Seeing we are all looking at engines this arrived in my email from Flygas - No prices / No other details but it will not be cheap - low run specialized engines are generally not
The weight looks good but its a UAV engine
Important news from the "Made in Italy"
GAS418HA, Meeting di Primavera and Website
We welcome you in the first newsletter marked FLYGAS ® created to update you on news and events.
After some years of planning and technical project in finally born the Flygas 4 cylinder engine “GAS418HA” for UAV flight.
Entirely produced at our headquarters in Bologna this engine takes full advantage of the famous “Gas Supercharger” mechanical compressor that for the occasion turns into a two-stage compressor.
The boxer 1.800 cc is so capable of delivering 132 Kw (180 hp) with weights and dimensions enviable by the main engine manufacturers.
Some technical data:
Capacity: 1.800 cc boxer
N. cylinders: 4 opposed, (2 OHV)
Bore\race: 92\68 mm
Maximum power: 132kW (180 hp) @ 5800 rpm
Supercharger: Dual Stage Centrifugal Compressor with mechanical control
Ignition: twin spark
Cooling system: water
Lubrication system: 4 liters oil
Alternator: 14 vdc, 25amp.
Injection: Electronics (EFI)
Starter: ElectricGearbox: Gears 2.2: 1
Fuel type: Unleaded
Weight: 77 kg including engine starter, alternator, injection, pipes, air filter
Dimensions: width: 664 mm, height: 449 mm
Depth from the propeller flange: 580 mm
The engine will be officially presented at the event “Meeting di Primavera 2015”, at the Eleuteri airport of Castiglione del Lago.
