Hi all,
After some advice about the placement of the oil cooler and whether it needs its own air supply (NACA duct + 3" SCAT hose to a moulded shroud)?
There's a couple of different positions from Zenith.
From the 2002 FWF instructions they show it bolted below the radiator, like so (I possibly could get away with this given the holes in the front of my cowl)
However later installations show it bolted to a welded bracket on the engine mount arm, angled and with a fitted shroud which receives air feed from a NACA duct on the side of the cowling.
I'm guessing they did it that way (in later versions) because they've mounted the water radiator vertically in order to have a narrow vertical opening in the newer cowl, leaving no room for the oil cooler under the radiator.
My cowl has not only a large intake for the water radiator but a smaller chin intake (see yellow arrow), so I'm tempted to go with the older method. Before I commit though - are there any advantages going with the newer method?
Thanks!
Cheers, Marty
