See and Avoid and communicate
Dear Wayland 1, Dazza 38, Windsor 68, Maj Millard, Kevin the Penniless,
Firstly, Yes Bob could have done a ‘go around’ and as a very experienced GA pilot Bob doesn’t need the benefit of any more experiences of a ‘go around’.
You don’t see a problem because you were NOT there and yes it is a very wide runway.
However runway width has nothing to do with good airmanship.
I did my basic training at Boonah and found all pilots at that field excellent communicators, and Dazza, if as you say, and you have mixed with the gliders at Boonah you will be very, very aware that those glider pilots are extremely cautious and courteous and the powered pilots reciprocate by using good, clear and concise radio communications --- one with the other and at all times all pilots are aware of exactly where each other is located --- in the air and on the ground, and this is achieved by good visual and radio communications.
Windsor 68, you didn’t think that Bob had to land on the grass, again you were NOT there to witness the event and YES Bob could have done a ‘go around’ but the point of my video and now my reluctant reply is to emphasise the importance of visual and radio communications to AVOID such situations.
Finally I note with some interest that you had “heard a fair bit of griping about the glider operations at this airfield on these forums…’ well maybe you are also familiar with the expression that ‘were there is smoke there is usual fire’???
In conclusion let me place before you the facts.
1. We are required to operate by the ‘see and avoid’ principle and to make radio communications that clearly make our intentions absolutely and unambiguously clear for all of our fellow aviators, both in the air and ON THE GROUND.
2. The glider to which I referred to in the video was towed from one side of the ACTIVE runway to the other side and at no time did anyone involved with this manoeuvre carry out either of the above requirements. How do I know?? Because I went and asked them, ‘did you see or hear the aircraft on finals and did you announce your intentions via radio that you were going to tow this glider across the active runway’ and to my horror the answer to both questions were “NO”
3. And what has incensed me to reply is the extremely off handed and dismissive replies and the apparent lack of understanding of what our responsibilities are to each other when it comes to our safety.
What Bob, I and all other responsible pilots require from all fellow users of all airfields is consideration and courtesy when using the same facilities, and one of the very basic courtesies and considerations are the same ones we all should practice before we enter an active runway is to ‘see and avoid’ and make the appropriate radio calls and to clearly articulate your intentions and to ensure our actions are not going to put others under unnecessary stress.
I trust I have now made my point – clearly and concisely.
May there always be smooth wind under you wings,
Pete-the-Pilot.
