willedoo
Everything posted by willedoo
  1. Stalin only had two choices at Stalingrad - be ruthless or lose the war to the Germans. Stalingrad had to be held at all costs and if it wasn't, we'd all be speaking German now. One controversial thing was his refusal to evacuate civilians. The east bank of the Volga was heavily fortified with rear guard elements with orders to shoot any retreating Russians, so there was little risk of the troops at Stalingrad disobeying orders and retreating. But the other risk was that they would surrender to the Germans, and Stalin kept the civilians there so the troops would have something more than real estate to fight for. It worked. A lot of Stalin's ruthlessness had tactical reasoning behind it.
  2. Bruce, the biggest difference I've noticed over the years about that part of the Territory is the vast carpet of buffel grass that has taken off there. From the SA/NT border on up, it's everywhere. Rare to have dust storms now like they used to have because of the buffel.
  3. It was a live missile; it carried on past the Hercules to the far side of the base and destroyed a house, killing five occupants.
  4. It's a bad show. One of the ground crew must have been in the cockpit fiddling around.
  5. A Chad Air Force Su-25 has accidentally discharged a missile at the Adji Kossei airbase. It went through a fuel tanker and deflected past a French C-130 Hercules, eventually hitting a house and killing five civilian,s including three children. Reports allege the house belonged to a top Chad army officer. It was said the fuel tanker is French as well. It looks like the missile would have hit the Hercules if the tanker wasn't there. https://www.youtube.com/watch?v=8cedCOgrOhM
  6. I read the investigation report using google translate; it's quite disturbing reading. I really feel sorry for the passenger; it reads like he was bullied into the flight from the word go. Lucky he was not hurt too bad, mainly just powder burns to the face from not having his visor down. He was an employee of an arms company and was in charge of testing at his point of retirement. He had no aviation experience apart from a previous flight on an airliner. The flight was a surprise deal organized by his co-workers through the air base commander. The passenger didn't know about it until he got to the base about four hours before the flight. It appears the poor bloke was stressed to the max and really didn't want to be there. Recommended procedure for medicals for passengers is one at ten days before the flight, followed up by one on the day. Because the flight was a surprise flight, he only had one on the morning of the flight. On the day the whole thing was pre organized, including lunch with the base commander and the pilots. This put pressure on the medical officer and pilot to pass the whole thing through. It also put a lot of social pressure on the passenger to follow along as he was treated as a VIP guest. The passenger was in a high state of stress all morning which would have made it hard for him to concentrate on the pre-flight safety briefing. Due to his age and the fact his heart rate was getting near maximum, the doctor decided he should be subjected to no more than 3 G's. A computer failure prevented the doctor from supplying his report to the pilot and passenger, so he rang the pilot and told him to go easy on the bloke. He failed to mention the 3 G restriction. One problem was that the flight was not a dedicated passenger flight. The passenger had been slotted into a three aircraft training exercise, with a combat takeoff and simulated dogfighting. Because of the nature of the mission, the pilot had to stick to the original takeoff procedure, but had decided to skip the dogfight and just do a recon run and return to base. The passenger's watch recorded his heart rate as between 136 to 142 bpm even before takeoff, indicating a high level of stress. The pilot helped buckle the passenger into the restraint harness and then entered the front cockpit. He missed a small slack loop between keepers in the shoulder region of the harness, a very easy thing to miss. The ground crew member did very little in the way of gear checking, as there was no set checklist for it. They had made up flight suit patches with the passenger's name, company and position, leading the crew chief to assume the passenger had flight experience and knew what he was doing. In reality, the poor bugger was terrified, and didn't have a clue what to do. Problems with the gear were: slack in the restraint harness, helmet strap not done up, mask fitted asymetrically; one side tight, the other loose. Also, the G suit lower leg zip not done up on one side, and loose inguinal straps on the combat vest. I'm not familiar with this vest, but it appears to be a general vest with built in life vest and groin straps between the legs. I don't know if it also serves as a pressure jerkin or not. Before takeoff, the pilot instructed the passenger to lower his visor, but in a state of stress, he didn't lower it. After lift off in a 47 degree climb, G forces reached 3.7. After hearing loud verbalization from the passenger, the pilot backed off and nosed forward, causing negative G of 0.63. The passenger had been pushed down into the seat and now found himself riding up with the small slack in the harness. He had no experience and had not been trained to recognize anything that was