Kyle Communications
Moderators
  1. I will be in Rocky that weekend. Trouble is that its for a wedding not aircraft 😞
  2. Filling done...now lots of sanding and then glass over the outside joins and inside joins then fine filler...Cant wait until I finish this part of the build
  3. hahah Marty surely you jest...Mabel was supposed to be a 12 month project..its now 5 years !!!!!!!!!!! and still not finished 😞
  4. Managed to get the new cowl cod piece out of the mold this morning. Fitted the lower cowl and sorted my exhaust outlet at the side then taped it in the correct spot lining it up how I set it. Marked and cut the join overlap of about 20mm and preped the lower cowl and cod piece. Screwed it all together to make sure its all aligned properly. Glued both parts together with carbatec and resin and fitted all the screws. Now just have to wait and I will remove all the screws and fill the holes glass the inside joins and the outside then fill around the joins and start sanding again. Finally have some progress again
  5. So many things going on around here its difficult to get back onto projects. Danny came over tonight to help me to get the new bottom section of the cowl for Mabel done. I waxed it and did the release agent this week. So if its sunny it will be out in the sun tomorrow and the peel ply will come off Sunday and hopefully I can get it out of the mold. Maybe next week I can have it grafted onto the lower cowl. Then its cut and reweld 2 of the engine pipes and I can then get the engine started and the rest done so Mabel can go to the hangar finally. Got a chance today to work on the CNC to get the press tool made for the throttle rod bar. Tried it in the press tonight and 5 ton seems to be the right pressure to press the stainless tube perfectly round at the right size
  6. If you want a RANS S-21 kit well pay the deposit and the current wait time until shipping is 16 months
  7. I built a kit ICP Savannah XG XL back in 2010. I bought a wreck of a Savannah S model which turned out to be a far bigger project than expected and I have made and built more than 90% of this aircraft. It is almost completed I have a RANS S-21 Outbound kit sitting here ready to go when I finsih the Savannah S rebuild The S-21 powered with a Rotax can suit the 760kg Group G but any other heavier engine or higher horsepower engine other than a Rotax it will not fit as it has a higher MTOW. Rotax powered is 727kg and Titan or other style of engine is 820kg so it doesnt fit Group G https://www.recreationalflying.com/topic/9712-another-new-savannah-xl-on-its-way/#comments https://www.recreationalflying.com/topic/28429-my-savannah-s-model-rebuild-blog/#comments https://www.recreationalflying.com/topic/35636-my-rans-s21-outbuound-build/#comment-479308
  8. No they have not been doing any development at all the design is the same. The prop JG tested I gave to him it was a 175cm prop but he did not test it how he should have...yes you can test the props all different ones to a type but that is not how these are to be used. JG is testing the prop wrong. His tests are based on how you test a constant speed prop not a ground adjustable fixed pitch. The Eprop has been designed to take advantage of the Rotax engine properties and is modern design with modern materials not something the Wright Brothers used. You set the prop up as per the manufacturers specs not what you think if you want max performance. The drone article posted by Blueadventures basically says it all
  9. Is Flylite the Ninja manufacturer?
  10. Also make sure no more that 0.3 deg between any blades lower is better of course Just be aware to that dont jam the trottle on fast the prop tips can cavitate a little...just push it on firmly..also be aware that on landing you will not slow as fast as there isnt a huge paddle like before. Some do slightly adjust their landing approach but its no drama just a little different. I am keen to see your numbers at your std cruise rpm with it. Most get 5 kts increase some more just depends on the type of aircraft
  11. What is the size. 175?
  12. Mike..tie the aircraft down and set your pitch for 5500 wide open throttle on the ground. This is a good starting point. The ultimate aim is to get 5500rpm WOT in the air straight and level. Setting it like that on the ground will get you fairly close
  13. Thuraya is not positioned well for a lot of parts here in OZ..Iridium is ok but be prepared for no comms if you are in a valley or gullies....Inmarsat is the pick of the bunch. it is geostationary like Thuraya but much better position for australia and the look angle is far higher. It all goes back to cost and some usability. I personally like the Inmarsat for portable ops and the plans now at least are sort of reasonable you dont have to maintain a yearly subscription you can just do a month etc I have been into sat comms since Aussat more than 30 years ago then Optus Mobilesat then of course the rest of these ones now. As a side point I just setup Starlink at my farm last night...it is super impressive and fast and literally 2 mins to setup...incredible stuff now
  14. I was quoted over a year ago around $5500 for RANS S-21 TD with little experience and 90k hull insurance My sav was $1900 for 60k hull insurance
  15. Yes He is very happy with it..even though he has not set it up as he should have. I have urged him to set it up as per factory instructions and he said he will when he gets some time. He has set the prop at 5800 WOT..this is not the way to set the prop. You set it up to 5500 WOT. The reason is that it is NOT a CSU it is a fixed pitch ground adjustable so its performance curve is very different to a IFA. For the same cruise RPM he should be 5 to 8 kts faster "Hi Mark The Eprop is performing really well on my Highlander, I’m very happy with my decision. I’ve set the pitch fine to give max hp on takeoff and climb. Takeoff roll is noticeably shorter and climb is better by 200fpm better than my old warp drive, cruise is similar seeing 85kts at 5300. The best thing is the 5kg weight saving and smooth running it gives. Rotax gearbox should last forever."
  16. I just received the nose dragger bits for my S-21...originally ordered as a TD but insurance is very high especially as I have no TD time. So will build and fly it as a nose dragger but only takes less than an hour to convert to a TD..best of both worlds 🙂
  17. No.... RAA aircraft are allowed
  18. I like the Tailbeacon X if you can swindle the 50% subsidy that would be great. Brings it back to $2500 I have a SE 2 I was going to use in Mabel but thinking of applying for a Tailbeacon but using it in the RANS when I get it done. You can only claim for a aircraft that is registered. I have a rego number for Mabel but it wont be my end game. The S-21 will be the one I keep but cant get a subsidy for it yet. Even getting one for Mabel will be a bit dodgy as she isnt flying yet but now far off Mark
  19. Just got a email about the subsidy says it opens in 75 days Details below follow the check eligabity link https://www.uavionix.com.au/?mc_cid=94320d6cfc&mc_eid=9b6b4b3753
  20. Pulled the mold off this afternoon. It took a few hours but eventually I got it free after destrying the frame it was built on. Seems reasonable so need to clean up the main part of the lower cowl then look at where the graft will sit and make the new cod piece
  21. Danny Leach came over this morning to give me a hand to make the mold for the lower cowl piece. I have coated the section in wax and sprayed a coat of release agent over the section then a thick coat of brushed white gelcoat. Today there are 3 layers of chopmat over the gelcoat then sections of coremat and another layer of glass over the top. The coremat gives the mold some strength but still allows some flex if you need it. I will leave this now for 3 or 4 days then try to separate it from the cowl. That will be the interesting bit.
  22. That is what CASA are doing now...they want responses about why the 45kt limit should be lefted
  23. There are plenty in Europe with them on. The factory obviously allow them on in Europe. You just need to get the factory approval....note I said FACTORY approval NOT the local guy approval Mark
  24. Thats because CASA has in its charter to be as obstructive as possible no matter the cause
