red750
Moderators
Everything posted by red750
  1. The American Sportscopter Ultrasport 496 is an American helicopter that was designed and produced by American Sportscopter of Newport News, Virginia. Now out of production, when it was available the aircraft was supplied as a kit for amateur construction. The Ultrasport 496 is a two-seat trainer development of the Ultrasport 254 and, like that model, is named for its empty weight in pounds. The aircraft was designed to comply with the US Experimental - Amateur-built aircraft rules. It could also have been registered as a FAR 103 Ultralight Vehicles rules exemption trainer. It features a single main rotor, a two-seats in side-by-side configuration enclosed cockpit with optional doors, skid-type landing gear and a four-cylinder, horizontally opposed, air-cooled, two-stroke, dual-ignition 95 hp (71 kW) Hirth F-30 engine. The aircraft fuselage is made from composites. Its 23.00 ft (7.0 m) diameter two-bladed rotor employs an ATI 012 (VR-7 mod) airfoil at the blade root, transitioning to an ATI 008 (VR-7 mod) airfoil at the tip. The dual controls include cyclic controls mounted from the cockpit ceiling, but are otherwise conventional. The tail rotor is ring-mounted and the horizontal tailplane mounts end-fins for directional stability. A ballistic parachute was a factory option. The aircraft has an empty weight of 495 lb (225 kg) and a gross weight of 1,085 lb (492 kg), giving a useful load of 590 lb (268 kg). With full fuel of 16 U.S. gallons (61 L; 13 imp gal) the payload for crew and baggage is 494 lb (224 kg). The manufacturer estimated the construction time from the supplied kit as 60 hours. In June 2014 one example was registered in the United States with the Federal Aviation Administration, although a total of seven had been registered at one time.
  2. The Pilatus SB-2 Pelican was a civil utility aircraft developed by a purposely founded development bureau at the ETH Zurich on behalf of the Federal Air Authority. In November 1940 it was decided to go on with the project and build the aircraft, in February 1941 the Authority approved the development bureau to have it built at the newly formed Pilatus Aircraft company. In 1938 the Federal Air Authority was looking for an aircraft able to land at minial airfields in mountain valleys. In fact the aircraft was desired to define the criteria such possible future airfields would have to meet. So this was not to be the aircraft for such air transport itself but a mean to find possible airfield locations. The previous project of a four-seater STOL experimental aircraft under the designation Studienbüro für Spezialflugzeuge SB-1 was not implemented, so it was followed by the SB-2, which at some moments was also discussed for commercial use. Work on the SB-2 Pelican, a special “slow-flying” aircraft, commenced in the winter of 1941. Good short takeoff and landing credentials, plus steep climbing capabilities, were essential attributes of the aircraft flown in the narrow Alpine valleys at that time. The aircraft was designed to carry five people, the double controls could be reduced to one if flown with only one pilot. The configuration of the SB-2 was slightly unusual, in that it was provided with tricycle undercarriage (an uncommon feature at the time), and a wing that had a slight forward sweep. As it turned out, the type was never actually tested in its originally intended role. Only twice the aircraft was used later by the company it was sold to, Alpar, to land in a narrow mountain valley. Only the one unit was built.
  3. The Aeronca C-3 was a light plane built by the Aeronautical Corporation of America in the United States during the 1930s. Its design was derived from the Aeronca C-2. Introduced in 1931, it featured room for a passenger seated next to the pilot. Powered by a new 36 hp (27 kW) Aeronca E-113 engine, the seating configuration made flight training much easier and many Aeronca owners often took to the skies with only five hours of instruction, largely because of the C-3's predictable flying characteristics. Both the C-2 and C-3 are often described as “powered gliders” because of their gliding ability and gentle landing speeds. The C-3's distinctive razorback design was drastically altered in 1935 with the appearance of the “roundback” C-3 Master. Retaining the tubular fuselage frame construction, the C-3 Master featured a smaller vertical stabilizer and rudder with a “filled out” fuselage shape that created the new “roundback” appearance and improved the airflow over the tail. It featured an enclosed cabin with a proper door (brakes and wing light still cost extra), and a revised undercarriage dispensing with external struts in favour of a neater arrangement largely hidden in the fuselage. The 1935 C-3 Master was priced at only $1,895—just a few hundred dollars more than the primitive C-2 of 1930. The low price generated significant sales; 128 C-3 Masters were built in 1935 alone (of 430 C-3s built in all), and the 500th Aeronca aircraft also rolled off the assembly line that same year. A strengthened version of the C-3 with fabric-covered ailerons (instead of metal), designated the Aeronca 100, was built in England under license by Light Aircraft Ltd. (operating as Aeronautical Corporation of Great Britain Ltd. sometimes called Aeronco), and marketed by its associated company Aircraft Exchange & Mart. It was powered by a modified Aeronca E-113C engine built by J. A. Prestwich and Company and called the JAP J-99, and this led to the aircraft being marketed as the Aeronca-JAP. The expected sales never materialized – only 24 British-built aircraft were manufactured before production was halted. The aircraft could be fitted with floats, and those so equipped were sometimes designated PC-3, with the P standing for Pontoon. Production of the C-3 was halted in 1937 when the aircraft no longer met new U.S. government standards for airworthiness. Many of the C-3's peculiarities – a strictly external wire-braced wing with no wing struts directly connecting the wing panels with the fuselage, extensive fabric construction, single-ignition engine, and lack of an airspeed indicator – were no longer permitted. Fortunately for the legion of Aeronca owners, a “grandfather” clause in the federal regulations allowed their airplanes to continue flying, although they could no longer be manufactured. A total of 400 were built. Variants C-3 Production variant, early versions of which were built as the C-2 Collegian. C-3 Master Improved variant. Aeronca 100 British-built variant powered by an Aeronca JAP J-99 (a licence built Aeronca E-113C), 21 built. Aeronca 300 Improved British variant of the Aeronca 100, one built. Ely 700 British variant with wider fuselage and two doors, two built.
