KRviator
Everything posted by KRviator
  1. I don't want to come across as an angry prick, but you've been provided a reference to where that answer can be found in the RAAus Ops manual and a hyperlink to the manual for you to review...Have you looked over the RAAus Ops manual yourself to try to find the answer?
  2. Not at all, it is quite clear, you just need to know where to look... Short answer, yes, if it was for the issue of a: CSU Tailwheel Retractable Float Floating hull or Controlled airspace endorsement or a flight test for the initial issue of an RPL/PPL/CPL. Reference is RAAus Ops Manual Section 2.07 Chapter 5(f)i-vi. And here's the curious thing - for the issue of any of the above endorsements, you do not need to be in an aircraft under 1,500Kg. You could do your retract endorsement on a Baron or Twinkie and it would still meet the requirements, but if you do a GA AFR then it must be in an aircraft under 1,500Kg...
  3. I'd find another inspector, or respectfully say "Thanks, but no thanks, they aren't required so I'll be saving the weight". I've flown my RV under RAAus for the last 3 years with not even a landing light in order to keep the weight down, and not one person has said tickety-boo about it. I have got a few comments about how well it's livery stands out in the circuit though... ClintonB is on point here. Marine and non-aviation lights will work, and likely work well but... they may cause interference on certain VHF frequencies - then again, they may not too, but you can't just whack them on and go fly, you'll need to turn your squelch down and incrementally go across the VHF band to confirm they don't impact your reception. One thing to consider with marine nav lights though, is they are typically based on vessel size. For example, for vessels under 12m they appear to only require they be visible to 1NM, for vessels upto 20m they need to be seen out to 2NM. At the speeds we can close on traffic at, that's less than 30 seconds to identify the light, assess it, and maneuver to arrange separation. So check what size vessel they're intended for and go the higher one if you can afford it!
  4. Who needs CAsA when you have Youtube! I'd forgotten about the US version...Enjoy!
  5. Here you go. I merged my two Dynon databases the other day for a new available-daylight calculator and had them all together. Every ALA, Certified & Registered airport in Australia, from the May 2020 DAH. HLS' are not included. Enough acronyms for everyone, yes? [TABLE] [TR] [TD]YADY[/TD][TD]ADAMINABY[/TD] [/TR] [TR] [TD]YPAD[/TD][TD]ADELAIDE[/TD] [/TR] [TR] [TD]YPPF[/TD][TD]ADELAIDE/PARAFIELD[/TD] [/TR] [TR] [TD]YALG[/TD][TD]ADELS GROVE[/TD] [/TR] [TR] [TD]YABA[/TD][TD]ALBANY[/TD] [/TR] [TR] [TD]YMAY[/TD][TD]ALBURY[/TD] [/TR] [TR] [TD]YADG[/TD][TD]ALDINGA[/TD] [/TR] [TR] [TD]YBAS[/TD][TD]ALICE SPRINGS[/TD] [/TR] [TR] [TD]YAPH[/TD][TD]ALPHA[/TD] [/TR] [TR] [TD]YAMT[/TD][TD]AMATA[/TD] [/TR] [TR] [TD]YAMB[/TD][TD]AMBERLEY[/TD] [/TR] [TR] [TD]YANK[/TD][TD]ANNA CREEK[/TD] [/TR] [TR] [TD]YAMC[/TD][TD]ARAMAC[/TD] [/TR] [TR] [TD]YARA[/TD][TD]ARARAT[/TD] [/TR] [TR] [TD]YARG[/TD][TD]ARGYLE[/TD] [/TR] [TR] [TD]YARK[/TD][TD]ARKAROOLA[/TD] [/TR] [TR] [TD]YARM[/TD][TD]ARMIDALE[/TD] [/TR] [TR] [TD]YARY[/TD][TD]ARRABURY[/TD] [/TR] [TR] [TD]YATN[/TD][TD]ATHERTON[/TD] [/TR] [TR] [TD]YAUG[/TD][TD]AUGUSTA[/TD] [/TR] [TR] [TD]YAGD[/TD][TD]AUGUSTUS DOWNS[/TD] [/TR] [TR] [TD]YAUR[/TD][TD]AURUKUN[/TD] [/TR] [TR] [TD]YMAV[/TD][TD]AVALON[/TD] [/TR] [TR] [TD]YAYE[/TD][TD]AYERS ROCK/CONNELLAN[/TD] [/TR] [TR] [TD]YAYR[/TD][TD]AYR[/TD] [/TR] [TR] [TD]YBSS[/TD][TD]BACCHUS MARSH[/TD] [/TR] [TR] [TD]YBAU[/TD][TD]BADU ISLAND[/TD] [/TR] [TR] [TD]YBNS[/TD][TD]BAIRNSDALE[/TD] [/TR] [TR] [TD]YBLC[/TD][TD]BALCANOONA[/TD] [/TR] [TR] [TD]YBGO[/TD][TD]BALGO HILL[/TD] [/TR] [TR] [TD]YBLT[/TD][TD]BALLARAT[/TD] [/TR] [TR] [TD]YLLE[/TD][TD]BALLERA[/TD] [/TR] [TR] [TD]YBIU[/TD][TD]BALLIDU[/TD] [/TR] [TR] [TD]YBNA[/TD][TD]BALLINA/BYRON GATEWAY[/TD] [/TR] [TR] [TD]YBRN[/TD][TD]BALRANALD[/TD] [/TR] [TR] [TD]YBMY[/TD][TD]BAMYILI[/TD] [/TR] [TR] [TD]YBAD[/TD][TD]BARADINE[/TD] [/TR] [TR] [TD]YBAB[/TD][TD]BARALABA[/TD] [/TR] [TR] [TD]YBAR[/TD][TD]BARCALDINE[/TD] [/TR] [TR] [TD]YBRY[/TD][TD]BARIMUNYA[/TD] [/TR] [TR] [TD]YBWX[/TD][TD]BARROW ISLAND[/TD] [/TR] [TR] [TD]YBRS[/TD][TD]BARWON HEADS/GEELONG[/TD] [/TR] [TR] [TD]YBYL[/TD][TD]BARYULGIL[/TD] [/TR] [TR] [TD]YBTH[/TD][TD]BATHURST[/TD] [/TR] [TR] [TD]YBTI[/TD][TD]BATHURST ISLAND[/TD] [/TR] [TR] [TD]YBFT[/TD][TD]BEAUFORT[/TD] [/TR] [TR] [TD]YBIE[/TD][TD]BEDOURIE[/TD] [/TR] [TR] [TD]YBEB[/TD][TD]BELLBURN[/TD] [/TR] [TR] [TD]YBLU[/TD][TD]BELLEVUE[/TD] [/TR] [TR] [TD]YBLA[/TD][TD]BENALLA[/TD] [/TR] [TR] [TD]YBDG[/TD][TD]BENDIGO[/TD] [/TR] [TR] [TD]YBEO[/TD][TD]BETOOTA[/TD] [/TR] [TR] [TD]YBEE[/TD][TD]BEVERLEY[/TD] [/TR] [TR] [TD]YBHL[/TD][TD]BINDOON