happening to him. He grabbed hold of the pull handle between his legs and accidentally ejected at 650'/280kts.. The rear seat ejected as designed. Both canopy cutters worked, as did both seat's harness retractors. The failure of the front seat to eject identified two issues, none related to Martin Baker. An inherent fault in the sequence selector (designed and developed by Dassault) caused a casing rupture at the point where the pyrotechnic line to the front seat attaches. The pyrotechnic signal from the rear seat caused an internal malfunction in the selector. I would guess it caused an increase in pressure and a loose fitted screw caused the front seat's line to blow out. They've recommended fixes for both the selector and tooling and procedures for the screw problem. Another issue raised was the GoPro. It was fitted as authorized on the clear bulkhead between cockpits via a suction cup fitting. When the pyrotechnic cord cutter cut the canopy, the GoPro was dislodged and egressed with seat and passenger, increasing the risk of damage and injury. Having the visors up caused powder burns to the passenger's face. Issues continued post ejection. Wind blast tore off the unsecured helmet; lucky they were only doing 280kts.. I think it's around the 400 knot mark where eyeball rupture is an issue. At 650', seat separation would have been immediate. When the main parachute deployed, the loose groin straps of the combat vest caught on the pull handle linkage and broke the handle free of the seat. Didn't cause a big problem but has the potential to do so. The dinghy failed due to a packing problem; the activation cord for the CO2 bottle was jammed. Tests on that dinghy revealed another fault as they would deflate after something like 24 hours. The passenger landed in a smooth area off the end of the strip and didn't sustain any real injury in the landing. The pilot landed the Rafale, shut down the engines, and very carefully exited without safe pinning the seat. As it wasn't safed, they put a barrier around it for 24 hours before working on it. Main cause was put down to passenger stress and lack of experience, knowledge and preparedness. Factors contributing to that are numerous. The base commander would have most to answer for in my opinion. One recommendation by the investigators was for the Air Force to adopt a more stringent checklist for ground crew and pilots, along the lines of their Navy's procedures. Failed sequence selector.
  7. You're not wrong there Flightrite. With all that flame, you would want to make sure the fly on your nomex suit was zipped up tight. It's interesting in those photos to compare photo #1 ejecting at the rearward sloping seat angle, and #2 how quickly the rocket ignition pushes the pilot forward into an upright position.
  8. It might be a bit hard on the back, similar to the gun charges. The early Martin Baker had a single stage gun with only the main charge at the top. I think the charge varied depending on the height of the tail fin to clear. Either 50 or 60 fps, and they would get to over 20 G's. In later seats, charges went up to 80 feet per second on some aircraft, but using secondary charges to stagger the blast force rather than one big bang like the early seat. Low tail, twin boom planes like the Vampire didn't need a big charge, whereas high tails like the Mirage would need a much bigger charge, so that's where breaking the force into stages was important. The idea of the rockets is for zero/zero or low altitude ejection as the rockets take the seat up about 200 feet; enough to get a decent chute canopy. Rockets are also a much softer ride than the explosive charges of the gun. I'd guess the early firing in cockpit of the rockets on the MK.16 seats would be all about saving the pilots back. Historically, the main injuries received were spinal. The RAAF has has 80+ ejections and about 30% of those caused spinal fractures. Most were just hairline cracking from the compressive forces; usually a case of the pilot complaining of ongoing back pain. Only in one case did a broken vertebrae impact the spinal cord and luckily it didn't cause any paralysis.
  9. Looking at some of the MB test bed photos, that Rafale would have had a lot of burn damage in the rear cockpit. The newer generation of seats fry the cockpit much more than the older types, due to the rockets igniting while the seat is still partially inside the aircraft. The upside down twin gun system wouldn't appear to add to it much, due to most of the flame exiting at the top of the cockpit. But the flame from the rockets would have done a lot of damage. Photos below are of the F-35 test bed which also has a MK.16 variant, but the basic structure, gun & rocket systems are much the same as that on the Rafale seat. This photo gives a good view of the twin guns still firing inside the cockpit. This photo is of a MK.7 in an F-4 Phantom test rig. A fairly standard three stage telescopic gun and rocket pack. You can see the seat and inner tube has exited the gun's intermediate tube with flame expired and totally contained within the gun. In this photo, the inner tube has only just left the intermediate tube and there's only residual black smoke from the secondary charges exiting. It has enough extension to clear the cockpit before the rocket pack ignites, causing much less burn damage. Much harder on the back though, compared with the Rafale/Eurofighter/F-35 seat.
