Methusala
Everything posted by Methusala
  1. Answer or not. What's the problem?
  2. Nix to the story of Ukraine operating combat aircraft. Russkies have a no fly (no take off either) zone over all of Ukraine. Poland, somewhat hopefully volunteered its airstrips. Oh-oh, this would mean that Poland had become a military adversary to Russia giving them carte blanche to attack Poland. If this happened then, Poland, being a member of NATO, the rest of NATO would then be at war with Russia. Didn't anyone in Poland see this coming before shooting their mouths off?
  3. Leasing arrangements are most likely subject to Force Mejeure clauses most likely covered by sudden changes in international conditions. I think that we are witnessing a tsunami like change in world power dynamics which will have greater effects than had the demise of the USSR. Some see this as a hangover from the triumphalist western reaction to those events. I truly don't think that the governments headed by such towering intellects as BoJo and sleepy Jo Biden have a strong handle on the effects of their proxy war on Russia. PS. I believe that all wars are bad but that not that all wars are avoidable. Don
  4. Please tell me what your reaction was to US and NATO invading Afghanistan? "Felines owned by Russians have been banned from international competitions as punishment for Moscow’s attack on Ukraine." A further, crippling blow by the west against Russia!
  5. I have read that Boeing has withdrawn support for its aircraft based in Russia. Don't know whether Airbus has shadowed this doubtful strategy. Russia has one of the most advanced aerospace technologies in the world. Also, most western airspace is now closed to Russia. If it proves essential, they can keep Boeings flying internally without Boeing's "help". Russia and China are currently flight testing the CR-929 wide bodied competitor to the trouble plagued 787. This type of pressure from the west could have the result of speeding a 3rd competitor to Boeing and Europe's Airbus. I have trouble following the logic of US and Europe forcing a war against the Russian republic which, I see, as creating many unknown and definitely unexpected adverse consequences.
  6. Once had an "instructor". Went round & round always landing nervously. Nary 1 word did he speak apart from, "Do another one!" Another instructor took notice and invited me to do circuits with him. He said land this thing twice and you can solo. 2 good landings and off I went! Hahaha. Don
  7. I have my share of poor landings in the Thruster. Trying to flare in a normal progressive sense results in an abrupt collision of mains on the ground bouncing into the air. Application of power is required to avoid stalling. My technique is to pull and maintain full aft stick just before stalling. The elevator has sufficient authority at 50kts and I approach power off except with a passenger. I can land with idle power from 300 ft turning base quite comfortably. The power off attitude is quite steep.
  8. 3rd option, I think.
  9. Maintain 50kts till you get about 100ft under you. Then, if the engine quits you have sufficient airspeed over the elevator not to stall. It's all about energy management. Best climb is about 42kts.
  10. Happenstance can make the unlikeliest of heroes. Not making less of her great achievement.
  11. 1957 I was 6 and living in Cooma East.
  12. Tumut (home airport these days) is pretty good in both directions. Not so with some ( Wambalong ?).
  13. Primary interest is catastrophic power out so making it to the best crash site. Interesting point that into wind, higher airspeed to make more distance. Another point in favor of not turning back if insufficient altitude to make it back to the strip. Who wants to land downwind off airport?
  14. Mark, does the optimum L/D correspond to best climb speed as well as best glide?
  15. Quickest way down with lowest airspeed is to spin it - recover closest to ground that you dare and then forced landing. Evacuate...!
  16. See also JG3's posts on propeller comparisons.
  17. Fact that EFI is all but universal in the auto field and has been for 20 years answers this question. The number of problems apparent with Bing and Mikuni carbs speaks volumes for the 'yes' case. Electronic ignition is also preferred vis the electro-mechanical alternative. Conservatism rightly has its place in aviation but should not blind us to better alternatives.
  18. Hey, I notice your Volt meter. Mine was a Jaycar kit that I made up years ago. Same display.
  19. This is my Thruster panel. I like white as the background, easier on the eye. The instrument lower center is a Grand Rapids Engine Information System. Not only does it replace Tacho, hour meter, 2x CHT's, 2x EGT's, coolant temp, volts, outside air temp plus an aux, it has settable parameters and a warning light should values be exceeded. Not as capable as MGL but cheaper and adequate for a 2 cyl 2-stroke. ASI front and center.
  20. Reminiscent of the Viking SF-2A Cygnet amateur built a/c. At least 2 examples built here. Extraordinary vision from cabin due to forward-swept mid-wing layout. Performs well on 60hp VW.
  21. Annoys me...this stuff! Who here has fully stripped and reassembled a 582? I have. I have flown aircraft with 2-stroke power almost exclusively (except for my 550hrs on VW). This was with Fuji Robin EC 44-PM and 582, 447 and 503. Always with pre-mix and often with fuel which has sat in the tanks since last fuelled. Never had problems with starting or detonation. This is with pump 91 RON from any convenient tankage. On the topic of 2-stroke oil and metering pump, I bought an engine that had done 350 hrs (I'm told) running on the "sacred" green slime. The pistons were heavily oiled up, particularly on the exhaust port side to the extent that the rings were jammed into the ring lands. Over oiling was my conclusion. IMHO stick with premix at the recommended 50-1 on Castrol Activ 2-t. Rotax, unlike hotted up trail bike engines are not high performance and certainly not prime-donnas.
  22. Is it best to use mobile data, requiring cellular capability, or is it simply a matter of hotspotting from android phone?
  23. I've flown Technams, both Sierra and Papa, and they are almost too easy to fly. The J-170 does take a bit of concentration from the round-out to give that satisfied glow. Does this mean that the Technam is a 'better trainer' than the Jab? Apart from the round-out, no problems with the handling of either. Don
