Wilfred
Members-
1
Everything posted by Wilfred
If you would like to find out about the activities of the Australian Aviation Bird and Animal Hazard Working Group you can read the minutes of the latest meeting held on 4 July 2006 on the CASA website: http://www.casa.gov.au/aerodromes/bird.htm
As you say it is is emotionally and sensationally written and on reading very alarming. The sort of comments "I deal with this sort of data all the time and unless you can validate the data back to a common origin it's best consigned to the collex bin." seem to be hope that this type of data can be just ignored and it will go away. It will not go away After a look at the ATSB Stats it is concerning to find that all the dates I looked at confirmed the report and also that it is a logical and reputable source for this information. It will not go away and there really is no other answer than to recognise that there is a perceived and indeed real need for change in the way things are managed. As Dave noted it appears to many at first glance, thatsome training and licencing is questionable. Any outsider would be in awe that the trainer is also the licence tester in an area where the tested level of competance is so important. There appears to be a questionabe conflict of interest there. Also with the lack of "qualifications"required to maintain an aircraft. Rather than trying to sweep this issues under the mat and ignore them perhaps it would be a sound idea for all to band together and look to ways to reverse those undisputable accident statistics.
Provided the figures are accurate and there is nothing to indicate that they are not, perhaps this should be a wake up call as these statistics are how our organisation is veiwed safety wise by any observer. There really is no need to "relate to landings" an accident is an accident and action needs to be taken to prevent any futher problems. Just looking at it, it would logically have to come down to training and maintenance, things that a number of people have been pointing out as problems for a considerable time. There is no doubt these statistics will be used by those whose agenda they suit, but that does not change the fact that they exist and the sport can be perceived to have a serious problem that needs to be addressed.
Tower: "Aircraft on final, go around, aircraft on runway." Solo Student Pilot: "Roger" (Continues descent.) Tower: "Aircraft, GO AROUND" Student: "Roger" (Continues descent.) Tower: (Screaming) "AIRCRAFT, GO AROUND!!" Student: "Roger" (Continues descent.) So, the student pilot plunks his airplane down on the numbers, taxies up to where the twin is sitting in the middle of the runway, GOES AROUND it, and continues on to the taxiway
How the GPS works The aircraft knows where it is at all times. It knows this because it knows where it isn't. By subtracting where it is from where it isn't, or where it isn't from where it is (whichever is the greater), it obtains a difference, or deviation. The Inertial Guidance System uses deviations to generate error signal commands which instruct the aircraft to move from a position where it is to a position where it isn't, arriving at a position where it wasn't, or now is. Consequently, the position where it is, is now the position where it wasn't; thus, it follows logically that the position where it was is the position where it isn't. In the event that the position where the aircraft now is, is not the position where it wasn't, the Inertial Guidance System has acquired a variation. Variations are caused by external factors, the discussions of which are beyond the scope of this report. A variation is the difference between where the aircraft is and where the aircraft wasn't. If the variation is considered to be a factor of significant magnitude, a correction may be applied by the use of the autopilot system. However, use of this correction requires that the aircraft now knows where it was because the variation has modified some of the information which the aircraft has, so it is sure where it isn't. Nevertheless, the aircraft is sure where it isn't (within reason) and it knows where it was. It now subtracts where it should be from where it isn't, where it ought to be from where it wasn't (or vice versa) and intergrates the difference with the product of where it shouldn't be and where it was; thus obtaining the difference between its deviation and its variation, which is variable constant called "error".
I believe this is the origin of the story but is is hard to dispute the statistics Why use computer-assisted reporting methods? After attending the scene of a fatal ultralight aircraft crash and reporting on the accident, the writer became curious about the safety record of ultralights. A search of official Internet sites relating to air safety in Australia revealed there were no published statistics that could be used to directly compare accident rates of ultralights with accident rates of "normal" light aircraft. In response to inquiries with the Bureau of Transport Economics I was sent hard copies of raw statistics listing the dates of fatal ultralight accidents. The information did not mean much by itself, so from there it was a matter of going to the Internet and gathering freely available data which could be used to develop a meaningful statistical comparison. The biggest problem was that the statistics were scattered. The task was to find them, bring them together and then do the maths.
http://www.casa.gov.au/fsa/2006/aug/index.htm
If you push the stick forward, the houses get bigger. If you pull the stick back, they get smaller That is, unless you keep pulling the stick all the way back, Then they get bigger again.
