danny_galaga
  1. We don't know who's right yet 😄 But in the world of starters it's unusual to have basically the same starter built for two directions. Definitely can occur, most obvious example I remember is the Bosch car starter motor. They built a version that ran the other way for air cooled VW's. Every other one spun the same way as virtually any other car starter. But we are talking hundreds of thousands, and then millions of VW's versus a few thousand 912s. With something niche, normally you work around what's readily available. We've seen that with other peripheral parts of that engine, including the fuel pump. I wish I'd thought of all this before I put my engine in, I would have tested the starter on the bench. Now the engine is in, it's a real pain to get to. Maybe the mount was designed by someone from Alfa Romeo 😄
  2. Don't forget the Rotax 912 starter sticks out of the crankcase, and the f650 nestles above the crank case, effectively changing which way it turns the sprag clutch. Does that come into it? I get dyslexic looking at gears 😄 What's disappointing, if it spins the wrong way is that the f650 starters are listed as ccw. Do we know which way the Rotax starter spins? Is there no one here with a loose Rotax 912 starter they can test?
  3. Before you pull apart the aftermarket starter, can you check to see it's spinning the same direction as the Rotax one? I would be surprised if the aftermarket one isn't pretty much exactly the same, other than the possible direction of rotation. So it should have an oil seal, since the engines these starters go on have the same set up as the 912. That is, sprag clutch in the crankcase or gearbox, running in oil. Looking forward to more news 🙂
  4. Whatever the details, people smashed their heads on the ceiling. Lesson? Stay buckled up, no matter what the sign says.
  5. Yes, one guy observed that no one who was buckled in was injured. Not surprising. Like you say, every single passenger from that flight is going to remain buckled in during flights from now on...
  6. Deceased possibly due to heart attack. 6 or 7 severely injured. I ALWAYS have my seatbelt on when seated. Even loosened off a bit for comfort it's going to prevent you from smashing your head. I'm sure pretty much everyone here would too. https://amp.9news.com.au/article/7e6480ac-852c-4ca4-ae03-c58cd0cbeb25
  7. But back to the original question, yes Holden was definitely better than Ford 😎
  8. You missed skippys point. I almost did too. If you have exactly the same engine in two very different aircraft (say a Zenith 701 and a Sling, both with Rotax 912uls), then if one aircraft is just much more streamlined it will go faster for the same fuel consumption per hour. Then if it's going faster for the same fuel consumption, you are flying for a shorter period, so total consumption is lower for the faster plane.
  9. What was the question again? 😄
  10. I actually think he deliberately slowed down for the shit. A friend of mine regularly posts 4k footage from his racing drone, and I think that goes over 200km/h. Not saying this particular drone is capable of those speeds, but if you wanted more close footage you could use a faster drone for the takeoff sequence, and something else for other footage. You'd need to, racing drones don't run for all that long 😄
  11. I guess you didn't. A Sim would have all shadows in the right place though, they use realistic physics. If your PC isn't the latest and greatest, shadows is one of the first things to turn off.
  12. Yes and No. The journalist reported the correct thing, right? And then an interviewee voiced an opinion which is incorrect. Perhaps the only thing might have been to reiterate that the journalists statement was correct not the bystanders.
  13. What on earth are you guys smoking? It's not a flight sim 😆 Just some very nice footage, using drones
  14. Your ebay listing says CCW. If you are careful you can put some jumper leads on it and see which way it spins. Be careful though as it will jump when it spins. Unless you carefully mount the lugs in a vice. But don't clamp the carcass (body) in a vice since I think it is permanent magnet, you don't want to crack them. Does your old starter work at all? You can do the same with that and see if they both spin in the same direction.
  15. Maybe think of what things people might need in a pinch. Tyre patch kits, cable ties etc? But definitely snacks and drinks! And a toilet. If oil filters, then oil too.
  16. I have imagine this is not their first rodeo, and anything that has crossed your mind, will have crossed theirs too...
  17. Apparently snap vents are getting hard to get. This supplier does them https://www.plastics4performance.com/snap-vents-pop-it-vents?fbclid=IwZXh0bgNhZW0CMTEAAR0VNwzHvoAdOi7g5c3l2edpvi7nveAE7Knh_t3GNufXDM98cgnv8KoLPk0_aem_AfrUOBPFubMkDXaOb15b16WnLb0a7RWPMCarHliNi651_a-SUE-6qnePpD6paCLSYXJQR9g5JotV1BnOpXId1Hck
  18. Yes, although I think they actually only make parts for their own aircraft. That's what they say they'll continue to do. I might have to snap up an undercarriage, just in case...
  19. I can't remember if I ever noticed there were two power ratings! Going by that illustration, I have the 0.9kw version. Keep us informed!
  20. Yep. And the other Bushcat builders were saying just do the clamps up tighter 😄 I used 03-0010 and 03-0007 universal and 2 X 02-0951 Datsun 120y. Connectors came with the kit (25mm!)
  21. Oh, what I'm saying is our local lad is NOT convenient! So now I see some prices, Gates is cheaper and probably more convenient! I already use Gates rubber on the radiator hoses. That was an issue with the kit (they supply 27mm!). Although I got the different bends etc from various suppliers. Again, if I can avoid calling someone on the phone, the guy with the shopping cart on their website gets the sale.