HILL[/TD] [/TR] [TR] [TD]YBIR[/TD][TD]BIRCHIP[/TD] [/TR] [TR] [TD]YBDV[/TD][TD]BIRDSVILLE[/TD] [/TR] [TR] [TD]YBCK[/TD][TD]BLACKALL[/TD] [/TR] [TR] [TD]YBTR[/TD][TD]BLACKWATER[/TD] [/TR] [TR] [TD]YBLP[/TD][TD]BLUE WATER PARK[/TD] [/TR] [TR] [TD]YBOI[/TD][TD]BOIGU ISLAND[/TD] [/TR] [TR] [TD]YBLL[/TD][TD]BOLLON[/TD] [/TR] [TR] [TD]YBOM[/TD][TD]BOMBALA[/TD] [/TR] [TR] [TD]YBOC[/TD][TD]BOOLEROO[/TD] [/TR] [TR] [TD]YBGD[/TD][TD]BOOLGEEDA[/TD] [/TR] [TR] [TD]YBMI[/TD][TD]BOOMI[/TD] [/TR] [TR] [TD]YBOA[/TD][TD]BOONAH[/TD] [/TR] [TR] [TD]YBBT[/TD][TD]BOORT[/TD] [/TR] [TR] [TD]YBOR[/TD][TD]BORDERTOWN[/TD] [/TR] [TR] [TD]YBRL[/TD][TD]BORROLOOLA[/TD] [/TR] [TR] [TD]YBOU[/TD][TD]BOULIA[/TD] [/TR] [TR] [TD]YBKE[/TD][TD]BOURKE[/TD] [/TR] [TR] [TD]YBWN[/TD][TD]BOWEN[/TD] [/TR] [TR] [TD]YBRW[/TD][TD]BREWARRINA[/TD] [/TR] [TR] [TD]YBGR[/TD][TD]BRIDGEWATER[/TD] [/TR] [TR] [TD]YBBN[/TD][TD]BRISBANE[/TD] [/TR] [TR] [TD]YBWW[/TD][TD]BRISBANE WEST WELLCAMP[/TD] [/TR] [TR] [TD]YBAF[/TD][TD]BRISBANE/ARCHERFIELD[/TD] [/TR] [TR] [TD]YBHI[/TD][TD]BROKEN HILL[/TD] [/TR] [TR] [TD]YBRM[/TD][TD]BROOME/INTL[/TD] [/TR] [TR] [TD]YBNR[/TD][TD]BROWNS RANGE[/TD] [/TR] [TR] [TD]YBUN[/TD][TD]BUNBURY[/TD] [/TR] [TR] [TD]YBUD[/TD][TD]BUNDABERG[/TD] [/TR] [TR] [TD]YBKT[/TD][TD]BURKETOWN[/TD] [/TR] [TR] [TD]YBLN[/TD][TD]BUSSELTON[/TD] [/TR] [TR] [TD]YCAB[/TD][TD]CABOOLTURE[/TD] [/TR] [TR] [TD]YCDH[/TD][TD]CADNEY HOMESTEAD[/TD] [/TR] [TR] [TD]YCAG[/TD][TD]CAIGUNA[/TD] [/TR] [TR] [TD]YBCS[/TD][TD]CAIRNS/CAIRNS INTL[/TD] [/TR] [TR] [TD]YCDR[/TD][TD]CALOUNDRA[/TD] [/TR] [TR] [TD]YCVG[/TD][TD]CALVIN GROVE[/TD] [/TR] [TR] [TD]YSCN[/TD][TD]CAMDEN[/TD] [/TR] [TR] [TD]YCMH[/TD][TD]CAMDEN HAVEN[/TD] [/TR] [TR] [TD]YCMW[/TD][TD]CAMOOWEAL[/TD] [/TR] [TR] [TD]YSCB[/TD][TD]CANBERRA[/TD] [/TR] [TR] [TD]YCLQ[/TD][TD]CAPE LEVEQUE[/TD] [/TR] [TR] [TD]YCPR[/TD][TD]CAPE PRESTON[/TD] [/TR] [TR] [TD]YCEL[/TD][TD]CAPELLA[/TD] [/TR] [TR] [TD]YCDW[/TD][TD]CARDWELL/DALLACHY[/TD] [/TR] [TR] [TD]YCAR[/TD][TD]CARNARVON[/TD] [/TR] [TR] [TD]YSCD[/TD][TD]CAROSUE DAM[/TD] [/TR] [TR] [TD]YCPT[/TD][TD]CARRAPATEENA[/TD] [/TR] [TR] [TD]YCAS[/TD][TD]CASINO[/TD] [/TR] [TR] [TD]YCTN[/TD][TD]CASTERTON[/TD] [/TR] [TR] [TD]YCDU[/TD][TD]CEDUNA[/TD] [/TR] [TR] [TD]YCNY[/TD][TD]CENTURY MINE[/TD] [/TR] [TR] [TD]YCES[/TD][TD]CERES[/TD] [/TR] [TR] [TD]YCNK[/TD][TD]CESSNOCK[/TD] [/TR] [TR] [TD]YBCV[/TD][TD]CHARLEVILLE[/TD] [/TR] [TR] [TD]YCHT[/TD][TD]CHARTERS TOWERS[/TD] [/TR] [TR] [TD]YCGO[/TD][TD]CHILLAGOE[/TD] [/TR] [TR] [TD]YCCA[/TD][TD]CHINCHILLA[/TD] [/TR] [TR] [TD]YCHK[/TD][TD]CHRISTMAS CREEK[/TD] [/TR] [TR] [TD]YPXM[/TD][TD]CHRISTMAS ISLAND[/TD] [/TR] [TR] [TD]YCVA[/TD][TD]CLARE VALLEY[/TD] [/TR] [TR] [TD]YCMT[/TD][TD]CLERMONT[/TD] [/TR] [TR] [TD]YCEE[/TD][TD]CLEVE[/TD] [/TR] [TR] [TD]YCFN[/TD][TD]CLIFTON[/TD] [/TR] [TR] [TD]YCCY[/TD][TD]CLONCURRY[/TD] [/TR] [TR] [TD]YUNY[/TD][TD]CLUNY[/TD] [/TR] [TR] [TD]YCBA[/TD][TD]COBAR[/TD] [/TR] [TR] [TD]YCDE[/TD][TD]COBDEN[/TD] [/TR] [TR] [TD]YCTI[/TD][TD]COCKATOO ISLAND[/TD] [/TR] [TR] [TD]YCCT[/TD][TD]COCONUT ISLAND[/TD] [/TR] [TR] [TD]YPCC[/TD][TD]COCOS (KEELING) ISLAND[/TD] [/TR] [TR] [TD]YCOE[/TD][TD]COEN[/TD] [/TR] [TR] [TD]YCOF[/TD][TD]COFFIN BAY[/TD] [/TR] [TR] [TD]YCFS[/TD][TD]COFFS HARBOUR[/TD] [/TR] [TR] [TD]YCOH[/TD][TD]COHUNA[/TD] [/TR] [TR] [TD]YOLA[/TD][TD]COLAC[/TD] [/TR] [TR] [TD]YCEM[/TD][TD]COLDSTREAM[/TD] [/TR] [TR] [TD]YCBR[/TD][TD]COLLARENEBRI[/TD] [/TR] [TR] [TD]YCSV[/TD][TD]COLLINSVILLE[/TD] [/TR] [TR] [TD]YCDO[/TD][TD]CONDOBOLIN[/TD] [/TR] [TR] [TD]YCBP[/TD][TD]COOBER PEDY[/TD] [/TR] [TR] [TD]YCOO[/TD][TD]COOINDA[/TD] [/TR] [TR] [TD]YCKN[/TD][TD]COOKTOWN[/TD] [/TR] [TR] [TD]YCAH[/TD][TD]COOLAH[/TD] [/TR] [TR] [TD]YPFT[/TD][TD]COOMA - POLO[/TD] [/TR] [TR] [TD]YCOM[/TD][TD]COOMA - SNOWY MOUNTAINS[/TD] [/TR] [TR] [TD]YBCM[/TD][TD]COOMINYA[/TD] [/TR] [TR] [TD]YCBB[/TD][TD]COONABARABRAN[/TD] [/TR] [TR] [TD]YCNM[/TD][TD]COONAMBLE[/TD] [/TR] [TR] [TD]YCWA[/TD][TD]COONDEWANNA[/TD] [/TR] [TR] [TD]YCTM[/TD][TD]COOTAMUNDRA[/TD] [/TR] [TR] [TD]YCOR[/TD][TD]COROWA[/TD] [/TR] [TR] [TD]YCRG[/TD][TD]CORRYONG[/TD] [/TR] [TR] [TD]YCWL[/TD][TD]COWELL[/TD] [/TR] [TR] [TD]YCWR[/TD][TD]COWRA[/TD] [/TR] [TR] [TD]YCRN[/TD][TD]CRANBOURN[/TD] [/TR] [TR] [TD]YCKI[/TD][TD]CROKER ISLAND[/TD] [/TR] [TR] [TD]YCRL[/TD][TD]CROOKWELL[/TD] [/TR] [TR] [TD]YCRY[/TD][TD]CROYDON[/TD] [/TR] [TR] [TD]YCUE[/TD][TD]CUE[/TD] [/TR] [TR] [TD]YCMM[/TD][TD]CUMMINS TOWN[/TD] [/TR] [TR] [TD]YCUN[/TD][TD]CUNDERDIN[/TD] [/TR] [TR] [TD]YCMU[/TD][TD]CUNNAMULLA[/TD] [/TR] [TR] [TD]YCIN[/TD][TD]CURTIN[/TD] [/TR] [TR] [TD]YDAY[/TD][TD]DALBY[/TD] [/TR] [TR] [TD]YDGA[/TD][TD]DALGARANGA MINE[/TD] [/TR] [TR] [TD]YDLO[/TD][TD]DARLOT[/TD] [/TR] [TR] [TD]YDNI[/TD][TD]DARNLEY ISLAND[/TD] [/TR] [TR] [TD]YPDN[/TD][TD]DARWIN[/TD] [/TR] [TR] [TD]YDPD[/TD][TD]DAVENPORT DOWNS[/TD] [/TR] [TR] [TD]YDGU[/TD][TD]DEGRUSSA[/TD] [/TR] [TR] [TD]YDWF[/TD][TD]DELAMERE RANGE FACILITY[/TD] [/TR] [TR] [TD]YDLV[/TD][TD]DELISSAVILLE[/TD] [/TR] [TR] [TD]YDLT[/TD][TD]DELTA DOWNS[/TD] [/TR] [TR] [TD]YDLQ[/TD][TD]DENILIQUIN[/TD] [/TR] [TR] [TD]YDEK[/TD][TD]DENMARK[/TD] [/TR] [TR] [TD]YDBY[/TD][TD]DERBY[/TD] [/TR] [TR] [TD]YDPO[/TD][TD]DEVONPORT[/TD] [/TR] [TR] [TD]YDBI[/TD][TD]DIRRANBANDI[/TD] [/TR] [TR] [TD]YDOC[/TD][TD]DOCHRA[/TD] [/TR] [TR] [TD]YDVR[/TD][TD]DOCKER RIVER[/TD] [/TR] [TR] [TD]YDOD[/TD][TD]DONALD[/TD] [/TR] [TR] [TD]YDOP[/TD][TD]DONNINGTON AIRPARK[/TD] [/TR] [TR] [TD]YDMG[/TD][TD]DOOMADGEE[/TD] [/TR] [TR] [TD]YDOR[/TD][TD]DORUNDA STATION[/TD] [/TR] [TR] [TD]YDRN[/TD][TD]DROUIN[/TD] [/TR] [TR] [TD]YDRD[/TD][TD]DRYSDALE RIVER[/TD] [/TR] [TR] [TD]YSDU[/TD][TD]DUBBO[/TD] [/TR] [TR] [TD]YDKG[/TD][TD]DUKETON GOLD[/TD] [/TR] [TR] [TD]YDBR[/TD][TD]DUNBAR[/TD] [/TR] [TR] [TD]YDKI[/TD][TD]DUNK ISLAND[/TD] [/TR] [TR] [TD]YDUN[/TD][TD]DUNWICH[/TD] [/TR] [TR] [TD]YDRH[/TD][TD]DURHAM DOWNS[/TD] [/TR] [TR] [TD]YDRI[/TD][TD]DURRIE[/TD] [/TR] [TR] [TD]YDYS[/TD][TD]DYSART[/TD] [/TR] [TR] [TD]YEJI[/TD][TD]EAST JAURDI[/TD] [/TR] [TR] [TD]YMES[/TD][TD]EAST SALE[/TD] [/TR] [TR] [TD]YECH[/TD][TD]ECHUCA[/TD] [/TR] [TR] [TD]YECB[/TD][TD]ECO BEACH[/TD] [/TR] [TR] [TD]YPED[/TD][TD]EDINBURGH[/TD] [/TR] [TR] [TD]YESD[/TD][TD]EIDSVOLD[/TD] [/TR] [TR] [TD]YELD[/TD][TD]ELCHO ISLAND[/TD] [/TR] [TR] [TD]YEQY[/TD][TD]ELIZABETH QUAY[/TD] [/TR] [TR] [TD]YELN[/TD][TD]ELLISTON[/TD] [/TR] [TR] [TD]YESE[/TD][TD]ELROSE[/TD] [/TR] [TR] [TD]YEML[/TD][TD]EMERALD[/TD] [/TR] [TR] [TD]YMKT[/TD][TD]EMKAYTEE[/TD] [/TR] [TR] [TD]YEMP[/TD][TD]EMU PARK[/TD] [/TR] [TR] [TD]YERN[/TD][TD]ERNABELLA[/TD] [/TR] [TR] [TD]YEMG[/TD][TD]EROMANGA[/TD] [/TR] [TR] [TD]YESP[/TD][TD]ESPERANCE[/TD] [/TR] [TR] [TD]YEUO[/TD][TD]EULO[/TD] [/TR] [TR] [TD]YEUA[/TD][TD]EUROA[/TD] [/TR] [TR] [TD]YEVD[/TD][TD]EVANS HEAD[/TD] [/TR] [TR] [TD]YEXM[/TD][TD]EXMOUTH[/TD] [/TR] [TR] [TD]YFDN[/TD][TD]FEDERATION[/TD] [/TR] [TR] [TD]YFTZ[/TD][TD]FITZROY CROSSING[/TD] [/TR] [TR] [TD]YFLI[/TD][TD]FLINDERS ISLAND[/TD] [/TR] [TR] [TD]YFBS[/TD][TD]FORBES[/TD] [/TR] [TR] [TD]YFRT[/TD][TD]FORREST[/TD] [/TR] [TR] [TD]YFTA[/TD][TD]FORRESTANIA[/TD] [/TR] [TR] [TD]YFDF[/TD][TD]FORTESCUE DAVE FORREST[/TD] [/TR] [TR] [TD]YFRG[/TD][TD]FREGON[/TD] [/TR] [TR] [TD]YGPT[/TD][TD]GARDEN POINT[/TD] [/TR] [TR] [TD]YGAS[/TD][TD]GATTON AIRPARK[/TD] [/TR] [TR] [TD]YGAW[/TD][TD]GAWLER[/TD] [/TR] [TR] [TD]YGAY[/TD][TD]GAYNDAH[/TD] [/TR] [TR] [TD]YGTO[/TD][TD]GEORGE TOWN (TAS)[/TD] [/TR] [TR] [TD]YGTN[/TD][TD]GEORGETOWN (QLD)[/TD] [/TR] [TR] [TD]YGEL[/TD][TD]GERALDTON[/TD] [/TR] [TR] [TD]YGIB[/TD][TD]GIBB RIVER[/TD] [/TR] [TR] [TD]YGLS[/TD][TD]GILES[/TD] [/TR] [TR] [TD]YGIL[/TD][TD]GILGANDRA[/TD] [/TR] [TR] [TD]YGIA[/TD][TD]GINBATA[/TD] [/TR] [TR] [TD]YGIG[/TD][TD]GINGIN[/TD] [/TR] [TR] [TD]YGLA[/TD][TD]GLADSTONE[/TD] [/TR] [TR] [TD]YGLI[/TD][TD]GLEN INNES[/TD] [/TR] [TR] [TD]YGLO[/TD][TD]GLENORMISTON[/TD] [/TR] [TR] [TD]YGNE[/TD][TD]GNARWARRE[/TD] [/TR] [TR] [TD]YGNW[/TD][TD]GNOWANGERUP[/TD] [/TR] [TR] [TD]YBCG[/TD][TD]GOLD COAST[/TD] [/TR] [TR] [TD]YGGE[/TD][TD]GOLDEN GROVE[/TD] [/TR] [TR] [TD]YGDA[/TD][TD]GOODOOGA[/TD] [/TR] [TR] [TD]YGGI[/TD][TD]GOOLGOWI[/TD] [/TR] [TR] [TD]YGWA[/TD][TD]GOOLWA[/TD] [/TR] [TR] [TD]YGDI[/TD][TD]GOONDIWINDI[/TD] [/TR] [TR] [TD]YGLB[/TD][TD]GOULBURN[/TD] [/TR] [TR] [TD]YPGV[/TD][TD]GOVE[/TD] [/TR] [TR] [TD]YGFN[/TD][TD]GRAFTON[/TD] [/TR] [TR] [TD]YGRS[/TD][TD]GRANNY SMITH[/TD] [/TR] [TR] [TD]YGRL[/TD][TD]GREAT LAKES AIRFIELD[/TD] [/TR] [TR] [TD]YGDS[/TD][TD]GREGORY DOWNS[/TD] [/TR] [TR] [TD]YGTH[/TD][TD]GRIFFITH[/TD] [/TR] [TR] [TD]YGTE[/TD][TD]GROOTE EYLANDT[/TD] [/TR] [TR] [TD]YGRM[/TD][TD]GRUYERE[/TD] [/TR] [TR] [TD]YGDO[/TD][TD]GUNDAROO[/TD] [/TR] [TR] [TD]YGDH[/TD][TD]GUNNEDAH[/TD] [/TR] [TR] [TD]YGYM[/TD][TD]GYMPIE[/TD] [/TR] [TR] [TD]YHAA[/TD][TD]HAASTS BLUFF[/TD] [/TR] [TR] [TD]YHLC[/TD][TD]HALLS CREEK[/TD] [/TR] [TR] [TD]YHML[/TD][TD]HAMILTON[/TD] [/TR] [TR] [TD]YBHM[/TD][TD]HAMILTON ISLAND[/TD] [/TR] [TR] [TD]YHAE[/TD][TD]HARDEN[/TD] [/TR] [TR] [TD]YHAW[/TD][TD]HAWKER[/TD] [/TR] [TR] [TD]YHAY[/TD][TD]HAY[/TD] [/TR] [TR] [TD]YHEC[/TD][TD]HECK FIELD[/TD] [/TR] [TR] [TD]YHCS[/TD][TD]HERBERTVALE CATTLEYARD[/TD] [/TR] [TR] [TD]YHMB[/TD][TD]HERMANNSBURG[/TD] [/TR] [TR] [TD]YHBA[/TD][TD]HERVEY