Jetpack, schmetpack. Rather than waiting around for a sci-fi fantasy like a jetpack to become available, you could be flying around now in your very own personal helicopter. Yep, Japan's Gene Corporation is currently selling the GEN H-4, an open-air helicopter built for one. With controls and a seat that resemble those of a bicycle, the designers claim the flying machine is easy to use and can be mastered after a mere two hours of practice. Yep, after just two hours of learning to fly you can be tooling around at up to 3,280 feet high at speeds of up to 60 MPH. Yikes. Well, while the risk of smashing yourself into the side of a skyscraper is just as high, at least your chances of exploding are less than if you use a jetpack. You can risk life and limb now with the GEN H-4 for the low, low price of $30,000.
Flight Sim X - World's Best Pre-Order Offer Advert only (not a testimonial) Take Advantage Of The World's Best Flight Simulator X Pre-Order Offer Dear We're pleased to let you know that you can now preorder the upcoming Microsoft Flight Simulator X from PC Aviator and enjoy $105 of genuine added value FREE. We're giving away FREE Computer Pilot subscriptions, FREE UltimateDefrag software, future savings, and more! You are getting $175 value for just $69.95 with shipping from only $1.95. Flight Simulator X is expected to begin shipping in early October. The link for this offer is at: http://special.pcaviator.com/fsxpreorder.htm Don't miss out on the world's (as we promised) best preorder deal for Flight Simulator X from the company who's been doing this "flight sim" business for 16 years. We appreciate your business over the years and with this release of Flight Simulator we're showing it by giving you back so much for your ongoing support. And we want to continue to maintain your loyalty. NO hidden catches. NO fine print. NO needing to CLAIM your added bonuses. They're all automatically given to you at the time your order is fulfilled. Also important to note is that you are NOT charged until the day we ship your order. This offer will end on the day of release so follow the link now for more information and to take advantage of it. This offer is for online orders only. The link for this offer is at: http://special.pcaviator.com/fsxpreorder.htm Again just $69.95 (the price of FSX) gives you FSX and $174.95 of genuine value! Take advantage of this offer today and tell all your flight sim friends about it! Regards The PC Aviator Crew PC Aviator - The Flight Simulation Company! www.pcaviator.com
New spy plane likes the water Today's stealth planes may not show up on radar, but on a clear day you can still pretty much just look up in the sky and see them. Oops. Lockheed solves that problem with the Cormorant, a concept plane that won't show up in the sky because it's 150 feet underwater, at least for a large part of its mission. The Cormorant is designed to deploy from the missile tubes of Ohio-class submarines, which haven't really needed missiles since the Cold War ended. The idea is that the sub gets as close to the target as possible then releases the Cormorant, which floats to the surface, fires its rocket boosters and heads off on its mission. After it's done with whatever top-secret thing that needed doing, the Cormorant follows rendezvous coordinates from the sub and comes in for a splash landing, where a robotic underwater vehicle retrieves it. Then they all sneak off to the next mission.
