Hi Bill, How does the lubricant reduce with less power? If it is getting fuel isn't it getting lubricant... pre mixed that is
If I had a brand new engine I might do the same...
Mine is old. It is leaking and I think it is coming from the check valve/s (Dripping down the black oil lines and blowing out the back). Either they have dirt or grit in them OR the valve is not closing right even though the marks line up at idle. The throttle and injection cables needed adjustment (as they were real loose and needed to take up slack) and at that time we realigned the oil injection cable and lengths as well. It leaked a 'little' before but now it seems like a 'little' more.
I want to take it off because it is leaking and perhaps reduce drag and weight a little. Primarily though I am thinking I will do this because it is less complicated, less to go wrong. I have heard the various arguments and was myself stuck on the post mix because I trusted it and it is more convenient and you can carry more oil for longer flights easier. The more I contemplate it and hear opinions each way there does appear to me less risk with the pre-mix. Case in point is my scenario here: just how much oil is getting in with the fuel and how much is leaking out? All you can go by is total consumption.
As I see it you don't really know what your oil injection is doing at any given moment, we know they add LESS oil at times. More complicated means more risk (even if unlikely).
With Pre mix it means having to carry an extra container (or more oil elsewhere) and besides what Bill says above there doesn't seem to be many other problems besides the pilot that can go wrong.
Any tips on the changeover requirements?