BAY[/TD] [/TR] [TR] [TD]YHLS[/TD][TD]HILLSTON[/TD] [/TR] [TR] [TD]YMHB[/TD][TD]HOBART[/TD] [/TR] [TR] [TD]YCBG[/TD][TD]HOBART/CAMBRIDGE[/TD] [/TR] [TR] [TD]YHBK[/TD][TD]HOLBROOK[/TD] [/TR] [TR] [TD]YSHW[/TD][TD]HOLSWORTHY[/TD] [/TR] [TR] [TD]YHON[/TD][TD]HONEYMOON[/TD] [/TR] [TR] [TD]YHOO[/TD][TD]HOOKER CREEK[/TD] [/TR] [TR] [TD]YHPN[/TD][TD]HOPETOUN[/TD] [/TR] [TR] [TD]YHID[/TD][TD]HORN ISLAND[/TD] [/TR] [TR] [TD]YHSM[/TD][TD]HORSHAM[/TD] [/TR] [TR] [TD]YHUG[/TD][TD]HUGHENDEN[/TD] [/TR] [TR] [TD]YHRD[/TD][TD]HUNGERFORD[/TD] [/TR] [TR] [TD]YIFY[/TD][TD]IFFLEY[/TD] [/TR] [TR] [TD]YILF[/TD][TD]ILFRACOMBE[/TD] [/TR] [TR] [TD]YIGM[/TD][TD]INGHAM[/TD] [/TR] [TR] [TD]YINJ[/TD][TD]INJUNE[/TD] [/TR] [TR] [TD]YIKM[/TD][TD]INKERMAN STATION[/TD] [/TR] [TR] [TD]YINN[/TD][TD]INNAMINCKA[/TD] [/TR] [TR] [TD]YIMT[/TD][TD]INNAMINCKA TOWNSHIP[/TD] [/TR] [TR] [TD]YIFL[/TD][TD]INNISFAIL[/TD] [/TR] [TR] [TD]YIVL[/TD][TD]INVERELL[/TD] [/TR] [TR] [TD]YISF[/TD][TD]ISISFORD[/TD] [/TR] [TR] [TD]YIVO[/TD][TD]IVANHOE[/TD] [/TR] [TR] [TD]YJAB[/TD][TD]JABIRU[/TD] [/TR] [TR] [TD]YJAC[/TD][TD]JACINTH AMBROSIA[/TD] [/TR] [TR] [TD]YJST[/TD][TD]JAMESTOWN[/TD] [/TR] [TR] [TD]YJER[/TD][TD]JERILDERIE[/TD] [/TR] [TR] [TD]YJBY[/TD][TD]JERVIS BAY[/TD] [/TR] [TR] [TD]YJIN[/TD][TD]JINDABYNE[/TD] [/TR] [TR] [TD]YJLC[/TD][TD]JULIA CREEK[/TD] [/TR] [TR] [TD]YJDA[/TD][TD]JUNDAH[/TD] [/TR] [TR] [TD]YJUN[/TD][TD]JUNDEE[/TD] [/TR] [TR] [TD]YJUR[/TD][TD]JURIEN BAY[/TD] [/TR] [TR] [TD]YKDI[/TD][TD]KADINA[/TD] [/TR] [TR] [TD]YKBR[/TD][TD]KALBARRI[/TD] [/TR] [TR] [TD]YPKG[/TD][TD]KALGOORLIE-BOULDER[/TD] [/TR] [TR] [TD]YKKG[/TD][TD]KALKGURUNG[/TD] [/TR] [TR] [TD]YKAL[/TD][TD]KALUMBURU[/TD] [/TR] [TR] [TD]YKBL[/TD][TD]KAMBALDA[/TD] [/TR] [TR] [TD]YKML[/TD][TD]KAMILEROI[/TD] [/TR] [TR] [TD]YKAR[/TD][TD]KARARA[/TD] [/TR] [TR] [TD]YPKA[/TD][TD]KARRATHA[/TD] [/TR] [TR] [TD]YKMB[/TD][TD]KARUMBA[/TD] [/TR] [TR] [TD]YKNG[/TD][TD]KATANNING[/TD] [/TR] [TR] [TD]YKAT[/TD][TD]KATOOMBA[/TD] [/TR] [TR] [TD]YKMP[/TD][TD]KEMPSEY[/TD] [/TR] [TR] [TD]YKER[/TD][TD]KERANG[/TD] [/TR] [TR] [TD]YKDM[/TD][TD]KIDMAN SPRINGS[/TD] [/TR] [TR] [TD]YKID[/TD][TD]KIDSTON[/TD] [/TR] [TR] [TD]YKCY[/TD][TD]KILCOY[/TD] [/TR] [TR] [TD]YKLE[/TD][TD]KILLARNEY[/TD] [/TR] [TR] [TD]YIMB[/TD][TD]KIMBA[/TD] [/TR] [TR] [TD]YKKN[/TD][TD]KIN KIN RETREAT[/TD] [/TR] [TR] [TD]YKAB[/TD][TD]KING ASH BAY[/TD] [/TR] [TR] [TD]YKII[/TD][TD]KING ISLAND[/TD] [/TR] [TR] [TD]YKRY[/TD][TD]KINGAROY[/TD] [/TR] [TR] [TD]YKCS[/TD][TD]KINGS CREEK STN[/TD] [/TR] [TR] [TD]YKSC[/TD][TD]KINGSCOTE/KANGAROO ISLAND[/TD] [/TR] [TR] [TD]YKIG[/TD][TD]KINGSTON[/TD] [/TR] [TR] [TD]YKDN[/TD][TD]KONDININ[/TD] [/TR] [TR] [TD]YKLI[/TD][TD]KOOLAN ISLAND[/TD] [/TR] [TR] [TD]YKBN[/TD][TD]KOORALBYN[/TD] [/TR] [TR] [TD]YKOW[/TD][TD]KOWANYAMA[/TD] [/TR] [TR] [TD]YKUB[/TD][TD]KUBIN[/TD] [/TR] [TR] [TD]YPKU[/TD][TD]KUNUNURRA[/TD] [/TR] [TR] [TD]YKTN[/TD][TD]KYNETON[/TD] [/TR] [TR] [TD]YLCG[/TD][TD]LAKE CARGELLIGO[/TD] [/TR] [TR] [TD]YLEV[/TD][TD]LAKE EVELLA[/TD] [/TR] [TR] [TD]YLJN[/TD][TD]LAKE JOHNSTON[/TD] [/TR] [TR] [TD]YKEP[/TD][TD]LAKE KEEPIT[/TD] [/TR] [TR] [TD]YLMQ[/TD][TD]LAKE MACQUARIE AIRPORT[/TD] [/TR] [TR] [TD]YLND[/TD][TD]LAKELAND DOWNS[/TD] [/TR] [TR] [TD]YLKE[/TD][TD]LAKES ENTRANCE[/TD] [/TR] [TR] [TD]YLAK[/TD][TD]LAKESIDE AIRPARK[/TD] [/TR] [TR] [TD]YLCK[/TD][TD]LASSIE CREEK STATION[/TD] [/TR] [TR] [TD]YLTV[/TD][TD]LATROBE VALLEY[/TD] [/TR] [TR] [TD]YMLT[/TD][TD]LAUNCESTON[/TD] [/TR] [TR] [TD]YLTN[/TD][TD]LAVERTON (WA)[/TD] [/TR] [TR] [TD]YLAW[/TD][TD]LAWLERS[/TD] [/TR] [TR] [TD]YLAH[/TD][TD]LAWN HILL[/TD] [/TR] [TR] [TD]YPLM[/TD][TD]LEARMONTH[/TD] [/TR] [TR] [TD]YLGU[/TD][TD]LEGUNE STN[/TD] [/TR] [TR] [TD]YLEC[/TD][TD]LEIGH CREEK[/TD] [/TR] [TR] [TD]YLST[/TD][TD]LEINSTER[/TD] [/TR] [TR] [TD]YLEG[/TD][TD]LEONGATHA[/TD] [/TR] [TR] [TD]YLEO[/TD][TD]LEONORA[/TD] [/TR] [TR] [TD]YLED[/TD][TD]LETHBRIDGE AIRPORT[/TD] [/TR] [TR] [TD]YLRD[/TD][TD]LIGHTNING RIDGE[/TD] [/TR] [TR] [TD]YLIL[/TD][TD]LILYDALE[/TD] [/TR] [TR] [TD]YLIS[/TD][TD]LISMORE[/TD] [/TR] [TR] [TD]YLZI[/TD][TD]LIZARD ISLAND[/TD] [/TR] [TR] [TD]YLHR[/TD][TD]LOCKHART RIVER[/TD] [/TR] [TR] [TD]YLCS[/TD][TD]LOCKSLEY FIELD[/TD] [/TR] [TR] [TD]YLRE[/TD][TD]LONGREACH[/TD] [/TR] [TR] [TD]YLHI[/TD][TD]LORD HOWE ISLAND[/TD] [/TR] [TR] [TD]YLOR[/TD][TD]LORRAINE[/TD] [/TR] [TR] [TD]YLOV[/TD][TD]LOTUS VALE STN[/TD] [/TR] [TR] [TD]YLOH[/TD][TD]LOUTH[/TD] [/TR] [TR] [TD]YLOX[/TD][TD]LOXTON[/TD] [/TR] [TR] [TD]YLYK[/TD][TD]LYNDOCH[/TD] [/TR] [TR] [TD]YMAA[/TD][TD]MABUIAG ISLAND[/TD] [/TR] [TR] [TD]YBMK[/TD][TD]MACKAY[/TD] [/TR] [TR] [TD]YMND[/TD][TD]MAITLAND (NSW)[/TD] [/TR] [TR] [TD]YMLD[/TD][TD]MAITLAND (SA)[/TD] [/TR] [TR] [TD]YMCO[/TD][TD]MALLACOOTA[/TD] [/TR] [TR] [TD]YMNG[/TD][TD]MANGALORE[/TD] [/TR] [TR] [TD]YMGD[/TD][TD]MANINGRIDA[/TD] [/TR] [TR] [TD]YMJM[/TD][TD]MANJIMUP[/TD] [/TR] [TR] [TD]YMFD[/TD][TD]MANSFIELD[/TD] [/TR] [TR] [TD]YMBL[/TD][TD]MARBLE BAR[/TD] [/TR] [TR] [TD]YMBA[/TD][TD]MAREEBA[/TD] [/TR] [TR] [TD]YMGT[/TD][TD]MARGARET RIVER[/TD] [/TR] [TR] [TD]YMGR[/TD][TD]MARGARET RIVER STN[/TD] [/TR] [TR] [TD]YALA[/TD][TD]MARLA[/TD] [/TR] [TR] [TD]YMRE[/TD][TD]MARREE[/TD] [/TR] [TR] [TD]YMYB[/TD][TD]MARYBOROUGH (QLD)[/TD] [/TR] [TR] [TD]YMHU[/TD][TD]MCARTHUR RIVER MINE[/TD] [/TR] [TR] [TD]YMEK[/TD][TD]MEEKATHARRA[/TD] [/TR] [TR] [TD]YMML[/TD][TD]MELBOURNE[/TD] [/TR] [TR] [TD]YMEN[/TD][TD]MELBOURNE/ESSENDON[/TD] [/TR] [TR] [TD]YMMB[/TD][TD]MELBOURNE/MOORABBIN[/TD] [/TR] [TR] [TD]YMEL[/TD][TD]MELTON[/TD] [/TR] [TR] [TD]YMET[/TD][TD]MELVILLE WATER AERODROME[/TD] [/TR] [TR] [TD]YMEI[/TD][TD]MEREENIE[/TD] [/TR] [TR] [TD]YMER[/TD][TD]MERIMBULA[/TD] [/TR] [TR] [TD]YMDN[/TD][TD]MERREDIN[/TD] [/TR] [TR] [TD]YMMU[/TD][TD]MIDDLEMOUNT[/TD] [/TR] [TR] [TD]YMIA[/TD][TD]MILDURA[/TD] [/TR] [TR] [TD]YMLS[/TD][TD]MILES[/TD] [/TR] [TR] [TD]YMGB[/TD][TD]MILINGIMBI[/TD] [/TR] [TR] [TD]YMIO[/TD][TD]MILL IRON[/TD] [/TR] [TR] [TD]YMCT[/TD][TD]MILLICENT[/TD] [/TR] [TR] [TD]YMMN[/TD][TD]MILLMERRAN[/TD] [/TR] [TR] [TD]YMDR[/TD][TD]MINDEROO[/TD] [/TR] [TR] [TD]YMPA[/TD][TD]MINNIPA[/TD] [/TR] [TR] [TD]YMIT[/TD][TD]MITCHELL[/TD] [/TR] [TR] [TD]YITT[/TD][TD]MITTA MITTA[/TD] [/TR] [TR] [TD]YMIG[/TD][TD]MITTAGONG[/TD] [/TR] [TR] [TD]YMMO[/TD][TD]MOAMA[/TD] [/TR] [TR] [TD]YMOD[/TD][TD]MODEWARRE[/TD] [/TR] [TR] [TD]YMNK[/TD][TD]MONKIRA[/TD] [/TR] [TR] [TD]YMTO[/TD][TD]MONTO[/TD] [/TR] [TR] [TD]YOOM[/TD][TD]MOOMBA[/TD] [/TR] [TR] [TD]YMOO[/TD][TD]MOORABERREE[/TD] [/TR] [TR] [TD]YMRB[/TD][TD]MORANBAH[/TD] [/TR] [TR] [TD]YMRW[/TD][TD]MORAWA[/TD] [/TR] [TR] [TD]YMOR[/TD][TD]MOREE[/TD] [/TR] [TR] [TD]YMNY[/TD][TD]MORNEY[/TD] [/TR] [TR] [TD]YMTI[/TD][TD]MORNINGTON ISLAND[/TD] [/TR] [TR] [TD]YMRY[/TD][TD]MORUYA[/TD] [/TR] [TR] [TD]YMBT[/TD][TD]MOUNT BEAUTY[/TD] [/TR] [TR] [TD]YMDY[/TD][TD]MOUNT BUNDEY[/TD] [/TR] [TR] [TD]YMCL[/TD][TD]MOUNT COOLON[/TD] [/TR] [TR] [TD]YMTG[/TD][TD]MOUNT GAMBIER[/TD] [/TR] [TR] [TD]YGON[/TD][TD]MOUNT GORDON[/TD] [/TR] [TR] [TD]YMHL[/TD][TD]MOUNT HOLLAND[/TD] [/TR] [TR] [TD]YHOT[/TD][TD]MOUNT HOTHAM[/TD] [/TR] [TR] [TD]YMHO[/TD][TD]MOUNT HOUSE[/TD] [/TR] [TR] [TD]YMHW[/TD][TD]MOUNT HOWITT[/TD] [/TR] [TR] [TD]YBMA[/TD][TD]MOUNT ISA[/TD] [/TR] [TR] [TD]YMNE[/TD][TD]MOUNT KEITH[/TD] [/TR] [TR] [TD]YMOG[/TD][TD]MOUNT MAGNET[/TD] [/TR] [TR] [TD]YMSF[/TD][TD]MOUNT SANFORD STATION[/TD] [/TR] [TR] [TD]YMOU[/TD][TD]MOURA[/TD] [/TR] [TR] [TD]YMDG[/TD][TD]MUDGEE[/TD] [/TR] [TR] [TD]YMWA[/TD][TD]MULLEWA[/TD] [/TR] [TR] [TD]YMDA[/TD][TD]MUNDUBBERA[/TD] [/TR] [TR] [TD]YMGI[/TD][TD]MUNGINDI[/TD] [/TR] [TR] [TD]YLMU[/TD][TD]MUNGO LODGE[/TD] [/TR] [TR] [TD]YMRG[/TD][TD]MURGON[/TD] [/TR] [TR] [TD]YMBD[/TD][TD]MURRAY BRIDGE[/TD] [/TR] [TR] [TD]YMUL[/TD][TD]MURRAY FIELD[/TD] [/TR] [TR] [TD]YMAE[/TD][TD]MURRAY/MER ISLAND[/TD] [/TR] [TR] [TD]YMMI[/TD][TD]MURRIN MURRIN[/TD] [/TR] [TR] [TD]YMUR[/TD][TD]MURWILLUMBAH[/TD] [/TR] [TR] [TD]YMTB[/TD][TD]MUTTABURRA[/TD] [/TR] [TR] [TD]YMYU[/TD][TD]MYRUP[/TD] [/TR] [TR] [TD]YNKR[/TD][TD]NACKEROO[/TD] [/TR] [TR] [TD]YNGW[/TD][TD]NAGAMBIE- WIRRATE[/TD] [/TR] [TR] [TD]YNAN[/TD][TD]NANANGO[/TD] [/TR] [TR] [TD]YNAP[/TD][TD]NAPPA MERRIE[/TD] [/TR] [TR] [TD]YNRC[/TD][TD]NARACOORTE[/TD] [/TR] [TR] [TD]YNRB[/TD][TD]NAREMBEEN[/TD] [/TR] [TR] [TD]YNBR[/TD][TD]NARRABRI[/TD] [/TR] [TR] [TD]YNAR[/TD][TD]NARRANDERA[/TD] [/TR] [TR] [TD]YNRG[/TD][TD]NARROGIN[/TD] [/TR] [TR] [TD]YNRM[/TD][TD]NARROMINE[/TD] [/TR] [TR] [TD]YNWN[/TD][TD]NEWMAN[/TD] [/TR] [TR] [TD]YNGU[/TD][TD]NGUKURR[/TD] [/TR] [TR] [TD]YNHL[/TD][TD]NHILL[/TD] [/TR] [TR] [TD]YCNF[/TD][TD]NIFTY[/TD] [/TR] [TR] [TD]YNSH[/TD][TD]NOOSA[/TD] [/TR] [TR] [TD]YSNF[/TD][TD]NORFOLK ISLAND[/TD] [/TR] [TR] [TD]YNTN[/TD][TD]NORMANTON[/TD] [/TR] [TR] [TD]YNSM[/TD][TD]NORSEMAN[/TD] [/TR] [TR] [TD]YNTM[/TD][TD]NORTHAM[/TD] [/TR] [TR] [TD]YNPE[/TD][TD]NORTHERN PENINSULA[/TD] [/TR] [TR] [TD]YNOV[/TD][TD]NOVA[/TD] [/TR] [TR] [TD]YSNW[/TD][TD]NOWRA[/TD] [/TR] [TR] [TD]YNUL[/TD][TD]NULLAGINE[/TD] [/TR] [TR] [TD]YNUB[/TD][TD]NULLARBOR MOTEL[/TD] [/TR] [TR] [TD]YNUM[/TD][TD]NUMBULWAR[/TD] [/TR] [TR] [TD]YNYN[/TD][TD]NYNGAN[/TD] [/TR] [TR] [TD]YBOK[/TD][TD]OAKEY[/TD] [/TR] [TR] [TD]YOAY[/TD][TD]OAKY CREEK[/TD] [/TR] [TR] [TD]YOCA[/TD][TD]OCHRE ARCH[/TD] [/TR] [TR] [TD]YOEN[/TD][TD]OENPELLI[/TD] [/TR] [TR] [TD]YOLD[/TD][TD]OLYMPIC DAM[/TD] [/TR] [TR] [TD]YOLW[/TD][TD]ONSLOW[/TD] [/TR] [TR] [TD]YOOD[/TD][TD]OODNADATTA[/TD] [/TR] [TR] [TD]YORG[/TD][TD]ORANGE[/TD] [/TR] [TR] [TD]YORB[/TD][TD]ORBOST[/TD] [/TR] [TR] [TD]YORR[/TD][TD]ORROROO[/TD] [/TR] [TR] [TD]YOSB[/TD][TD]OSBORNE