Its a private strip on the southern end of fabulous Moreton Island it is a bit soft & short and only used by those things with the lawnmower engines
August 22, 2006 Shockwave Announces Aircraft Powerpack The Highest Rated Microsoft Add-Ons Ever Created Now Available In One Box Shockwave Productions and Wild Hare Entertainment celebrate their newly formed partnership by making two of Shockwave Productions critically acclaimed flight sim add-ons available in one box. Aircraft PowerPack for Microsoft Flight Simulator X®, Microsoft Flight Simulator 9® and Microsoft Combat Flight Simulator 3®, will be available October with a suggested retail price of $29.99. The Aircraft PowerPack add-on includes: Wings of Power: Heavy Bombers and Jets originally released for Microsoft Flight Simulator 2004®, is now compatible with the highly anticipated Microsoft Flight Simulator X®. Wings of Power: Heavy Bombers and Jets for Microsoft Flight Simulator X® raises the bar by adding eight meticulously created aircraft, visuals, and missions to Microsoft's latest and greatest flight simulator. Features: Gorgeously constructed aircraft, inside and out, down to the last rivet Fully clickable cockpits with authentic working gauges 3D cockpits so real, they look just like their 2D rendered counterparts The latest wind-tunnel technology helps to create for the most authentic, fluid flying qualities, including complex spins and stalls Enhanced lighting visual effects Fly the famous heavy bombers of WWII and the ingenious German jet technology that opposed them Featured Aircraft B17F and B17G "Flying Fortress" B29A "Super Fortress" B24D and B24J "Liberator" PB4Y-2 "Privateer" Lancaster BIII and "Grand Slam" Ar234 "Blitz Bomber" Ta183 "Huckebein" He162 "Salamander" Also Included in Aircraft PowerPack FirePower for Microsoft Combat Flight Simulator 3®, immerses the player in realistic air combat like never before in over 50 missions. Experience revolutionary, explosive, special effects. Witness towering explosive blasts, aircraft being torn in half, and smoke drifting thousands of feet above the battlefields. Shrapnel will fly, tanks will blow, and guns will shred their targets to pieces. The airplanes, their flight models and the weapon effects were built with the input from over thirty real Warbird pilots, authentic military test data and real world combat footage. Under the hood, you will find every aircraft, building, and vehicle reacting precisely as they did when you unleash all of the newly designed weapons. Specific targets will require specific weapons, just like the real thing. FirePower is so real you may find all you ever do is attack anything that has the misfortune of crossing your sights. As an added exclusive bonus the Aircraft PowerPack includes the visually stunning Wings of Power P 51D “Mustang”... as a playable aircraft in the combat environment of FirePower for Microsoft Combat Flight Simulator 3®. Featured Aircraft Wings of Power” P 51D “Mustang” (Exclusive Bonus!) B17F and B17G "Flying Fortress" Lancaster BIII and "Grand Slam" B29A "Super Fortress" Do217N-2 and Do217M1u2 Me410A and Me410B Ta154A and Ta154B Ta152C and Ta152H P40N and P40F He162A "Salamander" Ar234 "Blitz Bomber" D520 Ta183 "Huckebein" Me334 “Interceptor” “Aircraft PowerPack” will be available at all major North American retail stores starting October.
Ion Aircraft: a plane built for two While flying cars are probably not going to be seen on highways near you anytime soon, personal airplanes are becoming all the rage among the heavy-walleted jet set crowd. This Ion plane is a light sport aircraft that seats two and is currently under development for the purposes of "training, sightseeing, cross-country cruising, making your neighbors weep with jealousy, and generally having fun." Sounds about right. While they haven't gotten it off the ground yet due to issues with the canopy, it flies just great in computer simulations. That might not be enough to convince you to plunk down a deposit on one, but apparently folks are lining up trying to throw money at the designers in order to be the first to own one of the mini flyers. The development team hopes to have all the kinks worked out and the first models in the air sometime in 2008. As for pricing, it isn't available yet but it's safe to say a personal airplane isn't going to run cheap