  4. Rayne Viggenite The Viggenite was initially a one-of-a-kind two-seat homebuilt aircraft designed and built by Joe Rayne. Construction of the aircraft took some 10 years and the first flight was made on August 9, 1983 with an 150-160 hp Lycoming O-320 engine. The wings were based on those of Burt Rutan's VariViggen design, but with all-metal rather than composite material construction and these were mated to a metal construction fuselage of Mr. Rayne's own design. The type was not intended for amateur construction. However, a second example (named Viggenite 13B) was built by Keith O. Lewis and this aircraft, powered by a Mazda 13B rotary engine, flew during 2005.
  5. The LH Aviation LH-10 Ellipse is a two-seat light aircraft kitplane designed by LH Aviation of France and manufactured by Morocco . It is a low-wing single-engine pusher configuration with a tandem seating arrangement, and is constructed of composite materials. The plane is marketed in a surveillance configuration as the Grand Duc (Eurasian eagle-owl). The LH-10 Ellipse is a low-wing, tandem two-seat light kit aircraft, powered by a 100 hp Rotax petrol engine in a pusher-propeller configuration. Its low weight and unusual configuration is designed to deliver a very high cruising speed with exceptional fuel economy. This high speed and a relatively high 50-knot stall speed will exclude it from the UK Microlight or United States LSA categories, so a full single-engine private pilot certificate will be the minimum certification requirement to fly it in these countries, which are not the immediate target of the manufacturer, anyway. At the 2008 Farnborough Airshow LH-Aviation said that for the future they would be looking into LSA/ELA compliant production, possibly for the United States. The airframe is constructed of composite material based on ingredients produced by DSM. The production model is powered by a Rotax 912 four-cylinder reciprocating engine. (It has been tested using the 100 hp ULS variant, other options having been tested and discarded.) The undercarriage is a tricycle design, and will be available in fixed or electrically retractable front wheel configuration. The plane's design, with propeller in the tail and a short-nosed fuselage with a forward pilot seat in glider configuration, offers a field of view of 300 degrees. Three built to date.
  6. The Rutan SkiGull is an amphibious aircraft designed by Burt Rutan. The SkiGull is a two-seat composite/titanium aircraft equipped with retractable ski undercarriage that can have wheels attached for water, snow or land operations, landing on around 400 feet of surface, but with a range to cross oceans. The engine is configured to operate with Swift Fuel, auto or boat fuel. The aircraft is being developed privately. Public disclosure of the SkiGull design was made at the EAA's Airventure convention in 2015. Details included ability to operate in ocean waves with skis or land on smooth water or grass with skis retracted, 140 knot cruise speed (optionally 177 knots turbocharged), quiet flight, water takeoff in 460 feet, high wing with 47-foot span (foldable), ground transportation without a trailer, a single 44-percent-span Fowler flap behind the main propeller, and two electric motors with forward-folding reversible propellers to simplify docking and give optional takeoff power. The SkiGull performed water tests in October 2015. It has two 12 hp electric motors for docking, but they can also fly the plane 8 miles without the piston engine. The plane can loiter for 35 hours. First flight tests in Coeur d'Alene, Idaho lasting 1.8 hours were successfully completed November 24, 2015. Tests included basic stability and control in cruise configuration and with flap down and skis extended.[9] Rutan states that his goal for the aircraft is "something that we'll look back and say, 'what this airplane is and is able to do, in terms of operating in beaches, rough water, and have the kind of capabilities that it has, is not just something a little better than the best floatplane, but something that is really truly breakthrough in nature.'" Ongoing work is addressing refinements such as stall characteristics and pitch attitude in water. Changes also include larger wheels functionally independent of the skis and no longer configured as a "tail dragger." Only one SkiGull has been built to date.
  7. The Landgraf H-2 was an American single-seat twin-rotor helicopter designed by Fred Landgraf and built by the Landgraf Helicopter Company of Los Angeles, California. Although awarded a development contract by the United States Army, it was not developed and was overtaken by more advanced designs. Fred Landgraf formed the Landgraf Helicopter Company in September 1943 to develop and manufacture the H-2. It had an enclosed structure for one pilot and an 85 hp (63 kW) radial engine driving two rotors, each rotor fitted to a short boom on each side of the fuselage. It had a fixed tricycle landing gear. The H-2 first flew on 2 November 1944 and the company was awarded a development contract by the United States Army. It was not developed or bought and the company ceased operations by the end of the 1940s, with only one prototype built.. Unlike conventional helicopters, the H-2 used a tension-rod drive system to drive the side-by-side rotors. Control of blade pitch was also unconventional, with the blade shells rotating freely about the spars, controlled by ailerons near the tips.
