Kyle Communications
Moderators
  1. Far better off using 48v battery bank..more efficient Use grid connect solar panels cheaper than 24v pnes amd more prolific I use 1 grid connect 200watt panel to a MPPT controller and it charges 10 batteries in all my farm equipment...I dont have flat batteries any more
  2. I read that document and yes I think they have done a great job of telling ASA what a bunch of numpties they are
  3. Later on after fitting that fuel manifold I got a right angled barb fitting and put it into the right side end of that block and fitted another tap to it and bought my fuel return to it. That way I could turn the fuel return on and off and because it went to the fuel block it did not fill up one tank it just went as usuable fuel The main wire from the battery which in mine was right down the back of the aircraft was quite heavy...maybe 4 or 5 gauge in your terminology. It was a long run so I had to make sure it was heavy enough. The positive was larger than the negative as the negative was a parallel really because it was connected to the frame at the battery. I will look to see if I have any pictures..as I sold the aircraft late last year. This new rebuild I am doing I will only have 2 taps for fuel as I have totally remade the tanking system even though I have 4 tanks but the fuel return will come back to the manifold like I did later to stop the overflow of the tank The new tank system you can see on the S rebuild blog Mark
  4. Yes get rid of all Alu cables and replace with copper...also the only earth to the frame for the battery negative ICP do at the battery and they rely on the alu fuselage to provide the path...this is just bad !!! run another earth wire from the battery negative as well as keeping the original...run the other negative to the engine...bolt on the back of the start or somewhere else..it has been proved that not having a direct earth will/can stuff the sprag clutch in the engine as the engine doesnt turn just quite as fast as it can
  5. Waraton I think you may have hit the nail on the head..never even thought of that...they are testing delivery drones in Brisbane now
  6. What does make me laugh at this is if it goes ahead then effectively you are in CTA......so just fitting a transponder is not the only thing...how many RAA pilots have CTA endorsements...does this mean that ok I get my transponder and then I have to get a CTA endorsement as well because I am now allowed in Class E airspace?????
  7. Such a simple mod too I have a EFIS so obviously i can put the level marks where I like with programming but I like to have a analogue ASI in my aircraft as a backup...and I just have the normal arcs set to my speeds but I do like that tape line right across the gauge...i will be doing that to it. Super simple idea that I am sure will save lives
  8. Nah...all is quiet on the western front at the moment
  9. The antenna issue with the SE2 of course will be some requirement to the specs they had to build/design the device to by the relevent FAA or CASA or the Brits. It says in their paperwork that no mods are allowed but we all all know that to get the most out of something it needs to be modified usually 🙂 if you keep the SE2 plugged into the USB supply it will stay powered and the battery doesnt go flat of course
  10. HF...I wouldnt be to concerned about rushing out and getting a transponder thats for sure. This Class E clusterf**k will not get up because it is even too far ridiculous for even someone like CASA to approve. Save your pennies...well at this stage
  11. Well it certainly appears so with all the reports back
  12. Totally agree No one though has reported any real extra fuel consumption but that is because their original prop has been set up the same
  13. Hi Bob It depends on how you setup your prop. A fixed pitch prop needs to be setup differently to a variable pitch prop. JG did his tests as per a variable pitch prop setup and this is why you see little difference between all the props he has tested. The Eprop is setup differently being fixed pitch...how it is setup is how I setup my original Bolly and how everyone I know basically...setup up their props. When you set it up like that you get much better perofmance than before with a different prop setup the same. So all things being equal the Eprop outperforms every prop so far...over 20 props now fitted and not one customer who has said it wasnt worth every cent in the extra perfomrance they have now. I cant say anymore than that really..the proof of the pudding is in the eating
  14. Yes thats a perfect example of what can be done now with EFB and smart software writing and devices just like the SE2 This literally makes the SE2 part of a TABS device available for reasonable cost ASA surely cant be that poorly run that they can not see these potential devices will also save them time and energy when aircraft are not withing the high traffic areas
  15. Yes I watch all of Mark Patey's videos...He is unbelievable in what he can do and achieve..then again limitless pockets almost helps you do that. Do yourself a favour Skippy and subscribe to Mike Patey's youtube channel..its worth it I have learnt a lot more about glassing and other stuff from his videos. As far as not hearing from me...some of us still actually work you know so sometimes it can be a day or two until I see whats been posted...other times I can fire back straight after you post. I do not profess to know all the maths involved all I know is what I see with my own two eyes. So yes what you think should work to your eyes and brain doesnt necessarily do so....The first time I saw the Eprop blades I couldnt believe they had the rapp that so many have given them...well so far everyone who has them now has a marked improvement in performance...so thats all I have to say on blade shapes...except for asthetics...the rest of it I leave up to much smarter people than myself
  16. You could always stick this prop on your faeta and see how it goes 😂
  17. Being simplistic Mode S is ADSB and is what CASA wanted introduce back in 2014
  18. Wasnt there a mandate from CASA that all aircraft would have to be ADSB compliant by 2020. But about 2017 i think they bailed on enforcing that to some other date to be determined because the cost of everyone would be too high. So I think ADSB will be the norm eventualy anyway it is the cost factor. I know everyone was spewing about the cost back when it was first announced back around 2014/15
  19. The other thread is where most chat is on
  20. Yeah well cheesed off with my great idea of a quick and nasty spray booth....a squall came through late last week and destroyed the frame..folding it over the existing large carport even tough it was tied to the existing carport and tied to start pickets on the other side...it broke all its ropes and tried to go flying So after moping around and swearing at the dog who was looking at me to say..."why?..it wasnt me you fool that thought of it" So I have decided to bite the bullet and put up a carport as I actually do need another. But it wont have any sides. i will use corflute sheets 2.4 x 1.2 and attach them to the outsides when I need to spray in there. Seal the edges with duct tape. There are some nice premade steel skillion sections available and I will just sit on 2.5 mtrs steel posts anchored to the concrete and the roof will butt up to the edge of the existing large carport..all will be come clearer when I get it done. Should take a weekend or or so and it will be done. Just waiting for pricing but I dont expect it to be more that 900 bucks in bits So finally got around to finishing the steel brackets atatched to the rear of the sav fuselage so I can put it in a rotisserie to paint it. I made some angle alu brackets that attach to the fin post and tailpane mounts also on the steel frame there are 2 square sections that get bolted to the 2 lower rudder hinges...its not going anywhere. Just have to make the plate that bolts onto the 4 engine mount spots on the front. It will be ready by the time the carport is done
  21. Yes as my footer message says = Airservices Australia
  22. Yes its a joke..from Brisbane the E airspace finished just east of Chinchilla and just west of Blackwater...and west of Millmerran....These guys obviously dont want anything except RPT flying
  23. To be brutally honest I really dont think any ulralight "needs" as CS prop..the cost well outweighs the advantages
  24. How is that other build going Peter...are you finished?
