Not a worry shu77, so long as no-one else minds.
They're a wooden-framed craft with cabled controls and a tractor engine, usually either a Continental A65 or C85. You need to be wary if a C85 is fitted as they will allow cruise speeds over max stated cruise and approaching or over the design VNE of 105 knots. Mine cruises along nicely at about 80 knots solo in calm air and climbs at around 600fpm. Performance is comparable to a Cessna 150 if two-up (ie not a rocketship) and it much prefers solo.
Fuel burn is 15~16lph and is in a slab 65L tank on the firewall. Seating is roomier than a C150 and has good legroom. Headheight is marginal if you're over 6'3" - I fit fine but you wouldn't want to be taller!
Landing is a doddle once you're used to it - set 1300~1500rpm and 1st stage flaps for base @ 60kt, then 50~55kt on final with 2nd stage of flap. Get the cowl level to flare for landing and set idle power. Sink to ground, roll out on those nice cushy 6.00x6.5 tyres. Stall is 36kt clean or 30kt with full flap.
Only thing I'd ping it on is that mine seems to not want to start or run in ground attitude with 25 litres or less in the tank, so do not run minimum fueling and always fill to the brim. I would suggest a minimum takeoff fill of 35 litres to be on the safe side. It is also sensetive in pitch, but thats not a problem if you're aware of it or used to it.
Overall I really like her, and its a shame to have to sell.
Cheers - boingk