  8. The Lockheed C-5 Galaxy is a very large aircraft that often has mechanical issues. This is expected since it's a 50-year-old jet with many systems spread across its large airframe. Luckily, USAF mechanics are skilled at fixing it. For example, instead of flying with a broken engine, mechanics remove it completely to reduce drag. This makes the flight easier. Taking off with only three engines on a four-engine plane requires careful control to avoid losing control on the runway. Pilots must advance two engines first, then gradually the third to maintain balance.
  9. The Embraer Legacy 450/500 and Praetor 500/600 are a family of mid-size and super mid-size business jets built by Brazilian aircraft manufacturer Embraer. The aircraft family was launched with the Legacy 500 in April 2008 and were the first jets in the size category to feature a flat-floor stand-up cabin and fly-by-wire. The Legacy 500, with a range of 3,125 nautical miles [nmi] (5,790 km; 3,600 mi) and room for up to 12 passengers, first flew on November 27, 2012, and was certified on August 12, 2014. The shorter Legacy 450 first flew on December 28, 2013, was certified on August 11, 2015, has a range of 2,900 nmi (5,370 km; 3,340 mi), and can accommodate up to 9. The Praetor 500 and 600 are improvements of the Legacy 450 and 500, respectively, introduced in October 2018 offering more range. The Praetor 600 has a range of 4,018 nmi (7,440 km; 4,620 mi), while the Praetor 500 has a range of 3,340 nmi (6,190 km; 3,840 mi). Embraer introduced improved variants at the October 2018 NBAA convention, the Praetor 500 and 600, presented on display, with 3,250 nmi (6,020 km; 3,740 mi) and 3,900 nmi (7,200 km; 4,500 mi) of range; the 600 was expected to be certified in the second quarter of 2019 and the 500 in the third quarter of 2019. Both have 22 by 50 in (56 by 127 cm) taller and wider winglets. The $17 million Praetor 500 boosts the fuel capacity of the Legacy 450 from 12,108 to 13,058 lb (5,492 to 5,923 kg) to match the Legacy 500. The $21 million Praetor 600 is based on the Legacy 500 with two tanks on the fuselage belly for 2,928 lb (1,328 kg) more fuel for a 15,986 lb (7,251 kg) capacity, and more powerful 7,528 lbf (33.49 kN) HTF7500E engines. Praetor 600 flight testing began on 31 March 2018 and 300h were logged with three aircraft by October 2018, while the Praetor 500 flight tests began on 13 September 2018 with 80h accumulated. The synthetic vision system has a flight guidance system for CAT I airports approach with SBAS, allowing decision height to be reduced from 200 to 150 ft (61 to 46 m). Within US SBAS zones, the synthetic vision guidance system (SVGS) allows autopilot-flown instrument approaches down to 150 ft (46 m) height and 1,300 ft (400 m) RVR without the optional Rockwell Collins EVS and HUD. They are low wing, T-tail airplanes with cabin pressurization, powered by two rear mounted turbofans. The landing gear is fully retractable and designed to be operated on paved runways only. The glass cockpit includes four multi-function displays. The operation is made through a flight management system with autopilot, autothrottle and closed-loop control and monitoring of flight controls Fly-By-Wire. The aircraft are certified for Day, Night, VFR and IFR flights, and are approved for reduced vertical separation minima (RVSM) airspace and flight into known icing conditions, extended flight over water, Category II ILS, operations at high altitude airports up to 13800 ft and steep approach operations. Embraer offers an enhanced flight vision system constituted by the Rockwell Collins HGS-3500 Head-up display combined with the EVS-3000 Infrared camera, permitting a decision altitude necessitating visual references of 100 ft above touchdown at a projected price of $515,000. Federal Aviation Administration's draft AC 20-167A further proposes a descent below 100 ft if the required visual references can be observed using the EFVS, similar to Cat II and III approaches with limited instrument landing systems in many small airports. Number built 251 Praetor 500 : 42 (as of 26 April 2023) Praetor 600 : 71 (as of 26 April 2023) Legacy 500 : 80 (as of 26 April 2023) Legacy 450 : 58 (as of 26 April 2023) For operational history and details of variants, , click here. Specifications below are for the Praetor 600. Legacy 450 Legacy 500 Praetor 500 Praetor 600
  10. The Blériot 125 (or Bl-125) was a highly unusual French airliner of the early 1930s. Displayed at the 1930 Salon de l'Aéronautique in Paris, it featured accommodation for twelve passengers in separate twin fuselages. Between them, these pods shared a tailplane and a high wing. The centre section of wing joined the fuselage pods and also carried a nacelle that contained an engine at either end and the crew compartment in the middle. When flown the following year, it displayed very poor flight characteristics and although attempts to improve it continued on into 1933, certification could not be achieved and the sole prototype was scrapped the following year.
