Hadyn Bell
Everything posted by Hadyn Bell
  1. Hi Mark, I'm keen to see the pic of the back support as well, im sure you understand my interest as you have seen my height and size!! Also would appreciate info and pics of your instruments as we need to start looking at this now for down the track and your set up sounds good. Glad to here that you got to commit some aviation on the weekend. I hope my early morning phone call gave you the inspiration to get out of bed and go fly (sorry about that).
  2. Hi All, An overdue couple of pics of the fuselage build. All going well. The small problems we are seeing along the way seem to be across the board with most other builds, so thanks to all the builders for the reassurance and sharing the love!!. The spare black goop turns up today (thanks Mark) so we are back into it full stem ahead. The couple of weeks off has given me time to re organize the shed and have a little tidy up but mostly spend some time having another read through the manual and look at photo's.
  3. I think that everyone forgets to mention some of the very simple things to the new builders. Plenty more cleco's, decent cleco pliers and extra black goop.
  4. Remember "S" for smooth !!
  5. Hi Bob, Nice to see the progress. We are still a bit behind you but catching up.... How did you go with the undercarriage / strut plate that bolts onto / into the sides of the cabin and undercarriage tunnel? Cheers Hadyn
  6. A common problem in a high salt air environment and not just aircraft. A small spray with ACF50 or corrosion block keeps the barrel lubed and working well. This will be going on my maintenance check list.
  7. Our build is going well,need to post an update. Spoke to Mark re problems we have but it seems that these problems are normal .Fus is all skinned off, into the cabin build. Just the placement of the strut / undercarriage plate when we present it, needs manipulating. Out of the black goop. Mark has a spare so will get him to send it including the S/S rivets that go into the sides of the cabin that we cant find.
    Read more
  8. Hi Gundy, Hows is your Sav S going and how many ours do you have up on it now?? Cheers Hadyn
    Read more
    1. Gundy
      Gundy
      G'day Hadyn the Sav is awesome. Only got 75 hrs on it I've been busy helping other people.I'm Just painting my mates Sav today. How's things going for you. Gundy
  9. If I order it now I should get in about 7 days unless it has a D.G cert, then it will come by sea freight and I might see it in about 6 weeks!! O no, does this mean we wont be building this weekend, what will one do....The joys of being stuck out in the Pacific ocean! Might end up using a tad of that wattle super etc spray can. Tom pointed out that before we start the cabin build forward, while we have working room, it is a good idea to cut and fit up the baggage compartment trim and as we have the rear fuselage section all skinned off this is what we might do...
  10. Hi Bob, Hope the info supplied by others helps get your problems sorted. Cheers Hadyn
  11. Hi Mark, Could you please advise what the "black goop" is as we are running out and require more of it or a suitable replacement. Cheers Hadyn
  12. Hi Bob, I had a look at our rudder last night, unfortunately I cant help with the info as we have skinned off the bottom of the rudder covering the rivets in mention. Hadyn
  13. Hi Bob, Sorry I haven't got back to you yet, completely forgot. I am off to the build shed again tonight so will pull the rudder out so its in my face and get the info off to you tomorrow. Cheers Hadyn
  14. Thanks for the photo's Mark. Impressive build bench for the wings. Our extra cleco's have turned up and now in use (not quite as many as you!). All panels and holes are lining up perfectly.
  15. Hi All, We had a enjoyable productive couple of afternoons over the weekend with the fuselage. We thought the lack of clecos would hold us up as the extras we ordered were ment to turn up on the weekly Air NZ flight on Sunday. We couldn't wait so you are not seeing cable ties holding it all together!! All parts lined up extremely well and we ended up finishing the day with the top and bottom skins in place. Haven't really read anywhere about the lack of clecos in the kit?? Paint is all ordered and will turn up on the next ship to Norfolk as we would like to get the flying surfaces painted off while we spend the time on the fuselage build.
