Lyndon
Everything posted by Lyndon
  1. I've got wings to do. Be a while yet I'm sure
  2. Correct. Thus the longeron is only primed on the inside. The outside will be rubbed and primed just prior to painting. Lyndon
  3. I dip all my rivets in the same two pack primer. I'm thinking that should work ??? Lyndon
  4. I agree. Havnt drilled it yet. Having another look and running a measure over skin vs the holes. The tape is telling me I will fit. Time to have a cuppa
  5. Time to drill another rivet I think. The bottom lonererons are side specific. On these the rivets are off set except where a rib joins them. See pic one. Now on the rib a where it meets the longeron at rib a the holes are off set. There is no way in the world I can rivet the rib to the longeron see pic two. Thinking just drill another hole for an extra rivet. Thoughts. Lyndon
  6. Will do at bunnings now. My tyres arrived from the states today. Happy as. $40 bucks from USA to Adelaide. Have to be happy with that.
  7. I will see if I can get them locally. Lyndon
  8. No never heard of it. But I'm pretty sure of what it will look like. Will get onto it . Thanks Lyndon
  9. Will do. The fuse is just miss behaving as all the rivets don't line up. Especially the A and B rib. I want it cleacoed before rivets. Lyndon
  10. Ta. The fuse is a bit of work. Alignment of rivets seems to be a job and a half. In a day or two hopefully it will be done. Lyndon
  11. Front lower hatch fixing support question. What am I missing. How does this work. Is it bent over to catch the lip. A rod installed to make a hinge. Nothing in my manual except rivet it the hatch ??? Lyndon
  12. Nope it's almost done 2000.
  13. Thoughts on a 100 hp Rotax out of hours at a flying school. Soft start 2009 all serviced by a lame. Or is second hand to be avoided. Lyndon
  14. Bloody manual. Parts list for the rear fuselage. All primed and ready to go. Then during assembly all these other parts are required. If I went by the manual you button up the skins then you can't fit these angulars. Luckily I haven't riveted it all up. But I now need to set up and prime again. No economy of scale. Lyndon
  15. Thanks will have a look at that Lyndon
  16. Great I shall get riveting. Any tips on the trim wiring through the fuse ?? Lyndon
  17. So what your saying is I can go ahead and rivet up the fuselage skins and leave the elevator cables for a later date when I fit the tail. ?? Thanks Lyndon
  18. Now jumping a step. If I close up the fuse. Including the cargo area wiring for the trim and I have the rudder cables. I will be able to fit the elevator cables ok afterward s Lyndon
  19. No I haven't found any plate yet. I'm just sorting the wiring so it misses the cables etc. The manual shows all sorts of extra prices on the fuse which arnt in the parts list. So I will chase up the wiring the extra parts and prime them before I rivet up the fuse. If any one has a pic of their loom it would be a great help. Lyndon
  20. Incredible penny just dropped. Lyndon
  21. Don't match
  22. This is doing my head in. Minor problem the ribs a and b don't quite line up with the bottom skin. The big thing is I can't make sense of the angulars the bottoms make no sense. Holes are completely mis matched. I'm sure it's me but can't seem to work it out Lyndon
  23. Thanks. Will double check. I believe I fitted them correct but will check with the skins. Thanks Lyndon
  24. I will do all that. But the battery. What is the advantage of fitting in the rear. I'm thinking lithium ion in where the kit suggests. ???
  25. Probably not as much as I'm asking. Lyndon