  11. red750
    Latécoère 28
    The Latécoère 28 was a long distance monoplane aircraft designed and produced by the French aircraft manufacturer Latécoère. First flown in 1927, it had a fixed tailwheel undercarriage and an enclosed cockpit for its crew of two. When configured for airline use, the Latécoère 28 could accommodate up to eight seated passengers. It was produced in both land and floatplane configurations, being marketed towards the civilian market both as a mail plane and passenger airliner. During its operating life, the Latécoère 28 became the main-stay of Air France's predecessor, Aéropostale, which heavily used the aircraft during the 1930s in its efforts to establish intercontinental air mail services and support French colonialism and French cultural influence during the Interwar period.[citation needed] Its pilots included famous poets and French men of letters, such as Antoine de Saint-Exupéry and Jean Mermoz, along with numerous veteran pilots from the First World War. The Latécoère 28 was a development of the Latécoère 26. A total of about fifty aircraft of several versions were produced between 1927 and 1932. The seaplane version, the Latécoère 28-3, was the first to make a postal delivery crossing of the South Atlantic when Jean Mermoz flew from Dakar to Natal in 21 hours and a half aboard the Comte-de-La Vaulx (prototype n° 919) on 12 May 1930. [1] Unfortunately, the plane was lost at sea during the return flight (with no loss of life, nor of mail). Early examples had been furnished with Renault 12Jbr engines; however, all use of this powerplant was quickly substituted for by Hispano Suiza 12, which waw capable of providing up to 500 hp (370 kW). The floatplane version was equipped with the Hispano Suiza 12Lbr, which could generate to up 650 hp (480 kW). The Latécoère 28 was a long-range high-wing single-engined monoplane. The fuselage, which was highly streamlined and largely supported by light-metal tubing, was internally divided into three sections, each with its own distinct structure and function. The main landing gear comprised two independent wheels mounted on axles joined to the fuselage and supported by elastic struts that incorporated shock absorbers. The recoil from landing was absorbed via a light-metal strut in the plane of the axle, supported at one end by the axle's bend and hinged to the fuselage at the other end; atypically strong carbon-injected steel, which was hardened and tempered after machining, was used. A hinged elastic tail skid was also used to dampen the landing forces. The first aircraft were used by Aéropostale on the African mail routes connecting Casablanca and Dakar. The aircraft also inaugurated a Paris-Madrid service. The Latécoère 28 became famous in South America because of the regular mail service it performed between France and Argentina, amongst other destinations. This aircraft's introduction made it possible to send a letter from Paris to Santiago de Chile in what seemed then like an astonishingly short four days. Previously, the mail steamships had taken weeks or months. The Latécoère 28 was also operated in a military capacity. Venezuela purchased three aircraft for use as bombers while the French government supplied several to the Second Spanish Republic during the Spanish Civil War. For more details on the design, and the 11 variants, click here.
  12. red750
    Kharkiv KhAI-1
    The Kharkiv KhAI-1 (ХАІ-1) was an airliner produced in the Soviet Union in the early 1930s, unusual in that it was designed (and the prototype built) by students. An exceptionally clean design, the KhAI-1 was the first European passenger transport aircraft to feature retractable undercarriage, and boasted a top speed better than the fighter aircraft in service at the time. Some 40 KhAI-1s were operated by Aeroflot, but while a dedicated military version, the KhAI-1VV was developed and flown in prototype form, this did not enter production. The project was the brainchild of Iosif Grigorievich Nyeman, then head of aircraft construction at the newly formed Kharkiv Aviation Institute. Deciding to provide students with practical, hands-on experience, he divided the students into two teams, each assigned to designing an airliner making use of cheap, easily obtained materials. One team, led by L. D. Arson, was to work on a design incorporating modern techniques and design features designated KhAI-1, while the other, led by A. Eremenko, was to work on a more conservative design designated KhAI-2. The challenge was laid down in May 1931, and the timeframe specified was that the better design would need to be completed and ready for construction by February the following year. The whole venture was to be supervised by the Ukrainian branch of OSOAVIAKhIM. Soon, Nyeman selected the KhAI-1 as the design to proceed with. This was a low-wing, cantilever monoplane with a streamlined fuselage of oval cross-section, and retractable undercarriage. Construction was to be wood throughout, with fabric-covered control surfaces. The students were re-organised into ten teams of five to seven members each, and set to work on the detailed design of the aircraft's components and structures. The plans were completed on time, and in March 1932 work began at the Kharkiv Aviation Factory, then home to the design bureau of Nyeman's old mentor, Konstantin Alekseevich Kalinin. Construction of the prototype was undertaken by the students themselves, under the supervision of factory personnel, and was complete within 180 days. The aircraft first flew on 8 October at the hands of Boris Kudrin, with Nyeman on board as a passenger. The aircraft's high speed and good handling quickly became apparent, and following factory trials, the prototype KhAI-1 was flown to Moscow on 17 February 1933 for state acceptance trials, making the flight from Kharkiv in record time. These tests were completed by June, with test pilots I.F.Petrov and P.I.Stefanovskii confirming the aircraft's excellent performance, and recommending it for Aeroflot service, offering as it did a 50% increase in speed over the standard Kalinin K-5 airliner of the day. Nyeman was awarded the Order of the Red Star for the project. With the KhAI-1 ordered into series production, Nyeman initially requested that this be undertaken at the Kharkiv