djpacro
Everything posted by djpacro
  1. Compare the guidance from the FAA when certifying new aircraft per FAR 23, the Super Decathlon in which I teach spins and the Vixen. An inadvertent spin in a Vixen requires correct actions per its manual promptly rather than attempting a different method as one may have learnt in a Super Decathlon. If the manual states full forward yoke then don't expect halfway to be effective.
  2. All certified types must have the spin recovery method in the AFM and/or placarded. For those types not approved for intentional spinning then that correct recovery method must be initiated within one turn to ensure recovery. Interesting that most I encounter have a different spin recovery technique than types commonly used for spin training.
  3. Pilots were narrower back when the 150 was designed. Standard pilot weight for design was 77 kg for many years. They conceded a little with the bowed doors in 1967 to give extra elbow room.
  4. The 150/152 is a great trainer, including spinning and aerobatics (the last in the Aerobat of course).
  5. A sideslip is inherently spin resistant so I guess that you did something other than keep the sideslip straight just prior to the stall? The Decathlon is very docile, there is a sweet spot of airspeed, power, rate of turn and pitch etc where it will aggressively enter a spin with little warning. The Cessna 150 does it much better, trainee instructors would typically go around a couple of turns in a spin if they weren't expecting it.
  6. I hadn't landed a Pitts in over a year so my brain was a bit rusty.
  7. That is the consequence of some people using airports without paying. If you can talk to the General Manager Aviation my guess is that he'd be OK and nil fees.
  8. Per 1000 kg pro-rata
  9. Cutaway Eagle.
  10. Yep, good roll rate. 164 deg/sec actually achieved by one pilot here. A little while back a number of aerobatic pilots submitted videos of multiple rolls from which the time from inverted to inverted was measured and the maximum steady roll rate determined. All did it with full aileron at Maneuver Speed. By comparison the Super Decathlon is 90 deg/sec.
  11. Nice airplane to fly. I visited Frank in the ‘80s and he kindly spent much time showing me around the factory with a peek at his new project. I ended up working for Aviat.
  12. I witnessed an accident where an unlicensed pilot was trying to take off in an unregistered aeroplane. He destroyed one aircraft and damaged another. Got his aeroplane trucked away within a few hours. I spoke to the guy who's aeroplane was destroyed. CASA took no interest because he did not break any of their rules, if it had lifted off the ground then it would've been a different matter. Neither did the police. Just one vehicle crashing into another on private property.
  13. The next level up at a non-controlled aerodrome is a certified air/ground radio service (CA/GRS) per https://www.casa.gov.au/sites/default/files/2021-08/advisory-circular-139-d-02-guidelines-certified-air-ground-radio-services.pdf
  14. Courtesy of CASA and the great flight manual debacle. Many years ago all aircraft here required Australian-specific flight manuals and ASI's to be in kts so all American airplanes had to be converted. Around 2001 CASA reversed and required all aircraft to use the original flight manual. So, now people end up with ASIs in kts and the flight manual using mph. Airplanes which had been operating for 30 years now had to get their original flight manual - at least one aircraft manufacturer refused to respond to such requests for airplanes that old.
  15. I always consider the forces on the airplane ..... https://www.avweb.com/flight-safety/technique/turbulence-v-speeds/ Do the sums on gust loads. Manoeuvring loads and structural fatigue are adversely affected by overweight operation. So is performance but, as you say, a big engine is good. 20 kg .... 3% maybe .... almost trivial compared to those aeroplanes found to have incorrect empty weights a while back along with a gross error in crew moment arms so their CG was way further aft. Fixed by adding mass on the engine - a much bigger % increase - what effect does that have on the engine mount and forward fuselage structure?
  16. I would and I do. Class D towers wouldn't specify a speed as they don't know what my airplane is capable of.
  17. https://www.aircraftspruce.com/catalog/appages/gapseal.php Effectiveness depends on the design of the ailerons you have and the size of the gap. Some designs are not intended to have the gap sealed.
  18. I'd like to fly one https://bevhoward.com/Buecker.htm Dragging the top of the fin through water like Fred Nicole sounds like fun ... https://sbeaver.com/Bucker/index.php/anecdotes-mainmenu-69?start=5
  19. Somewhere in my filing cabinet I have a manufacturing plan for the SAH-1.
  20. Instrument screws are brass for a reason https://www.aircraftspruce.com/catalog/hapages/brassinstrscrew2.php
  21. Fleetwings, I used to visit it often. I’m pretty sure that it has been restored and flying now.
  22. Cessna 152 Aerobat simply has this note in the POH. The 7ECA Citabria with the same powerplant doesn't bother.
  23. And quite a few with VW engines, the Corby Starlet for one.
  24. An inspiration to the rest of us!
  25. The 242 is a very nice aeroplane to fly.