MINE[/TD] [/TR] [TR] [TD]YPAC[/TD][TD]PACIFIC HAVEN[/TD] [/TR] [TR] [TD]YPAM[/TD][TD]PALM ISLAND[/TD] [/TR] [TR] [TD]YPAY[/TD][TD]PAPUNYA[/TD] [/TR] [TR] [TD]YPBO[/TD][TD]PARABURDOO[/TD] [/TR] [TR] [TD]YPKS[/TD][TD]PARKES[/TD] [/TR] [TR] [TD]YPEA[/TD][TD]PEARCE[/TD] [/TR] [TR] [TD]YPEF[/TD][TD]PENFIELD[/TD] [/TR] [TR] [TD]YPPH[/TD][TD]PERTH[/TD] [/TR] [TR] [TD]YPJT[/TD][TD]PERTH/JANDAKOT[/TD] [/TR] [TR] [TD]YPTB[/TD][TD]PETERBOROUGH[/TD] [/TR] [TR] [TD]YPBH[/TD][TD]PETERBOROUGH (VIC)[/TD] [/TR] [TR] [TD]YPNA[/TD][TD]PINNARENDI[/TD] [/TR] [TR] [TD]YPNN[/TD][TD]PINNAROO[/TD] [/TR] [TR] [TD]YPWH[/TD][TD]PITTSWORTH[/TD] [/TR] [TR] [TD]YPLU[/TD][TD]PLUTONIC[/TD] [/TR] [TR] [TD]YMPC[/TD][TD]POINT COOK[/TD] [/TR] [TR] [TD]YPCE[/TD][TD]POONCARIE[/TD] [/TR] [TR] [TD]YPOK[/TD][TD]POREPUNKAH[/TD] [/TR] [TR] [TD]YPMP[/TD][TD]PORMPURAAW[/TD] [/TR] [TR] [TD]YPAG[/TD][TD]PORT AUGUSTA[/TD] [/TR] [TR] [TD]YPPD[/TD][TD]PORT HEDLAND[/TD] [/TR] [TR] [TD]YPKT[/TD][TD]PORT KEATS[/TD] [/TR] [TR] [TD]YPLC[/TD][TD]PORT LINCOLN[/TD] [/TR] [TR] [TD]YPMQ[/TD][TD]PORT MACQUARIE[/TD] [/TR] [TR] [TD]YPIR[/TD][TD]PORT PIRIE[/TD] [/TR] [TR] [TD]YPOD[/TD][TD]PORTLAND[/TD] [/TR] [TR] [TD]YPMH[/TD][TD]PROMINENT HILL[/TD] [/TR] [TR] [TD]YBPN[/TD][TD]PROSERPINE/WHITSUNDAY COAST[/TD] [/TR] [TR] [TD]YPKL[/TD][TD]PUCKAPUNYAL[/TD] [/TR] [TR] [TD]YPUG[/TD][TD]PUNGALINA[/TD] [/TR] [TR] [TD]YQNS[/TD][TD]QUEENSTOWN[/TD] [/TR] [TR] [TD]YQLP[/TD][TD]QUILPIE[/TD] [/TR] [TR] [TD]YQDI[/TD][TD]QUIRINDI[/TD] [/TR] [TR] [TD]YQRN[/TD][TD]QUORN[/TD] [/TR] [TR] [TD]YRNG[/TD][TD]RAMINGINING[/TD] [/TR] [TR] [TD]YNRV[/TD][TD]RAVENSTHORPE[/TD] [/TR] [TR] [TD]YRYW[/TD][TD]RAYWOOD[/TD] [/TR] [TR] [TD]YRED[/TD][TD]REDCLIFFE[/TD] [/TR] [TR] [TD]YREN[/TD][TD]RENMARK[/TD] [/TR] [TR] [TD]YSRI[/TD][TD]RICHMOND (NSW)[/TD] [/TR] [TR] [TD]YRMD[/TD][TD]RICHMOND (QLD)[/TD] [/TR] [TR] [TD]YRID[/TD][TD]RIDDELL[/TD] [/TR] [TR] [TD]YRBE[/TD][TD]ROBE[/TD] [/TR] [TR] [TD]YROB[/TD][TD]ROBINHOOD[/TD] [/TR] [TR] [TD]YROI[/TD][TD]ROBINVALE[/TD] [/TR] [TR] [TD]YBRK[/TD][TD]ROCKHAMPTON[/TD] [/TR] [TR] [TD]YRLL[/TD][TD]ROLLESTON[/TD] [/TR] [TR] [TD]YROM[/TD][TD]ROMA[/TD] [/TR] [TR] [TD]YRSY[/TD][TD]ROMSEY[/TD] [/TR] [TR] [TD]YRAY[/TD][TD]ROSE BAY[/TD] [/TR] [TR] [TD]YRVL[/TD][TD]ROSE VALE[/TD] [/TR] [TR] [TD]YRSB[/TD][TD]ROSEBERTH[/TD] [/TR] [TR] [TD]YRTI[/TD][TD]ROTTNEST ISLAND[/TD] [/TR] [TR] [TD]YBSL[/TD][TD]ROWSLEY/BROOKS LANDING[/TD] [/TR] [TR] [TD]YRTP[/TD][TD]RUTLAND PLAINS[/TD] [/TR] [TR] [TD]YRYL[/TD][TD]RYLSTONE AIRPARK[/TD] [/TR] [TR] [TD]YSII[/TD][TD]SAIBAI ISLAND[/TD] [/TR] [TR] [TD]YSTA[/TD][TD]SAINT ARNAUD[/TD] [/TR] [TR] [TD]YSGE[/TD][TD]SAINT GEORGE[/TD] [/TR] [TR] [TD]YSTH[/TD][TD]SAINT HELENS[/TD] [/TR] [TR] [TD]YSAM[/TD][TD]SAMARAI[/TD] [/TR] [TR] [TD]YBSG[/TD][TD]SCHERGER (RAAF)[/TD] [/TR] [TR] [TD]YSCO[/TD][TD]SCONE[/TD] [/TR] [TR] [TD]YSCA[/TD][TD]SCOTIA SANCTUARY[/TD] [/TR] [TR] [TD]YSLK[/TD][TD]SEA LAKE[/TD] [/TR] [TR] [TD]YSEN[/TD][TD]SERPENTINE[/TD] [/TR] [TR] [TD]YSHK[/TD][TD]SHARK BAY[/TD] [/TR] [TR] [TD]YSHG[/TD][TD]SHAY GAP[/TD] [/TR] [TR] [TD]YSHL[/TD][TD]SHELLHARBOUR AIRPORT[/TD] [/TR] [TR] [TD]YSHT[/TD][TD]SHEPPARTON[/TD] [/TR] [TR] [TD]YSHR[/TD][TD]SHUTE HARBOUR/ WHITSUNDAY[/TD] [/TR] [TR] [TD]YSGT[/TD][TD]SINGLETON[/TD] [/TR] [TR] [TD]YSMI[/TD][TD]SMITHTON[/TD] [/TR] [TR] [TD]YSNK[/TD][TD]SNAKE BAY[/TD] [/TR] [TR] [TD]YSOL[/TD][TD]SOLOMON[/TD] [/TR] [TR] [TD]YSMB[/TD][TD]SOMERSBY[/TD] [/TR] [TR] [TD]YSGW[/TD][TD]SOUTH GALWAY[/TD] [/TR] [TR] [TD]YGBI[/TD][TD]SOUTH GOULBURN ISLAND[/TD] [/TR] [TR] [TD]YSGR[/TD][TD]SOUTH GRAFTON[/TD] [/TR] [TR] [TD]YSCR[/TD][TD]SOUTHERN CROSS[/TD] [/TR] [TR] [TD]YSPT[/TD][TD]SOUTHPORT[/TD] [/TR] [TR] [TD]YSPK[/TD][TD]SPRING CREEK[/TD] [/TR] [TR] [TD]YSPI[/TD][TD]SPRINGSURE[/TD] [/TR] [TR] [TD]YSPE[/TD][TD]STANTHORPE[/TD] [/TR] [TR] [TD]YSWL[/TD][TD]STAWELL[/TD] [/TR] [TR] [TD]YSTL[/TD][TD]STIRLING STATION[/TD] [/TR] [TR] [TD]YSFG[/TD][TD]STONEFIELD GLIDING[/TD] [/TR] [TR] [TD]YSTO[/TD][TD]STONEHENGE[/TD] [/TR] [TR] [TD]YSRN[/TD][TD]STRAHAN[/TD] [/TR] [TR] [TD]YKBY[/TD][TD]STREAKY BAY[/TD] [/TR] [TR] [TD]YSNY[/TD][TD]SUNNYSIDE[/TD] [/TR] [TR] [TD]YSRD[/TD][TD]SUNRISE DAM[/TD] [/TR] [TR] [TD]YBSU[/TD][TD]SUNSHINE COAST[/TD] [/TR] [TR] [TD]YSRT[/TD][TD]SURAT[/TD] [/TR] [TR] [TD]YSWB[/TD][TD]SWAN BAY[/TD] [/TR] [TR] [TD]YSWH[/TD][TD]SWAN HILL[/TD] [/TR] [TR] [TD]YSBK[/TD][TD]SYDNEY/BANKSTOWN[/TD] [/TR] [TR] [TD]YSSY[/TD][TD]SYDNEY/KINGSFORD SMITH[/TD] [/TR] [TR] [TD]YTMB[/TD][TD]TAMBO[/TD] [/TR] [TR] [TD]YSTW[/TD][TD]TAMWORTH[/TD] [/TR] [TR] [TD]YTMN[/TD][TD]TANAMI[/TD] [/TR] [TR] [TD]YTAA[/TD][TD]TARA[/TD] [/TR] [TR] [TD]YTRE[/TD][TD]TAREE[/TD] [/TR] [TR] [TD]YTAM[/TD][TD]TAROOM[/TD] [/TR] [TR] [TD]YTEF[/TD][TD]TELFER[/TD] [/TR] [TR] [TD]YTEM[/TD][TD]TEMORA[/TD] [/TR] [TR] [TD]YTNK[/TD][TD]TENNANT