danny_galaga
  1. I picked something deliberately lairy to make a point 😁 There are plenty of regular cars with mechanical superchargers nicely confined in the engine bay. Look at the Mercedes Kompressor range.
  2. Youve not looked too closely at a hot rod then. V seems nearly ideal for supercharging
  3. I must missed something. I prefer the Singa bird when I can 😀
  4. Seems to me if I just go with the Castrol gear previously mentioned, which available from Repco I should be golden. It also means if I'm travelling and find i need more I can get it from many car parts stores. Heh. If my plane ever gets to the point I can fly it anywhere...
  5. V8s supercharge quite nicely 🙂
  6. Repco are showing the concentrate. Forgot to pop in today but will tomorrow
  7. Yes, my link is for concentrate. Demineralised water is cheap enough too
  8. Cool. So just this stuff https://www.repco.com.au/oils-fluids/engine-oils-fluids/coolant/castrol-radicool-coolant-concentrate-1l-3424673/p/A9458861?rgfeed=true&cid=google-shopping&utm_source=google&utm_medium=cpc&region_id=100352&gclid=Cj0KCQjw0bunBhD9ARIsAAZl0E2rb3iqhcG67iPznsxs4IP52dclHIZeSPIwGuGa4TuL_9suGD7CGAwaAu1oEALw_wcB
  9. Engine is 912 uls. I think 2017.
  10. Tuned pipes too 😊
  11. From Rotax point of view it's fine- went together easily enough in the factory, what do they care if it's hard for someone else to remove 😄
  12. Rotax 912 90° carby tube for choke cable. To get two of those genuine, about $150 Inc freight. Or go to Ali express 🙂 https://m.aliexpress.com/item/1005004164377398.html?spm=a2g0n.order_detail.order_detail_item.3.604cf19cHB72xq I'm always mindful of cheap n cheerful. If it's something complicated and bespoke, I'll go genuine. But Rotax don't make the carbies, or the parts hanging off them. So why pay the Ro-tax?
  13. I have to remain optimistic that my plane will be flying this year, and with it I'll do my navs. With that in mind what are some easy to handle fly ins etc around the place? Flying from Boonah, so SE QLD and Northern NSW I think would be a good start.
  14. I like that head and cylinder is cast in one piece. Potentially less to go wrong.
  15. I have an aviasport tacho and I notice that the gauge face is paper and is slightly lifting. There's a chance it might stop the needle. How is yours? Flush?
  16. This is ground up work, not a clone. Looks interesting 😎 Doesn't look like it will be cheaper than a 912, but interesting direct drive alternative for the home builders https://www.kitplanes.com/110-horsepower-taiwan-surprise/
  17. So no one is interested in the actual story?
  18. A reminder about being aware of what your loose items could do https://www.google.com/amp/s/verticalmag.com/news/dropped-ipad-implicated-in-fatal-chinook-helicopter-crash/%3famp
  19. Was that not a rule back then? In any case, from that article it seems he wouldn't always stick to the rules...
  20. https://www.flightsafetyaustralia.com/2023/07/impact-at-polo-flat/
  21. Very interesting about how the cut should start. Makes sense. Learn something new every day. And then I mostly forget it 😄 https://www.kitplanes.com/vans-updates-builders-on-laser-cut-parts/
  22. Yeah, if you ve been at Caboolture, that visibility around the junction is not great with the trees in the way. Looks like the Pawnee is the glider tug after all. So both pilots very experienced. Makes me worry about what chance I have around busy places with my lack of experience.
  23. Couple killed in Caboolture Airfield plane crash identified as David and Jan Maddern - ABC News https://www.abc.net.au/news/2023-07-28/aircraft-crash-caboolture-paramedics-respond-significant/102660186
  24. There's at least one VH plane involved, so they are going to investigate it
  25. Pawnee apparently not the glider clubs https://amp.theguardian.com/australia-news/2023/jul/28/two-light-planes-crash-mid-air-collision-caboolture-airfield-queensland