Aviation Factory, but this facility was gearing up to produce the Kalinin K-7 bomber and therefore lacked the capacity. Instead, production was assigned to the Gorky Aviation Plant (Zavod 21) which was concluding Polikarpov I-5 production. Production examples differed from the prototype in having a larger rudder, enlarged baggage compartment, revised undercarriage with oleo struts, and lighter wheel brakes, The passenger cabin was also revised, with additional sound-proofing and ventilation, and the addition of a lavatory. A revision of the general structure produced a weight saving of 125 kg (275 lb) and an increase in top speed from 292 km/h to 319 km/h (182 mph to 199 mph). However, only three aircraft were built here before the facility was needed to build the Polikarpov I-16 and KhAI-1 production was shifted to Zavod 43 in Kiev, where the rest of the aircraft were built. The first of these flew in November 1934, and airline service trials commenced the following April . The Soviet Air Force soon expressed interest in the design as an alternative to the Polikarpov R-Z then replacing the Polikarpov R-5 in the reconnaissance-bomber role. A single prototype was built of a KhAI-1VV (for Военный Вариант - Voennii Variant - "Military Variant"), armed with a rear-mounted machine gun, and bombs carried in internal racks. While performance was impressive, the bomb-release mechanism proved troublesome, and as development dragged on, the Air Force gradually lost interest. Following service trials between Moscow and Kyiv, the KhAI-1 was introduced on a regular Aeroflot service in early 1936 between Moscow and Sevastopol. Two accidents occurred during early service. In one, an outer wing panel broke soon after take-off, and in another, an undercarriage strut collapsed on landing. These events led to a review of the design by OKO, leading to general strengthening that added so much weight to the aircraft that one passenger seat had to be sacrificed. Production in Kiev had been suspended during this review, but was soon recommenced. Aeroflot continued using the type on passenger and mail routes until 1940 between Moscow and Kharkiv, Moscow and Minvody, and between Rostov and Krasnodar. Variants KhAI-1 - Passenger transport KhAI-1B - (a.k.a. KhAI-1VV), Military variant for bomber training, of which two were converted from KhAI-1, with a 200 kg bomb load, as well as one fixed and one moveable machine-gun.
  13. The Blohm & Voss BV 144 was an advanced twin-engined commercial airliner developed by Germany during World War II but intended for post-war service. It was unusual in having a variable-incidence wing. Two prototypes were built by Breguet in France. The BV 144 was an all-metal cantilever monoplane of broadly conventional layout with a high wing and twin tail fins. It had a crew of three and was intended to carry 18 to 23 passengers. A very unusual feature of the BV 144 was the variable-incidence wing. The wing mechanism had already been test flown on an Ha 140 floatplane. Combined on the BV 144 with a tricycle (nosewheel) landing gear, which was also still unusual in those days, it ensured the comfort of the passengers by maintaining a level fuselage during takeoff and also allowing the fuselage to sit low to the ground for ease of boarding. An electro-mechanical device rotated the wing by its main spar, up to 9°. The BV 144 was powered by two wing-mounted BMW 801 MA radial engines. For history and specifications, click here.
  14. The Gerhardt Cycleplane has been called the world's first successful human-powered aircraft. It was designed by Dr. William Frederick Gerhardt (January 31, 1896 – March 15, 1984), and assembled by the staff of the Flight Test Section at McCook Field in Dayton, Ohio. It was flown in 1923. The Cycleplane was constructed using private funds by members of the McCook Field Flight Test Section. Preliminary construction took place in secrecy in a barn loft. Officials from the base's Engineering Section later allowed Gerhardt and his crew to move into the McCook Field helicopter hangar for the aircraft's final assembly and storage. The Cycleplane had seven narrow vertically mounted wings, two attached to the small wood-and-fabric fuselage, and the other five stacked above it to a height of nearly 15 feet. A single pilot sat in an open cockpit near the wing roots where he pedaled a bicycle gear attached to a large two-bladed propeller. The aircraft made its first flight in July 1923. During initiate flight tests, an automobile towed the Cyleplane into the air and released it. Afterward Gerhardt was able to maintain stable, level flights for short periods of time. The only human-powered takeoff of the Cycleplane was a short hop of 20 feet (6 m) with the craft rising 2 feet (0.6 m).
  15. The Westland F.7/30 (or Westland PV.4) was a British fighter prototype. A single prototype was built in 1934, but the type was not put in production because its performance fell far below the RAF's requirements. The Gloster Gladiator won the F.7/30 competition. Full details here.
  16. The Miles M.20 was a Second World War British fighter developed by Miles Aircraft in 1940. It was designed as a simple and quick-to-build "emergency fighter" alternative to the Royal Air Force's Spitfires and Hurricanes should their production become disrupted by bombing expected in the anticipated German invasion of the United Kingdom. Due to the subsequent shifting of the German bombing effort after the Battle of Britain towards British cities in what became known as The Blitz, together with the dispersal of British fighter manufacturing, the Luftwaffe's bombing of the original Spitfire and Hurricane factories did not seriously affect production, and so the M.20 proved unnecessary and the design was not pursued. To reduce production time the M.20 employed all-wood construction and used many parts from the earlier Miles Master trainer, lacked hydraulics, and had spatted fixed landing gear. The fixed undercarriage freed space and payload sufficient for twelve .303 Browning machine guns and 5000 rounds, and 154 Imperial gallons (700 litres) of fuel (double the range and ammunition capacity of the Hawker Hurricane and Supermarine Spitfire). The M.20 was fitted with a bubble canopy for improved 360-degree vision. Two prototypes built.