*** NEW RELEASES *** Piper Cheyenne Fly a nice twin turboprop aircraft in FS2004 - the Piper Cheyenne! The package contains no less than four versions of the most successful Turboprop family: Cheyenne II, I, IA and II XL. All four aircraft have been rebuilt and animated for Flight Simulator 2004 in 3D fashion, right down to the smallest of details. Mechanical parts such as ailerons, rudders, flaps, engines and even windscreen wipers move just like in the original aircraft. The excellent graphics of both the 2D- and 3D-Cockpits are equipped with all the avionic instruments usually found inside these models, and the precise flight dynamics have been developed with the help of real Cheyenne pilots. Besides the accurate panels for the pilot and the co-pilot, the cabin of the Cheyenne has also been rebuilt to the highest level of detail with its opening doors for passengers and freight. The sounds which are implemented in this add-on have all been recorded aboard the real aircraft! Models: Piper PA31T1 Cheyenne I Piper PA31T1 Cheyenne IA Piper PA31T Cheyenne II Piper PA31T2 Cheyenne II XL Features: Detailed gmax model of each aircraft 12 liveries for each model Numerous animations and lighting effects Extremely realistic flight dynamics Soundest recorded from the real aircraft Completely functional virtual cockpits Three 2D cockpits for the Cheyenne I/IA, II, II XL in the following views: IFR normal view, IFR captains view and VFR view. Realistic handmade night lighting Detailed system simulation Bendix Silver Crown Plus Avionics Suite Trimble 2000 Approach Plus GPS Bendix King KFC250 Autopilot for the Cheyenne I and IA Bendix KFC300 Autopilot for the Cheyenne II and IIXL Duke Pressurization Controller for the Cheyenne I and IA Garrett Pressurization Controller for the Cheyenne II and IIXL Numerous liveries for all the available versions and an extensive documentation round off a superb simulation for both VFR and IFR pilots. Available Now! Price: $59.95 Compatibility: FS2004 Click Here for Full Product Information, or to Order Online Ground Environment Ground Environment brings stunning new photo-realistic ground detail to the Flight Simulator 2004 world. The creator of the critically acclaimed Flight Environment, Peter Wilding, is back again. As Flight Environment transformed the skies with awesome new clouds and sunsets, Ground Environment brings stunning new photo-realistic ground detail to the Flight Simulator 2004 world. As you’ve come to expect from Flight1, this package delivers much more for much less than you’d expect! While other replacement texture packages supply just one geographic area and or season, Ground Environment gives you the world, with the upgrade providing new textures for each of the four seasons. All for a fraction of what other packages might cost. Ground Environment has been specially design to improve not just the textures, but improves autogen brilliantly – the result, when used with a package such as Ultimate Terrain, has been described as better than many photographic scenery packages! Super Detailed Photo-Realistic Generic Textures - The terrain in Flight Simulator comes alive with all new texture sets for everything from deep river canyons, high mountain peaks, and everything in between. Global Coverage / All Regions - The program includes terrain enhancements for all areas of the globe. We don't focus on one area in FS, we cover it all! All Seasons - Texture enhancements to all seasonal textures to make your Spring, Summer, Fall, and Winter seasons more enjoyable. Perfectly Aligned Autogen - Our package incorporates autogen alignment techniques that surpass any other product. No longer will you have buildings or other autogen objects show up on roads or have misplacement in other areas of your scenery. Night Textures - Newly enhanced night textures improve lighting during night time operations.