CREEK[/TD] [/TR] [TR] [TD]YTNG[/TD][TD]THANGOOL[/TD] [/TR] [TR] [TD]YTGM[/TD][TD]THARGOMINDAH[/TD] [/TR] [TR] [TD]YTGT[/TD][TD]THE GRANITES[/TD] [/TR] [TR] [TD]YLKS[/TD][TD]THE LAKES[/TD] [/TR] [TR] [TD]YTMO[/TD][TD]THE MONUMENT[/TD] [/TR] [TR] [TD]YOAS[/TD][TD]THE OAKS[/TD] [/TR] [TR] [TD]YVAL[/TD][TD]THE VALE[/TD] [/TR] [TR] [TD]YTDR[/TD][TD]THEODORE[/TD] [/TR] [TR] [TD]YTHN[/TD][TD]THUNDERBOX[/TD] [/TR] [TR] [TD]YTHY[/TD][TD]THYLUNGRA[/TD] [/TR] [TR] [TD]YTIB[/TD][TD]TIBOOBURRA[/TD] [/TR] [TR] [TD]YTLP[/TD][TD]TILPA[/TD] [/TR] [TR] [TD]YTBR[/TD][TD]TIMBER CREEK[/TD] [/TR] [TR] [TD]YPTN[/TD][TD]TINDAL[/TD] [/TR] [TR] [TD]YTOC[/TD][TD]TOCUMWAL[/TD] [/TR] [TR] [TD]YTDN[/TD][TD]TOORADIN[/TD] [/TR] [TR] [TD]YTKS[/TD][TD]TOORAK RESEARCH STATION[/TD] [/TR] [TR] [TD]YTWN[/TD][TD]TOORAWEENAH[/TD] [/TR] [TR] [TD]YTWB[/TD][TD]TOOWOOMBA[/TD] [/TR] [TR] [TD]YTQY[/TD][TD]TORQUAY[/TD] [/TR] [TR] [TD]YTOT[/TD][TD]TOTTENHAM[/TD] [/TR] [TR] [TD]YBTL[/TD][TD]TOWNSVILLE/TOWNSVILLE INTL[/TD] [/TR] [TR] [TD]YTWG[/TD][TD]TOWRANG GLIDING[/TD] [/TR] [TR] [TD]YTGL[/TD][TD]TREGALANA[/TD] [/TR] [TR] [TD]YTEE[/TD][TD]TREPELL[/TD] [/TR] [TR] [TD]YTRA[/TD][TD]TROPICANA[/TD] [/TR] [TR] [TD]YTTI[/TD][TD]TROUGHTON ISLAND[/TD] [/TR] [TR] [TD]YTFA[/TD][TD]TRURO FLAT AIRPARK[/TD] [/TR] [TR] [TD]YTST[/TD][TD]TRUSCOTT-MUNGALALU[/TD] [/TR] [TR] [TD]YTUY[/TD][TD]TULLY[/TD] [/TR] [TR] [TD]YTBB[/TD][TD]TUMBY BAY[/TD] [/TR] [TR] [TD]YTMU[/TD][TD]TUMUT[/TD] [/TR] [TR] [TD]YTPK[/TD][TD]TURTLE PARK[/TD] [/TR] [TR] [TD]YTYA[/TD][TD]TYABB[/TD] [/TR] [TR] [TD]YTYH[/TD][TD]TYAGARAH[/TD] [/TR] [TR] [TD]YUDA[/TD][TD]UNDARA[/TD] [/TR] [TR] [TD]YUDG[/TD][TD]URANDANGI[/TD] [/TR] [TR] [TD]YVRS[/TD][TD]VAN ROOK STATION[/TD] [/TR] [TR] [TD]YVRD[/TD][TD]VICTORIA RIVER DOWNS[/TD] [/TR] [TR] [TD]YSWG[/TD][TD]WAGGA WAGGA[/TD] [/TR] [TR] [TD]YWGN[/TD][TD]WAGIN[/TD] [/TR] [TR] [TD]YWHG[/TD][TD]WAHRING FIELD[/TD] [/TR] [TR] [TD]YWKI[/TD][TD]WAIKERIE[/TD] [/TR] [TR] [TD]YWCH[/TD][TD]WALCHA[/TD] [/TR] [TR] [TD]YWLG[/TD][TD]WALGETT[/TD] [/TR] [TR] [TD]YWAG[/TD][TD]WANAARING[/TD] [/TR] [TR] [TD]YWGT[/TD][TD]WANGARATTA[/TD] [/TR] [TR] [TD]YWBR[/TD][TD]WARBURTON[/TD] [/TR] [TR] [TD]YWRL[/TD][TD]WARIALDA[/TD] [/TR] [TR] [TD]YWKW[/TD][TD]WARKWORTH[/TD] [/TR] [TR] [TD]YWVA[/TD][TD]WARNERVALE[/TD] [/TR] [TR] [TD]YWBS[/TD][TD]WARRABER ISLAND[/TD] [/TR] [TR] [TD]YWBI[/TD][TD]WARRABRI[/TD] [/TR] [TR] [TD]YWKB[/TD][TD]WARRACKNABEAL[/TD] [/TR] [TR] [TD]YWRN[/TD][TD]WARREN[/TD] [/TR] [TR] [TD]YWBL[/TD][TD]WARRNAMBOOL[/TD] [/TR] [TR] [TD]YWCK[/TD][TD]WARWICK[/TD] [/TR] [TR] [TD]YWTL[/TD][TD]WATERLOO (NT)[/TD] [/TR] [TR] [TD]YWSG[/TD][TD]WATTS BRIDGE[/TD] [/TR] [TR] [TD]YWAV[/TD][TD]WAVE HILL[/TD] [/TR] [TR] [TD]YWBN[/TD][TD]WEDDERBURN[/TD] [/TR] [TR] [TD]YBWP[/TD][TD]WEIPA[/TD] [/TR] [TR] [TD]YWEL[/TD][TD]WELLINGTON[/TD] [/TR] [TR] [TD]YWTO[/TD][TD]WENTWORTH[/TD] [/TR] [TR] [TD]YANG[/TD][TD]WEST ANGELAS[/TD] [/TR] [TR] [TD]YWSL[/TD][TD]WEST SALE[/TD] [/TR] [TR] [TD]YWWL[/TD][TD]WEST WYALONG[/TD] [/TR] [TR] [TD]YWHC[/TD][TD]WHITE CLIFFS[/TD] [/TR] [TR] [TD]YWGM[/TD][TD]WHITE GUM[/TD] [/TR] [TR] [TD]YWHA[/TD][TD]WHYALLA[/TD] [/TR] [TR] [TD]YWCA[/TD][TD]WILCANNIA[/TD] [/TR] [TR] [TD]YWMC[/TD][TD]WILLIAM CREEK[/TD] [/TR] [TR] [TD]YWIS[/TD][TD]WILLIAMSON[/TD] [/TR] [TR] [TD]YWLM[/TD][TD]WILLIAMTOWN[/TD] [/TR] [TR] [TD]YWLU[/TD][TD]WILUNA[/TD] [/TR] [TR] [TD]YWDG[/TD][TD]WINDARLING[/TD] [/TR] [TR] [TD]YWDH[/TD][TD]WINDORAH[/TD] [/TR] [TR] [TD]YWTN[/TD][TD]WINTON[/TD] [/TR] [TR] [TD]YWND[/TD][TD]WONDAI[/TD] [/TR] [TR] [TD]YWDL[/TD][TD]WONDOOLA[/TD] [/TR] [TR] [TD]YWWI[/TD][TD]WOODIE WOODIE[/TD] [/TR] [TR] [TD]YPWR[/TD][TD]WOOMERA[/TD] [/TR] [TR] [TD]YWMP[/TD][TD]WROTHAM PARK[/TD] [/TR] [TR] [TD]YWUD[/TD][TD]WUDINNA[/TD] [/TR] [TR] [TD]YWYA[/TD][TD]WYANDRA[/TD] [/TR] [TR] [TD]YWYF[/TD][TD]WYCHEPROOF[/TD] [/TR] [TR] [TD]YWYM[/TD][TD]WYNDHAM[/TD] [/TR] [TR] [TD]YWYY[/TD][TD]WYNYARD[/TD] [/TR] [TR] [TD]YWYR[/TD][TD]WYREEMA[/TD] [/TR] [TR] [TD]YYMI[/TD][TD]YAM ISLAND[/TD] [/TR] [TR] [TD]YYRN[/TD][TD]YAMARNA[/TD] [/TR] [TR] [TD]YYRM[/TD][TD]YARRAM[/TD] [/TR] [TR] [TD]YYWG[/TD][TD]YARRAWONGA[/TD] [/TR] [TR] [TD]YYKI[/TD][TD]YORKE ISLAND[/TD] [/TR] [TR] [TD]YYNG[/TD][TD]YOUNG[/TD] [/TR] [TR] [TD]YYND[/TD][TD]YUENDUMU[/TD] [/TR] [/TABLE]
  6. Something to be said for activating your ELT - if you have a fixed version - prior to landing. You can always call AMSA after landing if you are able to, and if you're not able, help is already coming. That's the only thing I don't like about carrying a 406 PLB in my vest, the inability to set it off before the landing.