  17. The Kayaba Heliplane Type-1 was a gyrodyne (compound autogyro) designed by Shiro Kayaba and prototyped by Kayaba Industry in Japan during the early 1950s. In March 1952, Kayaba Industry began the development of the Heliplane, a Gyrodyne, which combines the advantages of autogyro and helicopter. Kayaba took advantage of experience producing the Ka-Go Ka-1 and Ka-2 autogyros, intended for reconnaissance, artillery-spotting and anti-submarine use, developed during World War II. Kayaba received a subsidy of 2 million yen from the government of Japan for the development of the aircraft, as well as 1.2 million yen from Ishikawajima Heavy Industries (IHI) for development of the rotor-tip ramjets. The aircraft was modified from Cessna 170B. The wing was removed, and a three-blade main rotor with support structure was installed on the upper part of the fuselage. In addition, short-span fixed wings were fitted to either side of the lower fuselage. For initial testing the fixed pitch wooden propeller of the Cessna 170 was retained, but a 3-bladed variable-pitch propeller was to be fitted for flight testing. Ishikawajima had developed the Ne-0 ramjet during the war and tested it in flight beneath a Kawasaki Ki-48-II. A development of this ramjet was envisaged as the power source for the rotor drive. At takeoff, the rotor was to be started using the tip mounted ramjet engines, then transition to an autogyro powered by the propeller engine after the ramjets were stopped. One prototype unit was produced and almost completed in March 1954 (Showa 29), but was damaged in July 1954 during tie-down testing. Further development was cancelled before the aircraft was flown.
  18. red750
    Fairchild 100 Pilgrim
    John, there is a profile of the EP.9 on this site. https://www.recreationalflying.com/aircraft/general-aviation-single-engine/edgar-percival-ep-9-prospector-r1224/
  19. red750
    Junkers Ju 60
    The Junkers Ju 60 was a single engine airliner built in prototype form in Germany in the early 1930s. It was designed to meet a requirement issued by the Reichsverkehrsministerium (Reich Transport Ministry) for a German-built equivalent to the Lockheed Vega with which to equip Deutsche Luft Hansa. The result was a sleek, cantilever monoplane of conventional configuration, with wings skinned in the corrugated duralumin that had been a hallmark of Junkers designs up to this time, although this would be the last Junkers aircraft to have this feature. The main units of the tailwheel undercarriage were retractable. The Ju 60 was evaluated by Deutsche Luft Hansa against the Heinkel He 70. With the latter able to demonstrate a top speed 75 km/h (47 mph) better than the Ju 60, development of the Junkers design was halted before the third prototype had been completed. The two examples that had already been constructed eventually saw service with the Luftwaffe as liaison aircraft until 1942. The work done on the design would later form the basis of the Ju 160.
  20. The Fairchild 100 Pilgrim is an American single-engined high-wing monoplane transport, and was one of a series of single-engine utility transports built by Fairchild Aircraft. The 100 was similar in design to the Fairchild C-8 and was an enlarged version of it. The first flight of the aircraft (NC754Y) was October 22, 1930. Although only one aircraft was completed, a modified version also known as the Pilgrim 100-A was in production for American Airways, the first operator of the type in 1931. After a total of 16 aircraft, an additional batch of ten aircraft with a larger fin were manufactured by the restructured American Aircraft & Engine Corporation that emerged in 1931 from the Fairchild Aircraft Co. The continuing series was built under the designations, Pilgrim 100-B and American/Fairchild Y1C-24. The first six in the new series went to American Airways. The parent company later reinstated the Fairchild name. The sturdy Fairchild 100 series served as both an airliner and a bush plane. In 1932, the US Army Air Corps bought four Pilgrim Model 100-Bs designated the Y1C-24 and were initially assigned as light cargo transport and supply aircraft. After a short time in service, the Y1C-24s were adapted for use as aeromedical evacuation aircraft, carrying up to four litter patients. The aircraft were assigned to pilot training and pursuit aircraft airfields for use as crash rescue aircraft. Exploiting the Y1C-24's ability to take off and land in a relatively short distance, the Y1C-24s remained in service into the late 1930s when they were replaced by newer air ambulance aircraft. Variants Pilgrim 100 Prototype of the Pilgrim 100 family, powered by a 575 hp (429 kW) Pratt & Whitney R-1340 Wasp. designed by Virginius Clark, one built. Pilgrim 100-A aka American Pilgrim, powered by a 575 hp (429 kW) Pratt & Whitney Hornet B, derived directly from the Fairchild 100. 16 were built, all of which were operated by American Airways. Pilgrim 100-B Powered by a 575 hp (429 kW) Wright R-1820 Cyclone B, ten built, of which six for American Airways, and four to the US Army as the Fairchild Y1C-24. Fairchild Y1C-24 (Specifications below) Military designation for the US Army Y1C-24, four built, powered by 575 hp (429 kW) Wright R-1820-1 Cyclone engines. Pilgrim Y1C-24 Alternative military designation for the US Army Y1C-24.
  21. The KhAI-24 was designed by students of the Kharkiv Aviation Institute for an Estonian Ministry for the Energy Industry competition for a light autogyro for power cable inspection. The two-seat autogyro had an enclosed cabin and a tricycle landing gear, it was powered by a 115 hp (86 kW) Walter M332 aircraft engine driving a tractor configuration two-bladed propeller. A three-bladed rotor was fitted above the cabin. A full-scale model was displayed in 1966 in Moscow and the autogyro was tested in 1967 but nothing else is known.