  16. H Hi Bob, Sorry for the delay as I had the opportunity of co-piloting the the locally based PC12 down to NZ, Keri Keri, Ardmore, Keri Keri, Norfolk from Sunday to Wednesday and couldn't turn that down!! Maybe im getting practice in for our oceanic flight to Keri Keri in the Sav..... 2 hours down there in the PC12, 5.5 - 6.0 in the S ??? Anyway, I think I understand what your concern is re the rudder as we had to do a little removing of some rivets on the lower hinge brackets as it was a little confusing and was only picked up when we went to fit the hinge plate. We were one row of rivets down further than we should have been, but easily rectified. Might be a little hard to show in photo's now as we have the leading edge skins on. I will have a thorough look tonight when we have our build session. As Mark pointed out you have the XL model? so im not aware of the differences between that and the S. More than happy working with you on this. Cheers Hadyn
  17. Hi Mark, Best I load this onto your forum, not mine!! Could you please run your nose over the Sav wiring diagram attached for your opinion on the extra fuses that I think are required. We will stick to the original harness and just the extra fuses as much as I liked your harness and fuse box. If you cant read it I can email it to you. Cheers Hadyn
  18. Hi Mark, Could you please run your nose over the Sav wiring diagram attached for your opinion on the extra fuses that I think are required. We will stick to the original harness and just the extra fuses as much as I liked your harness and fuse box. If you cant read it I can email it to you. Cheers Hadyn
  19. Hi Mike, Thanks for the info, I will look into this a little more as I have not been convinced of these products in the past. One of my syndicate partners in the build of our Sav fitted an ERPS to his new 4WD ute in 2000 when he shipped it to Norfolk Island, this vehicle has just had extensive chassis and rust repairs. I have seen this vehicle deteriorate over the years when I have serviced it. Normally and my preferred method is to dismantle the vehicles and spray with inner cavity wax and coat the chassis with underseal, understanding that this is not suitable weight wise for aircraft, anyway that is vehicles and im all about aircraft at the moment. I believe with regular cleaning, hangerage and spraying with ACF-50 / Corrosion Block at least every 6-12 months we should be right... Cheers Hadyn
  20. Hi Mark, We discussed the possibility of you having a copy of the prop pitch tool made up that you showed me. Please advise if you were still going to get a couple made as we are keen to purchase one. Also myself being a bigger bloke im keen to do the flap lever mod that you showed me as it worked well. Did you keep any plans on the design?? Cheers Hadyn
  21. Hi Gundy, Are you able to supply any info and suppliers on the Vernier Throttle and splitter you fitted. Cheers Hadyn
  22. Another productive weekend on the Sav. Rudder and fin completed, finalizing the building of all the flying surfaces. Will spend the next couple sessions drilling and fitting the tips to the modified mounting strips (Thanks once again Mark). Then a bit of a clean up and we are into the fuselage. When I caught up with Mark a few weeks back he only had 2.5 hours on his new Sav and he was going on about his interest in building another one, and I thought whats wrong with this guy!..... Mark we understand now and even share a little of that passion. What and enjoyable and interesting build this is for a first build, but understanding that we have the fuselage to get our teeth into....
  23. Hi Mark, Attached is a photo (i hope) of the trim tap with the 3 holes in it. Do you recall if these holes are there for the manual trim adjustment and just need to have rivets fitted since we have the electric trim option?? Hope the head cold is sorted and you get some flying in this weekend. Beautiful day here on Norfolk, just thinking if we had the Sav finished, which way I would do my 15 minute cross around the island, to the left or to the right, round and round we go....
  24. Hi Mark, Would appreciate the info when you get it, thanks. Looks as though you have had some nice wx of late so I hope you have had a few more flights and starting to get the hours up, and no more teething problems. We spoke about the 72" prop and by the time I got in touch Tom the 68" prop was under way and we now have it here. Anyway we have plenty of strip here and we will be using the std tires supplied with the kit initially. We are only allowed to use the seal over here even though there is plenty of grass.
