Thruster88
  1. Not a good day for white shorts
  2. Metres for altitude, yes of course, we wouldn't want the Chinese or Russians to feel left out.
  3. I always like total control and help that don't get tired with wing removal. At work we have a platform with two screw Jack's for Cessnas or a height adjustable hospital bed for low wings. Even light wings get heavy very quickly.
  4. I have always wondered about this. We know with Lycons above 7500 feet we usually have the throttle wide open (FT) as the chart I posted above shows. The Rotax 912ULS performance chart at altitude shows the 100hp engine only making about 38 hp at 7500 feet when it should be capable of approximately 75hp at that altitude. What is going on in that carburetor??? Is the chart wrong?
  5. A fast plane with 2000 fpm climb rate gets up out of the hot air quickly, love the RV.
  6. Skippy, your thinking is wrong, the propeller control only adjusts engine rpm, not manifold pressure. The throttle only adjusts manifold pressure, not rpm in a constant speed propeller system. There are exceptions to this outside normal climb, cruise, descent power, throttle will reduce rpm during landing etc. It would be nice if Rotax published a comprehensive chart like the one above for the 912, showing 75%, 65%, 55% power and how that can be achieved for a given altitude if a constant speed propeller is used.
  7. You certainly can reduce the rpm to 5200 WOT using the prop control, however this will be a much higher power setting than the fixed propeller doing 5200. The difference will be the amount of manifold pressure which is controlled with throttle. This power chart for a lycoming shows multiple combinations of manifold pressure and rpm to get the same power and hence fuel flow. 3 fuel/power settings are shown in the chart. All piston engines behave the same way.
  8. Thrusters have a 4inch main tube, no doublers but it is well braced .
  9. I agree you can get 14 lph but don't call it 75% power. The rotax charts that Blue posted show the fuel consumption at 75% which rotax say is only 68hp, weird maths if you ask me but anyway that is 18.5lph. The altitude chart is very informative.
  10. Skippy you need to use a calculator. 75% of the 100% fuel flow will be 0.75x27 lph = 20.25. L 5000rpm will only be 75% power if the propeller loads the engine to 75% and this will only be correct for one altitude. 5000rpm at 2500 feet is much more power than 5000rpm at 7500 feet. Performance charts for any aircraft will only be correct if the factory propeller is fitted. If the propeller is ground adjustable all bets are off.
  11. Mike, I believe the aircraft above was bought by a guy in central West NSW. Was an un flown prototype?
  12. You could drill a hole into which the plastic over flow tube would fit tightly. Can cut the tube at an angle so it can be pulled through then cut off. Some slack in the tube will allow the cap to be removed.
  13. Cross out "are trying to produce" and replace it with HAVE PRODUCED. Impediments to this, Lawyers, vested interests, useless government.
  14. Interesting to see the exhaust early in the vid. Looked stock Rotax, no dual expansion chambers. The exhaust was wrapped maybe to minimise cooling drag and maximise exhaust thrust, every bit helps. The 582 tuned up could produce 100hp given it's displacement.
  15. Would be nice if we could have something like this. Never happen in Australia. LA Special Flight Rules WWW.AOPA.ORG Want to fly over one of the world’s busiest airports without talking to ATC?
  16. This happened on the apron at cowra on a low wind day a few years ago. Pilots left the aircraft for a short time. Empty weight about 430kg for the piper colt.
  17. I guess the real question is if everything went to plan and the two aircraft missed by 100 feet would this be acceptable. No is the answer.
  18. Will you use ripper, the Gallion stallion in your gold prospecting after building the runway? I believe metal detection people use them to strip off the surface layer.
  19. Interesting they had left and right handed heads. Most aero engines have only one type of cylinder.
  20. Bolly test their propellers with a V8 engine and spin them to well in excess of there design speed. I like by 2 blade bolly on the 582 rotax.
  21. JR rudys point 2 about ATC not providing the helicopter with traffic information is just plain wrong. Listen to the tape. Paraphrasing "Traffic is a rj700 at the bridge for runway 33" at the time of this transmission the helicopter was about same distance from the pinch point as the jet, both aircraft similar speed, what to do what to do, slow down maybe so the jet passes ahead?
  22. We now know the helicopter was flying the 200ft or below route along the river. Looking at the chart, the passenger jet has to cross the helicopter route while descending, about 3/4 mile from the threshold of 33. 3/4 mile would put the jet at about 200ft yes? An accident waiting to happen.
  23. Looking at the replay on fr24, runway 01 mostly and 33 occasionally were in use, this would have been on the Airport Terminal Information Service. The helicopter pilots having sighted the jet may have believed it was on approach to 01 thus placing it further away than it actually was on the 33 approach. Distance can be hard to judge at night.
  24. Is the security check a one off for a part 61 license holder or is there an on going requirement to hold either an asic or avid?
