the aircraft topics so people can retain a copy? Best regards Mike
  3. On Bush Flyers Downunder (Facelokk) (Book) they are saying performed touch and go just before incident and also have some flight aware data images posted and seems maybe an engine failure type contributing factor. Not conformed of course and posted to be somewhat helpful.
  4. Saying 3 minutes into flight after taking off. Terrible; condolences to all involved.
  5. Agree, must be right on TDC otherwise will drive piston down and direction will be relative to before or after TDC. I have passed on info to Bill.
  6. There is an LS powered motor bike in Mackay. I'll did up an image.
  7. Look at the features on the E2A-1000 at Aircraft spruce, I have that one and made a 1/2” by about 300 mm pipe rather than the flexible hose connection into the spark plug thread in head. Works a treat. I recommend the need for the valve after the gauge for available pressure so you can turn on to get slight flow of air to confirm at TDC on compression stroke. Then open for full pressure adjusted for 80 psi or maybe 87 your choice. Such worth the extra bit of money.
  8. Prince Harry has been awarded the honour as an Aviation Legend.
  9. Many have them Jabiru, Bristelle have electric flap; Svannah's have electric trim. Very common.
  10. This is its plate if any benefit to you. I did its condition report for change of ownership.
  11. Aircraft now owned and based at Turtle Park since before December 2023.
  12. I came across these images tonight. The alloy and red one is the Teenie Two Bob built and its first flight at McMaster Field west of Rockhampton (my glider back then is in the background); it was the second he built the first he made in Canada. The other if its a Teenie was at Ingham, Qld. RAA search shows Bob 19-7319 is still in current rego so must be flying somewhere.
  13. Thanks for info. I had been leaning to maybe a tightening of the turn; however was not there and should never guess. Appreciate the info. Best Regards and condolences to families and all involved.
  14. Which post reads correct, this is yesterdays; being happy with the landings? "i did 3 good landings before he called me in. i wanted to keep going". All good, just a little confused. Cheers and enjoy next solo.
  15. Looks like you got yourself a job🙂
  16. Was the instructor instructing or just along for a ride in the new aircraft? Who was left seat / PIC?
  17. How was it proved; event repeated itself and you where solo? Thanks for info.
  18. Welcome to being an Aviator; Enjoy the ride; fly safe.
  19. Mavrick and Ice Man may not get it but 'Flick Man' will shoot it down in a flash
  20. Agree; maybe should have briefed the share holders. The in action is sadly not a surprise these days or back then.
  21. Skip this link will answer your question and any others you may have. Diesel Fuel Centrifuge | Sludge & Water Separator (dolphincentrifuge.com) One I used was to clean the diesel in our onboard fuel tanks so the day tank (engine [two main at 3,000kw and two Gen sets] feed tank) fuel was suitable.
  22. And a bugger to pull apart and clean; including putting back together correctly.
  23. Golf course is only 1.1km NE of runway threshold.