  22. red750
    Focke Wulf Ta 152
    The Focke-Wulf Ta 152 is a World War II German high-altitude fighter-interceptor designed by Kurt Tank and produced by Focke-Wulf. The Ta 152 was a development of the Focke-Wulf Fw 190 aircraft. It was intended to be made in at least three versions—the Ta 152H Höhenjäger ("high-altitude fighter"); the Ta 152C designed for medium-altitude operations and ground-attack, using a Daimler-Benz DB 603 and smaller wings; and the Ta 152E fighter-reconnaissance aircraft with the engine of the H model and the wing of the C model. The first Ta 152H entered service with the Luftwaffe in January 1945. The Ta 152 was produced too late and in insufficient numbers to have a significant role in the war. The Fw 190's BMW 801 engine was originally designed for bomber and transport aircraft flying at medium altitudes in the 15,000 to 20,000 feet (4,600 to 6,100 m) range. In keeping with this role it used a relatively simple single-stage supercharger that lacked performance above 20,000 feet (6,100 m) altitude. This presented a problem for fighter use, where high-altitude performance was desirable. Through careful tuning, the Fw 190 instead emerged as a powerful medium altitude design. Several experimental models of the 190 with different engines were tested with improved high altitude performance, but these were not high priority projects. Allied heavy bombers and escort fighters began flying operations at higher altitudes, around 25,000 feet (7,600 m). At these altitudes, the 190 found itself at a disadvantage, becoming acute in early 1944 when the long range P-51 Mustang arrived in quantity. This led to the introduction of the Fw 190D-9, mounting the Junkers Jumo 213E engine. This engine had a two-stage supercharger and much better altitude performance. However, the rest of the aircraft's design, especially the relatively short wings, made it difficult to fly at high altitudes. While the D-9 upgrade was expedient, it was not ideal. High-altitude fighters Rumours of the B-29, which would cruise at altitudes at which no German aircraft could comfortably operate, added impetus for a dedicated high-altitude design. The Reichsluftfahrtministerium (German Air Ministry, or "RLM") requested proposals from both Focke-Wulf and Messerschmitt for a high-altitude interceptor. Messerschmitt answered with the Bf 109H, and Focke-Wulf entered a range of designs; the Fw 190 Raffat-1 (Ra-1) fighter would replace the existing 190D series, the Ra-2 was a dedicated high altitude fighter, and the Ra-3 was a ground-attack aircraft. These designs developed into the Fw 190 V20 (Ta 152A), V21 (Ta 152B) and V30 (Ta 152H) prototypes, all based on the 190D-9 but with varying degrees of improvement. The V20 used the same Jumo 213E engine as the Fw 190D-9, while the V21 used the DB 603E. Neither of these offered any significant improvement over the 190D-9, and further development of the Ta 152A and B was cancelled. The V21 airframe, however, was further modified as the V21/U1 and became the prototype for the Ta 152C. The Ta 152's fuselage was an extended version of the Fw 190D-9 fuselage with wider-chord fixed vertical tail surfaces (especially the top half), and hydraulic rather than electrically controlled undercarriage and flaps. Due to the changes in the center of gravity and overall balance, the nose was also lengthened.[5][page needed] The D-9 retained the 10.51 metres (34.5 ft) wingspan of the original pre-war Fw 190 models, but this was slightly extended for the C model to 11 metres (36 ft), and greatly extended for the H model to 14.44 metres (47.4 ft), which gave it much better control at high altitudes at the cost of speed at lower altitudes. Due to the war's impact on aluminium availability, the wing was built around two steel spars, the front extending from just past the landing gear attachment points, and the rear spar spanning the entire wing. The wing itself was designed with 3° of washout, from the root to the flap-aileron junction, to prevent the ailerons from stalling before the centre section of the wing. For more details of design and development, operational history and 8 variants, click here. A total of 69 Ta 152's were built.
