The question really is that - Is shutting off both mags at the same time on finals (with ROM around 1800) cause any damage to the magnetos? The reason for asking is that after doing a full stop landing and parking the aircraft, a few minutes later when wanting to go up again after a break, the right magneto seemed to be giving some problems. After starting the engine with both switches / magnetos on in the Jab LSA, I taxied to the holding area to perform the pre-take off checks. While doing a pre-take off check at 1800 RPM, on shutting "off" the left switch / magneto, the engine shut down completely, although the right magneto was switched to "on" position.
This sort of a thing has never happened before. On doing the checks a second time to make sure that I had done the checks correctly, the engine shut down again on switching "off" the left switch / magneto in the Jab LSA. I then restarted the engine leaving both magnetos on as usual and taxied back to the parking area. I told my instructor, who also maintains the aircraft himself about the problem. When he performed the checks, the mags seemed to be ok and the engine did not shut down. However as a precautionary measure he changed the right magneto on the aircraft as it had behaved inappropriately.
As Dick Gower rightly pointed out - "If the mags are off and the prop windmilling there is a risk of plug fouling from all of the fuel that is still passing through the engine without being ignited." [Thanks Dick for your contribution. I see that you don't post often but when you do, it makes a lot of sense!]
In that case I am wondering if the magnetos were actually ok but it was plug fouling of the spark plugs supplied by the right magneto which actually led to the problems. And once I taxied back to the starting point, the plug fouling might have cleared up, as any excess fuel might have got burnt up, hence the problem was never repeated!
