Hey Maj, I have a Rotax coolant bottle I bought with the engine and just need to make up a bracket for it... anyone provide some pictures or ideas of their set up??
The Bolly Blades appear very well made and IMHO look great in shape and form (by my untrained eye), with the lighter hub it makes a very efficient package. They are ground adjustable and go together very easily with sufficient instructions (and tech details) to assemble it no time and fit to the engine.
We used a laser light to pitch it up on the ground and make adjustments... which is what takes the real time, torque up the bolts check and loosen, adjust, torque up etc. Using max RPM on the ground we snuck up on a coarser setting than the Brolgas standard 17deg pitch. Set at about 6500 on the ground we torqued up the blade grip bolts (11n) and the hub plate bolts (13n) and took it for a run. It now pulls about 6600RPM on take off at 50kts and will drop back to about 6500 at 40kts climb out. Straight and level it winds up a little more to maybe 6700. So I still need to make it a touch coarser than where it is to get the set up I want, would like to take another 100RPM off those numbers.
You can tell the efficiency gain you get with the three blades straight away just in the noise, much pleasanter sound than the screaming banshee 4 blade. Of course the truth is in the pushing and it definitely drives off the mark with more authority. With the Brolga I used to just steadily but quickly wind on the power right through to full throttle but the Bolly getts the aircraft rolling earlier I think, so I tend to be a bit slower on the power input to diminish (or control) the slightly increased torque effect. At climb out around 50-55kts 6600 you are looking at about 800fpm+ on the VSI and can drag it into the air at 1000 with no real problem. Power on (5000RPM) stalls the prop will want to cavitate at about the same time the nose wants to drop.
In cruise it is maintaining 5700-5800 for 65kts but I want that RPM a touch lower in the 5600-5700 range... Haven't done any long range flying yet to check fuel efficiency. In the ground effect and glides it seems to wind mill a little less and with the reduced drag of three blades it seems to float on a bit longer.
They are a good buy and good price worth the change out of the Brolga even if you just had the urge I reckon. But new stuff is always good:bounce:
