spacesailor
Everything posted by spacesailor
  1. My wife does not understand torque values . Everything get the full 'death' grip turn . I have to change 'tap ' washers twice yearly . Swmbo doesn't drive but owns a vehicle. Smart ! , always has a chauffeur. spacesailor
  2. Only have 100 centimetres in my meter . spacesailor
  3. Perhaps . COULD IT be the wire to the " RCD " . ? . spacesailor
  4. Possibly The " woke " Rainbow colour . But I suspect the worst ! , Earth Brown . I have a ' trio ' of " flouro lights " all in " white wire " . spacesailor PS. : I just checked & confusion reigns supreme!. Current colours what is yellow ?
  5. I don't agree with ALL the Woke idea's . I had a colour-blind electrician wire ' panel heaters ' in my daughters bedrooms . only the heaters ended up being live , with the wires in the wrong order . now none ' colour blind 'people are getting those wires wrong , sky blue , should be high . Brown is dirt so Earth wire Grrrrr madness. spacesailor
  6. But that view is the same . Is it not ? . And I don't get the ' headache ' after too many glasses ! . spacesailor
  7. Yes but looking at my posted specs It is a two-stroke. And yes . my bro & I made a " compound-steam engine " out of ' high-pressure hydrolic piping. It worked fine under ' compressed air . but the powers to be, said we would need a " boilermakers " certificate to operate our ' home made ' flash water tube ' boiler. End of a dream . spacesailor
  8. I often wear my " Rose tinted " sunglasses ! . Optometrist told me to wear " Rose tinted glasses " . spacesailor
  9. So ! , it seems an overlooked fuel engine . not ' IC ' / CI / EV OR CA ( COMPRESSED AIR / STEAM ) . NOW ! , Boffins get your idea's working. Two stroke " wasteful " , rotary ! . Four stroke ! Does not need compression. Direct injection liquid over heating element! . ( High pressure low volume cylinder ) Exhaust into large volume low pressure, secondary cylinder ? . four pot ! , ' Two high P ' & ' two low P ' . CONFIGURATION ? . who will make their name ? . spacesailor
  10. And they " insulate very well ". Air conducts temperature very easily. ( air-mat ) Self-inflated full of insulating foam . ( self-inflated ) spacesailor
  11. Air mattress, let's the cold from the ground get to your body . Needs a woollen ( heavy ) blanket under it . Found it out in Tasmania. spacesailor
  12. My last camp ! . Tooraweenah, the morning frost was so bad I couldn't fold the chair of even roll the extension lead up ( I left it behind ). I boil water in a " copper-thermette " . Burn anything that's handy . Spacesailor
  13. I have often been advised , " to fly 10-1103 on private land " . Most agree ' it should be land owned by me . ( on paper ) to be legal . Three ' property owners ' have offered land, for flying the Hummel-Bird . spacesailor
  14. Automotive tyre stems Are larger then the hole in the rim . Not tubed , so tubeless stem is ' lubed ' & pulled through with great strength . The reason your worker can't do it .he's lost muscle strength. I use a ' claw ' hammer to ease it through. I also have the correct pulllthroug spacesailor
  15. That was very interesting! . Thank you . spacesailor
  16. T510 I'm the same " old school " with no electrics . But can manage a ' hand-held ' radio . ( & signal- lamp ( tricolor ) ) . spacesailor
  17. OOOPS Not a lot of Nitrogen engines anywhere . But they Are safe ! . Spacesailor PS. : Liquid nitrogen is easier to transport !. Even my doctors have a can of it , to freeze bits off your body .
  18. Like the " OAKS ". Overflying by Camden planes . They should charge for their airspace Incursions. spacesailor
  19. Here"s the two pics of Tori Mac"s Bede-BD5J . spacesailor
  20. I had pics of VH-POK, with tori mac & posted them on this site . spacesailor
  21. Nitrogen, could be used as a " compressed gas " the same as a ' steam engine ' . No heat ! Can use plastic rings/sealing , with only friction to get worked up about . spacesailor
  22. Yes : see " Blind pilot lands at Mascot airport " . ( in a trike ) No .: Raa has no " pilots icence " . On.y Certificate. ( CASA exceptions ) spacesailor
  23. With inflation ! , what would you get for for ten bucks . spacesailor
  24. I didn't know were it lived .only ' female drummer ' owner . Have pics somewhere. spacesailor
  25. There's one in Australia, spacesailor