I think it is that simple Unless you have an obscure engine and aircraft, talk to the manufacturer and use what they recommend
Why not just stick to the engine manufacturers specifications The coolant specs fpr the engines are clearly laid out in the operating manuals. Rotax are very clear with their requirements. In a 912 the rotax manual staes the recommendations http://www.rotax-aircraft-engines.com/pdf/dokus/d03377.pdf
http://redbullairrace.westernaustralia.com/
I have used the Valvoline product on beach vehicles with a noticable improvement in cooling efficiency <TABLE cellSpacing=0 cellPadding=0 width="100%"> <T> <TR> <TD width=20> </TD> <TD width=366> <DIV id=overview> Valvoline Racing Super Coolant is a cooling system corrosion inhibitor concentrate race-tested by Valvoline's Winston Cup team. It is proven to provide a 25% improvement in heat transfer over conventional glycol-based engine coolants. Available at NAPA. <UL> <LI>Provides advanced anti-corrosion protection <LI>Formulated to provide improved heat transfer <LI>Prolongs the working life of water pumps and heat exchangers <LI>Track-tested and proven by the Valvoline's NASCAR team </LI> <TABLE cellSpacing=0 cellPadding=0 width=255> <T> <TR> <TD>Part Number</TD> <TD>VV858</TD></TR> <TR> <TD>Size</TD> <TD>32 oz.</TD></TR> <TR> <TD>UPC</TD> <TD>74310-00858</TD></TR></T></TABLE></TD></TR></T></TABLE>
This is a link to Bert Flood's site with most of the Rotax manuals available for download http://www.bertfloodimports.com.au/ Click on "tech/service data" tab to show the manuals
</A> <TABLE cellSpacing=0 cellPadding=0 ="planeSpecs"><T> <T> <TR> <TH>Piper Cub Specs</TH></TR> <TR> <TD> <UL> <LI>Length: 22 ft, 2 in. <LI>Wingspan: 35 ft, 2 in. <LI>Empty weight: 670 lbs <LI>Gross weight: 1,220 lbs <LI>Max speed: 75 mph <LI>Fuel capacity: 12 gal <LI>Range: 190 mi <LI>Engine: 65-hp four-cylinder Continental A-65 </LI> </TD></TR></T></T></TABLE> turtle
<TABLE cellSpacing=0 cellPadding=3 align=center border=1> <CAPTION> New registrations from the RAA database for the year show much the same trend as your poll Summary 3: number of aircraft per manufacturer [Januaryâ€â€June 2006]</CAPTION> <T> <TR> <TH>Company or model</TH> <TH>Number registered</TH></TR> <TR> <TD>Jabiru</TD> <TD>39</TD></TR> <TR> <TD>AirBorne Australia</TD> <TD>16</TD></TR> <TR> <TD>Aerochute</TD> <TD>15</TD></TR> <TR> <TD>Tecnam </TD> <TD>12</TD></TR> <TR> <TD>Savannah</TD> <TD>10</TD></TR> <TR> <TD>Aeroprakt </TD> <TD>7</TD></TR> <TR> <TD>Sonerai/Sonex</TD> <TD>6</TD></TR> <TR> <TD>FlySynthesis</TD> <TD>6</TD></TR> <TR> <TD>Evektor</TD> <TD>4</TD></TR> <TR> <TD>Skyranger</TD> <TD>4</TD></TR> <TR> <TD>Alpi</TD> <TD>3</TD></TR> <TR> <TD>Dragonfly</TD> <TD>3</TD></TR> <TR> <TD>Flight Design</TD> <TD>3</TD></TR> <TR> <TD>Skyfox</TD> <TD>3</TD></TR> <TR> <TD>Zenith</TD> <TD>3</TD></TR> <TR> <TD>Birdman</TD> <TD>2</TD></TR> <TR> <TD>Corby</TD> <TD>2</TD></TR> <TR> <TD>Fantasy Air</TD> <TD>2</TD></TR> <TR> <TD>Foxcon</TD> <TD>2</TD></TR> <TR> <TD>Mustang</TD> <TD>2</TD></TR> <TR> <TD>Piper</TD> <TD>2</TD></TR> <TR> <TD>Pipistrel</TD> <TD>2</TD></TR> <TR> <TD>Rand</TD> <TD>2</TD></TR> <TR> <TD>Single aircraft [note 6]</TD> <TD>22</TD></TR> <TR> <TH>Total</TH> <TH>172</TH></TR></T></TABLE>
Military Tactical Vehicle Chimeraâ„¢ is an advanced tactical concept vehicle developed for special operations infiltration and exfiltration missions. Key Features of the Chimera Air-droppable from a C-17, C-130, or other platform using an integrated parachute system Ground-launchable using the largest elliptical paraglider ever constructedâ€â€100 ft wing span Ducted fan propulsion 3-Cylinder, 110 Hp, liquid-cooled engine Hybrid-electric drive 80 Peak Hp electric wheels motors Max takeoff weight: 2200 lbs Dry weight: 970 lbs Ground speed: 60 mph Air speed: 30 kts
