Sam
Firstly, I recommend you check the pins for rust/corrosion pitting/metal dags etc. Since your machine is much older than mine, I suspect your pins will be rusted/pitted and not in pristine condition. If rusty, corrosion pitted etc I would remove and dress with a fine sandpaper strip (don’t worry about removing the zinc plating with the sandpaper, it will have long gone by mechanical action of the disc on the pin)…..my pins were ok because the aircraft was virtually new when I went searching for the problem, which as I said previously, occurred shortly after taking delivery. If you do need to remove the pins, deflate the tyre and apply heat to the pins with a paint stripper gun (the pins are Locktited ) before removing. I assume you have fabricated a wheel bearing nut removal tool??
Next, check the disc for flatness. You will need a perfectly flat surface. I have a piece of thick glass stored under the bench I use for such purposes. Use feeler gauges to measure twist/distortion of the disc….if they’re twisted like an old 45 vinyl record that been left out in the sun forget it…no amount of grease will help!!
Some distortion is permissible but my guess they’ll be buckled....mine were but only about 5-10 thou. By the way, I’m no engineer but I reckon Tecnam have gone overboard with the lightening cutouts and the result is a disc with very little strength to resist heat distortion….but as I say Sam, I defer to the experts out there for a second opinion.
I also have a theory that when the disc heats up due to ‘riding the brakes’ when taxiing on concrete or bitumen ( I don’t know about yours, but mine will just about reach Vr with the engine rpm set at 2000, which is what Rotax recommend to relieve load on the reduction gear box/clutch…. so you are constantly applying the brakes to slow down when taxiing downwind to the start of the runway), the disc ‘grows’, and because of the close tolerance between the disc locator holes and pins, there is a potential for the disc to seize.
So as to the lube to use…..I use STA-LUBE by CRC. Its high temperature grease specifically for lubricating the slide pins and any other moving parts subjected to high temperatures on brake systems. It contains moly disulphide, graphite and Teflon. Part No. SL 3301 available at Burson Auto Parts and Repco.
I treated mine about May and have not had a reoccurrence of the violent shudder since.
From time to time I get a slight shudder when turning with the brakes on… but only very slight. Applications in a straight line are still essentially shudder free. I know one Tecnam owner who has applied the STA-LUBE (from new) and last time we spoke he said no shuddering had occurred.
Sam, when you apply the grease make sure you work the disc back and forth on each pin to spread it evenly and then carefully wipe of any excess at the edges…you don’t want any excess grease flicking onto the disc and contaminating the pads.
I have not enquired as to the cost of a new pair of discs, but would be interested to know how much it would cost to fit the certified brakes to the non certified models.
My opinion is the Tecnam factory needs to ‘come clean’….admit the problem, issue an AD or SB and assist owners. They are letting their agents down badly… they ‘cop the flack’ when it’s not their fault. There seems to be little opportunity for feedback by customers to the factory. Tecnam need all the feedback they can get both positive and negative to continue to develop their products. A page on their website devoted to genuine owner feedback (log in by serial no.) would enhance their standing dramatically.
Hope this has helped but if unsuccessful you might have to buy new discs. I heard somewhere that the solid discs off earlier models are better but can’t confirm this….check with Bruce??
Let me know the outcome Sam.
Safe landings
24-4575