  10. A good outcome with this one at Quebec on Thursday. The pilot was even able to pull over and keep a lane clear.
  11. My seat experience predates the MK.16 by a few decades, so I'm not overly familiar with it. But looking at the photos, it appears to have what I'm assuming might be the auxiliary pull handle on the starboard side of the seat pan (yellow & black painted). Going into negative G with a loose harness, he would be more likely to grab the sides of the seat pan rather than the main handle between his legs. So I'm thinking that's what he's done when he fired it. There will be a lot of people in trouble over this one. It beggars belief that they put a newbie in the back seat without ensuring he was strapped up properly. And taking off with the helmet undone. Worst case scenario would have been if he only had the chin strap loosely done up which could have broken his neck. Makes one wonder if that pilot's fighter career is over. He might end up flying transports after this one. He would still have to shoulder responsibility for the unpreparedness of his backseater.
  12. Martin Baker will be looking into that one; they don't like their reputation being damaged. Faulty part perhaps. Technically, they should ground all aircraft using those seats until the fault is fixed. First thing would be to figure out if there's a batch fault or just an individual situation. There's always the possibility the sequence selector was only needed for a two seat sequenced ejection and the pilot, if need be, could still initiate his own egress after the fact.
  13. This photo is up on a few news sites. It will interest them to find out why the front seat didn't follow the rear one out.
  14. This is the MB MK.16F Rafale seat.
  15. Octave, I don't know if you ever played cricket but I recon you would have been a good batsman. They keep chucking balls at you and you keep batting them right back.
  16. Thanks for the input, FB. I know how Sputnik works; I've read it daily for many years, so not a newbie at it.
  17. Here's a passenger's view.
  18. Ah yes, the famous Vodka Burner video at Canberra. I guess if the airstrip is there, why not use all of it. This UTair An-26 doesn't have a big deal of strip left either.
  19. Good rule of thumb - never take any press as gospel. The BS is global.
  20. Latest MoD PR video for the Su-57. It's marking the start of regular Air Force pilots honing their skills on production aircraft; all previous video has been of Sukhoi test pilots flying them. One thing of note is that the regular Air Force pilots are wearing the standard equipment, ZSh-7AP helmet and KM-35M mask. Some previous videos showed test pilots using the new proposed gear, ZSh-10 helmet and KM-36 mask. By that, it might be safe to assume that these early production aircraft don't as yet have the new generation weaponry and AI systems that the ZSh-10 helmet will integrate with. Early days I guess, learn to fly them first and then move forward from there.
  21. Bruce, that would only be the case if his diet is lacking an element necessary for good brain function. There would be exceptions, but most vegans and vegetarians are very clued in on minimum nutritional and protein requirements. Because of their awareness of the protein and iron issues, most do their research and do the mathematics involved.
  22. Some photos from the early 70's. USAF F-4 Phantom barrel rolling over a Soviet Tu-95 Bear. They've been previously posted somewhere else on the site. This is the article they came from: “We Did Barrel Rolls Around Tu-95s At The Request Of The Soviets”: F-4 WSO Explains The Story Of The Phantom Upside Down Near Bear
  23. It looks to be an uncertain future for the aircraft at Bruntingthorpe airfield after being bought out by the car storage company. The car storage capacity is planned to double and a spokesman said they were winding down use of the airfield for large aircraft, but its aircraft museum would be staying. Information on the museum website says it's closed to the public and they don't have a date set for re-opening. It doesn't look good for the warbirds.
  24. This first clip is by a USN Hornet pilot commenting on the new Top Gun trailer. Interesting that all the flying scenes are real. Second clip is a behind the scenes trailer where they discuss the filming. It would be a memorable job for the actors involved in the flying scenes.
  25. These photos are slightly aviation related. The Russian MOD has released some previously unseen photos of Churchill and Roosevelt arriving and sight seeing in Sevastopol, Crimea, ahead of the 1945 Yalta summit. They are part of a bunch of declassified documents and photos released before the 75th. anniversary of the summit. Some sample photos; first photo shows what would be Roosevelt's DC-4 in the background, which would be the Presidential C-54C variant.