  23. The North American AJ Savage (later A-2 Savage) is an American carrier-based medium bomber built for the United States Navy by North American Aviation. The aircraft was designed shortly after World War II to carry atomic bombs and this meant that the bomber was the heaviest aircraft thus far designed to operate from an aircraft carrier. It was powered by two piston engines and a turbojet buried in the rear fuselage. The AJ-1 first became operational in 1950 and several were based in South Korea during 1953 as a deterrent against North Korea. Of the 140 built, plus three prototypes, 30 were reconnaissance aircraft. Inflight-refueling equipment was deployed on the Savage in the mid-1950s. The bomber was replaced by the Douglas A3D Skywarrior beginning in 1957. The type was used after its military service for some additional experiments including microgravity test flights and to test a new jet engine in the 1960s and 70s. At the end of World War II, the U.S. Navy began a design competition on 13 August 1945 for a carrier-based bomber which could carry a 10,000-pound (4,536 kg) bomb that was won by North American Aviation. Later that year, the Navy decided that it needed to be able to deliver atomic bombs and that the AJ Savage design would be adapted to accommodate the latest Mark 4 nuclear bomb, the next step in development from the more sophisticated imploding-plutonium-sphere design Fat Man Mk3 used on Nagasaki. A contract for three XAJ-1 prototypes and a static test airframe was awarded on 24 June 1946. The first prototype made its maiden flight two years later on 3 July 1948. That same year the US Navy began an interim capability program employing the Lockheed P-2 Neptune carrying a crash-program reproduction of the smaller, simpler all-uranium 'gun' design Little Boy nuclear bomb as its first carrier-launched nuclear bomber aircraft until the Savage was in service. The Neptune launched using JATO assist but could not land on existing carriers; if launched they had to either ditch at sea after the mission or land at a friendly airbase. The AJ-1 was a three-seat, high-wing monoplane with tricycle landing gear. To facilitate carrier operations, the outer wing panels and the tailfin could be manually folded. It was fitted with two 2,300-brake-horsepower (1,700 kW) Pratt & Whitney R-2800-44W Double Wasp piston engines, mounted in nacelles under each wing with a large turbocharger fitted inside each engine nacelle, and a 4,600-pound-force (20,000 N) Allison J33-A-10 turbojet was fitted in the rear fuselage. The jet engine was only intended for takeoff and maximum speed near the target, and was fed by an air inlet on top of the fuselage that was normally kept closed to reduce drag.[6] To simplify the fuel system, the jet engine used piston engine avgas rather than jet fuel. One 201-US-gallon (760 L; 167 imp gal) self-sealing fuel tank was housed in the fuselage, and another 508-US-gallon (1,920 L; 423 imp gal) tank was located in each wing. The aircraft usually carried 300-US-gallon (1,100 L; 250 imp gal) tip tanks and it could house three fuel tanks in the bomb bay with a total capacity of 1,640 US gallons (6,200 L; 1,370 imp gal). Other than its 12,000-pound (5,400 kg) bombload, the bomber was unarmed. Two of the three prototypes crashed during testing, but their loss did not materially affect the development of the aircraft as the first batch of Savages had been ordered on 6 October 1947. The most significant difference between the XAJ-1 and the production aircraft was the revision of the cockpit to accommodate a third crewman in a separate compartment. The first flight by a production aircraft occurred in May 1949 and Fleet Composite Squadron 5 (VC-5) became the first squadron to receive a Savage in September. The squadron participated in testing and evaluating the aircraft together with the Naval Air Test Center (NATC) in order to expedite the Savage's introduction into the fleet. The first carrier takeoff and landing made by the bomber took place from the USS Coral Sea on 21 April and 31 August 1950, respectively. Many, if not most, surviving AJ-1s had their tails upgraded to the improved AJ-2 configuration. A photo-reconnaissance version of the Savage, initially known as the AJ-1P, but later designated as the AJ-2P, was ordered on 18 August 1950. It had improved R-2800-48 piston engines and the tail was redesigned to add 1 foot (30 cm) of height to the tailfin. The 12° dihedral of the tail stabilizers was eliminated and the rudder enlarged which slightly lengthened the aircraft. Early AJ-2Ps retained the three-man crew, but late-model aircraft added a fourth aft-facing crewman to the upper cockpit. The Savage's internal fuel capacity was also increased. The nose of the aircraft was remodeled with a prominent "chin" to accommodate a forward-looking oblique camera and a variety of oblique and vertical cameras could be fitted in the bomb bay. Photoflash bombs could be carried for night photography missions. The AJ-2 incorporated all of the changes made to the late model AJ-2P and 55 aircraft were ordered on 14 February 1951. The AJ-2 deleted the separate compartment for the third crewman, but retained the third seat in the cockpit from the AJ-2P. For details of operational history an the 13 variants, click here. All up, a total of 143 were built.
  24. red750
    Soko-J-20-Kraguj
    The Soko J-20 Kraguj (from Serbian: крагуј, lit. 'sparrowhawk') is a light military, single-engine, low-wing single-seat aircraft with a metal airframe, capable of performing close air support, counterinsurgency (COIN), and reconnaissance missions, that was designed by VTI and manufactured by SOKO of Yugoslavia, first flown in 1962. It is of classic semi-monocoque, metal structure with a slightly tapered wing. The pilot is accommodated in an enclosed, heated and ventilated cockpit with adjustable seats. The cockpit canopy slides backwards to open. The landing gear is non-retractable with a tail wheel. Rubber dampers provide shock absorption, and hydraulic brakes are used for wheel braking. The power plant comprises one 340 hp Textron Lycoming GSO-480-B1J6 piston engine and Hartzell HC-B3Z20-1/10151C-5 three-blade metal variable-pitch propeller. The engine cooling airflow is intensified by means of two specially designed ejectors. 36 US Gal of fuel contained in two rubber tanks enables a flight range of 350 NM for the fully armed configuration of the aircraft. 28 V DC electric power is supplied from a 1,5 kW generator and a storage battery. De-fogging and de-icing of the windshield is done by blowing of hot air. The aircraft was specially designed for low-altitude missions against day and night visible ground targets in a broad area. It was readily available to be loaded with weapons and supplied through a flexible system of auxiliary airfields that required no special preparations, especially in mountainous regions. Yugoslav military planners assumed that potential aggressor will first disable airfields. Therefore, J-20 Kraguj was designed to take-off from short unprepared runways, even ones covered in deep snow when fitted with skis. It was also called a "Partisan aircraft". The Kraguj P-2 was intended for close ground force support, and could be used for training of pilots in visual day/night flights, aiming, missile firing and bombing of ground targets.