  7. Looks like he has a Brumby with a 912ULS:
  8. With careful planning, a CAVU day and attention to detail. Me at 75Kg, Coey at 57Kg, a 5Kg wing pod and fuel for a 18Nm flight out at 100Kts a couple of orbits and 18Nm flight back with a 30 minute fixed reserve. Flight fuel was planned at 11L, with a 9L reserve. Departed with 24L and landed with about 12L in the right tank. The task was to scatter a (pilot) mate's ashes from the air, and fortunately his wife had many hours airborne with him, so she understood the planning and could ignore the "LEFT LEVEL LOW" and flashing "0" warnings on the EFIS. That RV-7 reportedly caused a lot of issues...A two-seat RV can be had in RAAus, but it is a niche machine, as I've said here previously. It suited my mission at the time (ME + not-quite-full tanks or Me+Mini-Me+2hrs fuel). I've gained a bit of weight and the kids are growing, so 600Kg is no longer sufficient, so to VH- she went. If it suits your mission, RAAus is fine. But you do need to be conscious of your weight to stay legal. Some people don't...
  9. Just make sure they know what they're doing if you have a Dynon/Garmin EFIS. There's been several cases where they haven't been put into the relevant mode and, on the LAME doing their "normal" pitot/static or transponder test, have severely screwed up the ADAHRS. Simply reducing static pressure without a corresponding change in acceleration or position is catered for on these systems, but you can't just give it to the LAME and say "Call me when you're done!"
  10. You certainly can. I had an RV-9A on the RAAus register for several years with two seats. 445Kg BEW so a 155Kg payload. I only flew with two adults once, and she was very slightly built but I was still legal. There's another, lighter, RV-9A up at Watts Bridge, also on RAAus' register, though mine has now gone to VH-.
  11. $482 in a bundle at Bunnings. If you were wiring a plane from scratch, that's quite cheap for what you get in terms of traceability of wiring. Heck, even for the 4by or something it'd be good if you are adding a bunch of accessories!
  12. A lot of it comes down to sheer cost, IMHO. I was somewhat lucky when I built my RV-9 in that the $$ was much higher than it is now. I have probably $130,000 in my RV, but to built 'like for like' today would probably cost you close to $170,000 and that is an awful lot of $$ for someone who is trying to pay off a mortgage, or even simply save a deposit. Even over a 10-year timeframe, that's $17,000 every year, or a mortgage payment for a smallish house. Then there's the ongoing costs. I'm up for $6,000 a year in fixed costs before I spin the prop. Add in $200/hour just in landing fees for circuit training at Warnervale or some other airports, why on earth would you pursue something so expensive for so little reward? Those that have newish RV's, or those composite wonders aren't going to put them up for sale unless they have to, because they'll lose far too much replacing them. As much as I love the flying, CAsA (with their million-and-one rules and tacking on "this is an offence of strict liability" onto every piece of legislation), RAAus (the Privacy Policy disclosure debacle and the direction the organisation is going) DOTRS (ASIC, need I say more) and the various airport owners (who mandate an ASIC, 24/48H PPR, have 12'high razor wire, guard dogs, and a 10-person armed response unit to guard against a wayward RAAus pilot or weekend warrior dropping in just to have a look-see, or refuel, all backed up by an ARO with an attitude*) have taken an awful lot of the enjoyment out of it. If I could have my own property and self-insure a cheaper 4-seater, then perhaps I'd reconsider, but there will shortly be one more plane advertised on the classifieds....mine... *May be a slight exaggeration
  13. With the new Basic Class 2 you probably wouldn't even need RAA as a backup. The only medical difference between the two really is RAAus is essentially a self-declaration after asking yourself "Are you medically fit to drive anything?" whereas the Basic Class 2 is your GP assessing you against the AustRoads Commercial licence standards, which aren't that hard to meet, realistically...And you need to pay CAsA $10 for the privilege... FWIW, my opinion is if you can't meet the Austroads standards, you should be asking yourself if you are really fit to fly at all.
  14. You're only covered by the RAAus insurance policy if you are participating in an RAAus activity. Flying VH has no relation to RAAus = no coverage. Reference is the RAAus insurance certificate.
  15. Show me where I've had a crack at your product? The FACTS are your website was advertising cannabis-related products in a post attributed to Stuart Erskine. I simply pointed out that you are asking aircraft owners to trust your company with very valuable data, data that may not be able to be reproduced if it were lost, yet you didn't secure your own website well enough that it was apparently hacked to be selling cannabis-related products under the banner of "Flight Safety Solutions" and your name. IF you can't secure your own website, or even notice when it has been compromised then in my view it doesn't bode well for securing customers data.
  16. It's not a good look, you're asking pilots to trust your company with, what is quite valuable really, digital data but you've admitted your very own website got hacked because you didn't understand how easy it would be for someone to do. And not only did it get hacked, you didn't pick up on the fact that it had been. I'm not sure which is worse, but what I am sure about is I will be ensuring my aircraft data is kept under my control.
  17. No Spanish? Then Cannabis Oil perhaps?!? Who is Stuart Erskine and why is he advertising cannibis-related products on your website? Perhaps not the best thing to be advertising under the "Flight Safety Solutions" banner? Just Sayin....
  18. The maximum flow through the return line would be at ground idle, wouldn't it? At full power, most would be consumed by the engine??
  19. I've got a 200-series and just had a long range tank fitted. 273 litres of fuel on board. Of course, I got a GVM upgrade at the same time and do you think ARB had the foresight to re-weigh the vehicle for the RTA engineer before they filled the tank? Nooooooo, of course not..... So now I'm stuck trying to drive 2000km to get the weight down enough to get it back on a weighbridge. The previous car was a NP300 Navara, also with a long range tank, and I got told off by the servo attendants several times for using the filler cap wedged under the nozzle trigger to hold it open because nowhere seems to have the hold-open clips on the low-flow diesel hoses anymore.
  20. 981.5Lbs / 445Kg BEW for my RV-9A, but that was before autopilot servos and wheelpants. 450Kg after. Still, a 150Kg payload, less 80Kg of pilot gave enough fuel for a Sydney-Brisbane flight or a 2 hour local junket with Mini-Me. I could have got a bunch more if I hadn't stuck an O-340 in it! At least on VH- now I can take 2 adults, AND fuel!
  21. You can get -7's and -9's onto the RAAus register, but then they are very niche machines, essentially, single-seat high-speed cross-country or medium-range 1+1 aircraft. I've just transferred my RV-9A from RAAus toVH to make full use of its' payload and take the KRviatrix, not just Mini-Me flying...
  22. The difference between "Landing" and "Crashing" is defined as an ability to use the plane again... One thing I have found, or rather, not found in most POH's is those nuances that you are either taught (by a good instructor) or learn yourself, about particular airplanes. Flap pitch couples, opposite or into turn rudder rolling into a bank are a couple of examples I can thing of, off the top of my head. POH's are great for performance and limitations, but handling tricks and quirks, not so much.
  23. The good thing with the RV line is it's hard to find a single point of failure, with the exception of the fuel system. I would rather build and maintain my own plane as then it's a known quantity. Sure you pay a LAME to "do this, fix that" and give you an airworthy aircraft at the end of it, but it isn't their life on the line if they've forgotten to tighten the fuel servo B-Nuts. I've flown Victor 1 several miles offshore with my 5 year old in a plane I built in my back shed, and felt completely comfortable doing so just like I've flown from Sydney to Caloundra over a layer of stratus where you couldn't see the end of it, or what was underneath it - and truthfully I feel more comfortable doing both of those than flying an aero clubs 60-year-old C150 for a BFR...
  24. The removed Planesales ad says it was still undergoing Phase 1 testing while being offered for sale...I wonder how many hours it had at the time of the incident?
  25. Except that CAsA have decreed that having only 1 TSO'd GPS (C145/6) is sufficient for sole-means IFR navigation without requiring an alternate! What would happen at night, in IMC enroute if that single GPS were to fail is the million-dollar question. I don't have a VOR in the RV, and don't see the point either. Any TSO'd GPS newer than C129 is sufficient to push the "Time to positive fix" out from 30 minutes for VFR to 2 hours, you don't need station passage or intersecting radials from a VOR. A waste of time, money and weight in a modern cockpit. The only reason I'd install one would be for an ILS, but never a standalone VOR. Anyway...Here's a bit of my handiwork from a few years ago, showing the remaining VOR's in Australia and their effective ranges. Nationwide coverage at 10,000'. Red is ASA, Blue is private. Green is DoD. Victoria 5,000'. Victoria 10,000'. NSW 5,000'. NSW 10,000'. Queensland 5,000'. Queensland 10,000'.
