Lyndon
Everything posted by Lyndon
  1. I have no hole I'm my tank. Just one to fill it. Also if you look at the pic I don't have a delivery fitting that is complete. I have two manifolds not one. Lyndon
  2. Better pic
  3. Long range tanks. Got one. No hole in it for the delivery ???. All I have is this with and it's incomplete I'm sure. I have the manifold kit. I take both tanks feed to one manifold. I can then choose either or both tanks at one time ???
  4. Will do. Any tricks. Ps that's a while away . Lyndon
  5. It's inside as well. One of the benefits of being single
  6. Update. I finally got one one extra tank from Reg. Australia post lost it. The other is on order. Have bought the trim kit. A trim gauge. Some nice grips from Ray Allen. Big tyres. Boot for the stick. Some fuel hose that won't smell. Upgrade door latches. Boots for the firewall. Taps for the extra tanks. Upgrade on the front suspension mounts. Happy to spend a few thousand on upgrades seeing its a cheap plane. My flying has been Bush strips and it's what I like. So it won't fast but I'm hoping it will be good on rough short ground. No fancy instruments either. Well maybe a small I pad GPS. Lyndon
  7. And anywhere it fits
  8. Sure am. In the garage
  9. Unley
  10. My thread for the building of my VG in Adelaide. I will have lots of questions. Thanks Lyndon
  11. Thanks will have a look Lyndon
  12. And thanks
  13. Excellent. I shall prime one side with the wing parts. Lyndon
  14. That's what I'm thinking. There is a curve or bend in part for sure
  15. Can't find this in my manual. 9sa129 two off Thanks Lyndon
  16. I have renewed conference. I'm assembly parts for priming on the front fuselage and there are two parts with part numbers on then that aren't even close. So when it comes to assembly the baggage compartment the parts will work fine. Lyndon
  17. SF081 is the seat back. And does not have the 90 degree edge from what I can see
  18. I will . At not this stage yet. Just sorting parts. As I assemble it I'm sure it will fall into place
  19. I've got the floor.
  20. Same part
  21. Is this the back my book says sb 003-12 but ???
  22. Would an xl be wider than the VG ???
  23. Thanks
  24. Great thanks with that in mind I'm sure it make sense. I have found the floor. But can't seem to find the back wall of the compartment. I will keep looking. Lyndon
  25. Sorry Savannah VG
