johnm
Everything posted by johnm
  1. I see the light now Ian good site - just as it ever was
  2. the top cop still have some way to go
  3. OK Ian where is the: - the site layout - the menu bar - the index - the road map - the big picture - the ? - where ? thanks john m
  4. from memory they also had a US warship 'making lots of smoke' as a signal to assist Earhart ......... but they never saw that ?
  5. Yes Ian a PC screen (big puta screen) ............................ not seeing that menu bar
  6. I might be a dinosaur the thing I don't understand is where is the site layout Ian the first video In your video Ian) says there is a side bar which shows the site layout / forums Ian - can you explian in monosyllabic diction where the side bar is (aint nothing on the LHS of my screen - but a coffee cup) thanks
  7. suffering from a mild technical anomaly - after critical analysis using complimentary spanners and hammers .......... it has been decided to file the project in the big square bin out back
  8. if low flying is legally taught - it is in a defined area / zone where there are no dangerous low obstacles .............. such as wires there is certainly a curiosity about flying low when you are a low hour pilot (generally speaking) a low flying area helps pilots to start to contemplate, consider and comprehend the dangers
  9. good to see its got 2 nose wheels R750
  10. Did somebody just mutter, “correlation does not imply causation”? ............................ if you dropped a rock on your foot - the above statement holds logic
  11. johnm
    Blériot 5190
    what a beast / titanic ear muffs required no doubt
  12. thanks for all that peoples - I'll add I think for the turbo - the intercooler needs to be in there as well cooling down of intake gas and fuel ? before it goes in the engine I'm going back to that book where I mislead it or I misunderstood it (I still think ? the Luftwaffe climbed to have the height advantage for speed / gravity - to get some performance)
  13. so Loonybob / and others - are the facts about Luftwaffe and say USA aircraft performance correct ? - via my crude technical ability Did Luftwaffe craft perform not as well at the higher altitude and if that is correct what was the thing that determined that ? ta
  14. On the subject of P47’s and WW2 Reading my last book ……… the Luftwaffe did not have much access to metals such as nickel so their max boost (super or turbo ?) for the ME 109 and FW 190 was say 18000 ft where as the P47 & P51 was something like + 24000 ft The height at which the B17 flying fortress flew at - + 24000 ft A distinct advantage to the allies and their bombing campaign in Europe. A distinct disadvantage to Luftwaffe pilots who had to get up to the B17 height Not something well considered by many ? – these crude technical comments are made for discussion !
  15. ......... there an opening here for a 'vegan' / vegetarian roadhouse the truck parking could be a staged construction .................... as popularity increases
  16. also to help you search for other suppliers ..................... ? don't think its XPS - its EPS (expanded polystyrene)
  17. 4 engines - DC8 ?
  18. There seem to be 2 groups of people in this landscape: Group 1 - these people - their pulses race with words like AGM's, boards elections, board member, associations, incorporated associations, diplomatic, elections, constitution, nominees ......... etc Group 2 - this group just are not interested Group 3 - and other groups, in case this is to much of a generalisation Group 1 - love throwing rocks and will keep throwing rocks at group 2. Group 1 thinks Group 2 is at fault for not participating. Rock throwing is obviously contradictory to diplomacy. Rock throwing is the same fault that Group 1 thinks .............. Group 2 has Group 2 - usually never react - because probably there was no reaction in the first place. Rock throwing is not a provocation to Group 2. Group 2 does not think Group 1 has a fault - generally Group 2 never even considered any one had a fault at all
  19. johnm
    Blohm & Voss BV 138
    Looks like Homer Simpson had a go on the drawing board - in the design of that one
  20. the govamin will shortly be mandating a 7% wage rise for all building bound employees first, all windows will have to 'blacked' out (white is also becoming acceptable) the cost inefficiencies of clear glass distraction can be easily demonstrated (says the govamin) ...............
  21. posted this before ............ v1 & v2 speeds have been attained
  22. 250 hp might be enough ........... but the bloke at the end of the queue (you know - the one following too close & looking over your right fender and right side mirror) needs 350 hp to get past 'you' all
  23. if its real ? - be good to see how they depict the hose layout (metal and rubber; other) on the design drawing (sssssss ........)
  24. PBS TJ100 jet engine - google says $65 k to buy the engine - assuming US dollars by way of comparison a B737 engine cost $ 15,000,000 !?! ................ still hoping my investments will ...................
