bull
Everything posted by bull
  1. And for all the plastic fantastic pilots out there that will scream ,,,OH but they are so unsafe etc,well personally when my engine fails ,[because it is not if ,it IS when be it the latest fantastic plastic or a little loehle ]i ,d much prefer a stall speed under 30 knots and a weight that if i go into trees i,m more and likely to be stuck up in the branches and have to climb down , where as plastic fantastic hitting trees at 60 kts will penetrate and smash into trunks etc or explode into flames ,,NO thanks Also if you look at historic records Yes there was a lot of outlandings, in fact you where trained to do them, and the death rate per accidents is way lower then todays parrot brigades. The records show that your chances of surviving and outlanding back then where far better then the same scenario today as the planes are heavier faster and beside jabiru,s most are low wing with a very high chance of a turnover in an outlanding and subsequent entrapment here are some examples, i know which one i,d rather be in ...lol....................
  2. YES that would be ideal with less requirements and costs and that can be balanced by some restrictions per say , like only allowed to fly a certain weight and allowable fuel on board etc . This sub group would be formed along the same lines as the AUF was formed and for the SAME reason the AUF was formed , for safe affordable aviation for recreation ,not for long distance regular transport for WORK purposes and glitter club.
  3. No and that's the problem because you are FORCED to spend the money to train in a high performance type as that is all there is to train in , and after that you are FORCED to spend lots of extra money to find an instructor who trains in drifter types if one can be found [as there is still a few around but not many ] and then FORCED to spend more money having to travel to these instructors and accommodation and associated costs ,,just because you WANT to fly an aircraft that the RAA was originally designed and formed for........................
  4. 😎Just to use the roads for an example ,,ok if you want to learn to ride a motorcycle , there are training facilities for that ,now just a motor vehicle , there is a totally different training regime for that ...Now if you want to drive a truck there is a training regime for that,,,now all these things have wheels and a steering wheel and a brake pedal /handle,,,BUT you would not like to see someone coming the other way at you in a 14 tonne truck who was trained in a honda jazz would you???
  5. If you just wanted to fly a cheap drifter or thruster ,you are now FORCED to learn to fly in a totally inappropriate aircraft for that regime of flight ,,do you think this is conductive to SAFETY ,,?? cause it is not! A jabiru trained pilot has a high chance of killing himself in a drifter or thruster through over confidence and inappropriate training for these aircraft.
  6. Ok well tell me where you can now go learn to fly a high drag open cockpit aircraft at less then $200 an hour?
  7. $ 200000 dollars worth of supposed affordable aviation in this photo ! YEH your right it is flourishing for the rich boys using rules designed for affordable aviation. The money in this photo would have 15 aircraft all flying around together enjoying the pleasure of flight ,,not like you guys just showing off your expensive toys to your mates and using them for long distance transport at high speed with cta access etc ,you know WHAT GA was for before the takeover of the AUF??
  8. Or lack of finances , which by the way is why the AUF was formed in the first place,,,,but thats all forgotten now as the ga boys have taken over........raa is fucked ,
  9. Sit back down, Now after all this modern confusion of rubber and such had Cappy seeing flashforwards of another time,when he had to take on hitler alone way behind enemy lines with his trusty 303. Now this upset the A7V ,s crew to no end as they where so sick of cappys stories and 35mm film collection ,and having to watch another rerun on the wall of the tank [with the 35mm projector that turned up from somewhere]all over again was the last straw ,,,,,,,,,,,,,,as cappy,s alter ego Benny was about to...................
  10. ok going on that i,d agree your right ,,WHICH in itself is more worrying about jab engines is it not?
  11. cappy stuck his head in the hatch and screamed Hey you lot, workplace health and safety here now stop all engines and close all valves and exit the machine you lot , and where is your high vis shirts and safety boots? and whats that oil doing on the steps and where is the fire blanket for that stove , and why is all this electric cables hanging down and held up by bits of bloody rags??Who is in charge here,and you turdo where do you think your slinking away to hmmm.... Righto wheres my report book he said as....................
