djpacro
Everything posted by djpacro
  1. Nesmith Cougar
  2. I use Aeroshell W15 W50 AeroShell Multigrade W 15 W 50
  3. To add: we were obviously going very fast, from a gradual circling descent overhead Moorabbin, so quite different from the standard PFL practice with a glide approach. That word "high" was wrt the high speed and being able to ensure getting on the field, rather than "high" wrt my normal approach profile. Backup plan was to restart the engine.
  4. It happened to me in the training area once. CASA FOI on board as my student. Turned the engine off, high short final.
  5. Much written about this stall accident ... I suggest Tony Kern's http://www.916-starfighter.de/darker_shades_of_blue-1.pdf
  6. Another one for you: I was a member of the ULAAA long before there was an AUF. Ultra Light Aircraft Association of Australia!
  7. To add to that, I suggest that you ring CASA and ask - they are helpful and will organise for you to get your tailwheel and nav endorsements transferred too.
  8. djpacro
    LOC-I in GA
    It is long overdue for this subject to be addressed in Australia. http://davidjpilkington.blogspot.com/2018/06/loc-i-in-australian-general-aviation.html
  9. That’s the one.
  10. I think it is the SA-III listed in this table.
  11. Nope .... somewhere in my garage I have a report assessing the cost of putting it into production (if my memory is correct). It came along after this one https://www.flightglobal.com/FlightPDFArchive/1981/1981 - 3419.PDF
  12. I think I know but just can’t recall the name ... UK some years ago?
  13. djpacro
    Stalls
    Notes on turning stalls required for training towards an RPL at http://aerobaticsaustralia.net/?p=165
  14. That's the current AIP, it will have to change when the new law comes in later this year.
  15. https://www.flightradar24.com/data/aircraft/vh-xmh#timesettings
  16. I had the smaller one previously for my Decathlon - this wider one fits the vernier mixture on my Super Decathlon.
  17. I got mine here http://www.skylines.com.au/products/93/throttle-mixture-lock
  18. yep https://www.yakuk.com/aircraft/c3603-c3605/
  19. discussed previously
  20. Read the other rule: " (5) The pilot in command must declare a situation of emergency fuel when the calculated usable fuel predicted to be available upon landing at the nearest aerodrome where a safe landing can be made is less than the fixed fuel reserve for the flight. The pilot in command must declare an emergency fuel state by broadcasting MAYDAY, MAYDAY, MAYDAY FUEL. Note The emergency fuel declaration is a distress message."
  21. I flew in one RV-6A with an empty weight of 477 kg, very strange as the load data sheet was dated many years prior to the aeroplane being built so I'd believe there would be more around with an empty weight of 477 kg.
  22. Loaded to that to that so divide by 1.5 to give the limit load factor? Who witnessed the tests, did they cover the critical load cases for that airframe?? The LAA does a very thorough job of it and their current data seems to be consistent with CASA back then https://www.lightaircraftassociation.co.uk/engineering/TADs/055 TAYLOR JT-1 MONOPLANE.pdf
  23. Regardless of what I think about the new rules (the NPRM process has finished), I try to follow rules and it won't cost me anything to call "MINIMUM FUEL" when inbound to Moorabbin (as I am normally close to reserves on an aerobatic flight, being limited by maximum aerobatic weight) as required by the new law. I can't image what unforeseen factors there may be so I will be obliged to ask the Tower about delay information. On the odd occasion when my landing is delayed it may turn out that I calculate that I'll eat into my reserve before landing and I will be required to call "MAYDAY". I probably won't be distressed as a pleasant and safe landing is almost certainly assured within the next 30 minutes. Perhaps a bit of paperwork for me to deal with afterwards but that's OK. Airservices will have paperwork too. We'll both be obliged to report it to the ATSB.
