This is actually a very poor video for the following reasons:
- he introduces the PARE spin recovery technique before commencing the demos, but never mentions the A (aileron) during any of the recoveries. If you enter a spin and not centre the ailerons you will likely not recover (aircraft type dependent).
- he continually refers to airspeed being the primary factor in stalling - it’s angle of attack, you can stall / spin from any airspeed.
- he introduces a non standard method of using roll to identify which rudder to apply during spin recovery. This will kill you if you try this method with inverted spinning. The only way to reliably identify the direction of rotation is yaw, best way is to sight down the nose of the aircraft. I agree that looking at the balance ball is unrealistic unless in IMC.
- he never mentions removing the opposite rudder when the spin rotation stops. Leaving full rudder in will cause some aircraft to spin in the opposite direction, some will flick into an inverted spin if you also hold the forward stick in too. The Yak 52 being a great example.
If you’re going to produce a training video on a topic it must be done correctly. In this case give the full recovery method and apply all steps through to established back in the climb. It is very difficult to retrain people who have been taught incorrect techniques, teach the correct ones from the outset.
In summary;
- it’s angle of attack not airspeed leading to stall / spins.
- Use all steps of an acceptable procedure every time, especially when instructing.
- don’t try to make up your own recovery tips without thinking them through and doing some research. (Using roll to identify which rudder to use)
On the positive side, I agree with his scenario based entry method by simulating an overshoot onto final.