  12. Hey Ken just to clear up something i,ve got some stats for you that might help explain the mistrust of jabiru engines ok have a read and then tell me there is nothing to worry about with jabs..... TL;DR. FACT: between 2009 and 2014, 1 in 10, Jabiru powered aircraft had an engine failure or malfunction, twice the rate (per hour flown) than any other manufacturer (3.21 per 10,000 hrs). ...will see if I can find anything that covers the last 6 years. https://www.atsb.gov.au/public.../2013/ar-2013-107_research/ Over the 6-year study period between 2009 and 2014, 322 engine failures or malfunctions involving light aircraft were reported to the Australian Transport Safety Bureau (ATSB) and/or Recreational Aviation Australia (RA-Aus). These reports involved single-engine piston aeroplanes up to 800 kg maximum take-off weight. Aircraft powered by Jabiru engines were involved in the most engine failures or malfunctions with 130 reported over the 6 years. This represents about one in ten aircraft powered by Jabiru engines in the study set having reported an engine failure or malfunction. Reports from Rotax powered aircraft were the next most common with 87 (one in 36), followed by aircraft with Lycoming (58 – one in 35) and Continental (28 – one in 35) engines. When factoring in the hours flown for each of these engine manufacturers, aircraft with Jabiru engines had more than double the rate of engine failure or malfunction than any other of the manufacturers in the study set with 3.21 failures per 10,000 hours flown. Unlike the engines of other engine manufacturers in this study, nearly half of the Jabiru engine failures or malfunctions related to a fractured component. Engine through-bolt failures were the most commonly reported failure mechanism in Jabiru powered aircraft with 21 through-bolt fractures reported between 2009 and 2014. Taking into account the number of aircraft registered in the study period, through-bolt failures occurred in about one in 55 Jabiru powered aircraft. Although originally designed to be replaced after 1,000 hours, 19 through-bolts failed before the 1,000 hour mark, with seven failing before 500 hours. At least four failures involved engines with upgraded 3/8 inch diameter through-bolt nuts. There were no failures reported involving the newer 7/16 inch diameter through-bolts which are used in currently manufactured engines (present in about 20 per cent of Jabiru engines). ATSB.GOV.AU Engine failures and malfunctions in light aeroplanes 2009 - 2014
  13. Yep your dead right ,i had to chase the buggers away and then the farmer come over with some star pickets and some orange safety fence stuff and helped me put a ring around the loehle until i could get my truck the next day and pick it up.
  14. 🥩 or T bone steaks or roast lamb maybe.🥩
  15. ...spot in the ditch faster then speedy gonzales and was last seen disappearing over the hill. Well the moving garbage bin thingy started turning towards onesie and...............
  16. Most cow farmers i,ve met would go out of their way to help you in this situation ,,when i landed in a "cow farm PADDOCK' the farmer offerred everything from the use of his sheds to store my aircraft and the use of his tractors and trucks etc and even made me some sandwiches and a nice cup of tea. Not one mention of damage to the "grass" or frightened cattle ,[the bloody things where more curious then frightened] might be a different matter if you landed in barley or wheat and started a fire ?,
  17. a bit like Normandy or Scotland . You didn't see this fella around it did ya onesie?said Bull he might have been the one to bring in the stuka.,Suddenly cappy screamed,,,,,,, into the ditch everyone ,,,,,,as an strange looking moving garbage bin looking thing started screaming ,,""exterminate,exterminate" whilst swinging its trunk thingy around and pointed it at turdo who.............................
  18. Yes you are right there,he was lucky that paddock was there as there is LOTS of tassie tiger country around here that does not leave you much chance . And he has done a very good job ,he is in one piece and so is the jab more or less.
  19. Taildragger would have gone over it, but i digress , my apologies for not seeing those rocks and ,yes he has done a fine job and taildraggers are not immune either,i personally had my 503 fail [fuel pump] and landed in a paddock and hit the only little ditch [not seen from the air ] and destroyed my undercarriage on my loehle a while ago [ if you look along the wing line just above it you can see the little ditch]
  20. He does have a jab on his avatar so just trying to defend the undefendable i suppose,,lol
  21. Have a good look at that paddock Ken ,no rocks no gulles just tufts of grass hmmm.........
  22. Sure is , and notice the weak nosewheel failed as it does in nearly all outlandings in a jab?
