rhtrudder
Everything posted by rhtrudder
  1. Thanks nev, you might be on the right track
  2. It over revs on the fine set for glider tow on the first flight after that on the same setting it performs ok,
  3. I thought the clutch was designed to slip in case of prop strike which I turn saves the pressed crank from twisting. It's not a csu you manually set the pitch using a crank handle in the cab
  4. Inflight adjustable , Kašpar
  5. Got a mate towing gliders and noticed first tow the engine revs to high then settles down, could the clutch be slipping in the box , engine is low hours any ideas ?
  6. I fitted a knock sensor to my 914, thinking it might show up stale fuel , bolted the Mike somewhere near the rocker cover , series of lights on a display inside cab which light up when engine is high up in the rev range but I don't think it picks up any detonation or maybe the motor has never had a problem
  7. Tyres are 400 / 4. 8 ply sabre
  8. Won't stop raining, thanks for the interest
  9. Won't stop raining, thanks for the interest
  10. I wasn't really concerned with the weight of my Xair , I am having trouble getting my head around my sabre ending up with a lower MTOW than the Xair , although all the rego renewals have came back at 544 so l am guessing it has been sorted out and that fantastic looking blue sabre ,regardless of the dispute , can legally find a new home
  11. I might need more HP , but I think yours is a bit different to mine
  12. Mine was set at the higher weight when I first bought it , about 3 years ago, the point I was trying to make was the build and performance difference of both aircraft when comparing MTOW, I think my Xair at MTOW on a warm day would struggle to get off the ground
  13. As well as my sabre I also own a Xair , my lame called it a flying annex and my CFI although happy to fly in the sabre not so much in the Xair . Now I am the first to admit I am way out of my depth when it comes to understanding the rules and laws of our regulators as opposed to some of the other experts on these forums but you would think common sense would eventually prevail , the Xairs MTOW is 544kgs
  14. There has been a couple of landings with the wheels up , can't really blame the plane for that, and they come out without much damage as the wheels still run on the ground , the undercarriage all go over centre and lock into place .i had to adjust one limit switch that's about it and I have done I lot of landings,
  15. Interesting , I have clocked up 1350hrs in my sabre, never had any trouble with the undercarriage flying off our grass strip, only replaced brakes and tyres, parts direct from the factory turns up in a week, the weight restrictions I believe was being sorted out within RAA . There are other Czech built planes flying in Aust with the higher weight limits
  16. Thanks, at 43inches is there plenty of room for two bigger blokes or are you rubbing shoulders
  17. Maybe they will lift the stall speed as well otherwise what would be the point of going to 1500kgs , my other choice is to go with the rpl , but my question was more so to do with min cab width , any sugestions?
  18. If the weight increase goes ahead I have been dreaming of maybe stepping up to a rv7 , but watching lots of y tube videos the cabin looks a bit cramped, great cruising along at 170 but nothing worse than rubbing shoulders on a long trip. The plane I fly has staggered seating , works good, what would the narrowest cab width you would go for.
  19. My tyres are 8 ply , strong in the walls but not that thick in the tread, ended up using the goo and still had one go down over a few days used a bit more goo and it stopped and haven't had any more trouble , not bindie season at the moment though, wheels didn't seem to get out of balance so all good
  20. I think under SAAA rules only the original builder can only do the maintenance , if sold it needs annuals done by a lame ,
  21. Will this mean if you are the second owner of a RV7 and not the builder you can do your own maintenance which would be a huge plus
  22. Thanks for that , I will get on it as soon as my strip dries out a bit
  23. Might have to get radio nurd mate to figure it out
