Ok. I wasnt going to. But I will raise a few points I find ...Concerning.
Remember, this is a nation wide publication, and this column comes under the heading
"Flight Instructor's Forum"
Facilitated by the Aviation Guru professor Avius."
Im not exactly sure what the idea behind the column is to be honest. But in the past I have had to discuss at length with MY students why our methods differ from those professed by our Guru.
Its not helpful.
I will paraphrase the sections I have issue with.
" Major Aim- It should be stressed that an inadvertent stall should never occur. It is a big killer of pilots.
The first time you show a student a stall the goal should be to debunk any preconceived idea that the lesson is a frightening experience."
Gee, where would they get that idea from Professor? You just opened the paragraph talking about how stalling kills people.
"The most important thing they have to learn is that the point of stall is the time they should begin the recovery"
Thats the most important thing? Ok, I disagree. I wont go into the grammar.
" But why does a stall occur?
ANSWER: It is the angle formed between the chord line of an airfoil and the relative airflow"
Ok, the stall occurs because it is an angle? Huh? Professor. You asked WHY a stall occurs, not what angle of attack is.
It may seem like splitting hairs, but a subject like stalling needs to be taught Clearly, concisely, and above all, needs to make sence.
He/she goes on to describe the angle between the chord line and the relative airflow being like a top and bottom jaw. Ive heard this description before and often wondered why one would need to use this description, but
thats not the problem. The problem is this statement.
" - A stall happens when you open the jaw to angle of about 16 degrees. If you close the jaw by just a couple of degrees, no more stall.."
A couple of degrees? I thought you said it stalls at 16 deg's? Why do I need to "close the jaw" by a couple of degrees? Im confused.
" What controls this bite or angle of attack?
ANSWER: Just one thing. The elevators."
Did you mean the elevator ( Singular) as in, just ONE thing. Now we have multiple elevators on the aeroplane? Which one controls the angle of attack? You said just one of them..Which one of the two or more elevators controls it?
"Explain what happens if a wing drops at the stall and why - (use of ailerons/ autorotation). Refer to the lesson on effects of controls ."
What happens if a wing drops at the stall and why??. Did you mean, explain what to do IF a wing drops. Or, explain THAT a wing MAY drop at the stall because ....
Again, this poor use of english by an instructor trying to teach other instructors is pretty sad.
Ok, so now we get to the actual stalling lesson in the aeroplane.
"Phase 1. Recovery without power. Control column is eased forward to the horizon. As airspeed increases, ease out of the dive"
First of all. I have major issues with using the horizon AT ALL while teaching recovery from a stall. The horizon has NOTHING to do with the aeroplane stalling.
Control column is eased forward to the horizon? Are we pushing the stick towards the horizon? Ok. What if the nose is below the horizon? Do I PULL the stick to the horizon?
What dive? You just said to lower the nose to the horizon? Wheres the "dive" come into it?
" Phase 3. Effects of power and flaps. This is one of the most important aspects of of the stalling exercise.Stalling in the landing configuration. Recap the three steps to a recovery
1. Full Power
2. Nose to the horizon
3. Check yaw with opposite rudder"
Professor. You just spent half a page explaining that "nose to the horizon" was first THEN POWER was applied. What is the correct order?
Further and MUCH MUCH more importantly, power should NOT be applied first as this may cause the aeroplane to either torque, or yaw aggressively and CAUSE autorotation.
So the stall in the landing configuration, lets look at a typical stall turning final and apply the GURU's recovery procedures shall we?
The pilot gets a bit too far back on the stick during the turn onto final, the nose is DOWN below the horizon, and the aeroplane is now in a stall, banked and yawing.
Professor says step 1. Full power. This causes yaw and (remember effects of control professor) pitch UP. Now we are really starting to stall baby!!. thats ok, lets go to step 2
Step 2. Nose to the horizon. Cool, ill just PULL THE NOSE up the horizon. Thats what you said to do professor. NOSE TO THE HORIZON.
Patter like this is not only confusing, its downright DANGEROUS. Surely the RAA can edit this sort of crap before it gets displayed in public for the whole aviation community
to see. No wonder we are seen as amateurish cowboys.
