facthunter
  1. Has the prosecutor decided to Proceed yet? Nev
  2. At Penfield there was always stray traffic boring through the circuit at the same height . That's bloody rude as well as being very dangerous. Nev
  3. WE were Hijacked. Nev
  4. They all look "Ripley believe it or not". Stainless also fatigues. Nev
  5. Rust often happens UNDER powder coating . Use a zinc based paint. nev
  6. Hard to weld thin SS sheet without it buckling. Nev
  7. Nitrogen is an element. Early in chemistry you learn about elements, mixtures and compounds, Acids and Bases Metals and non metals. Nev
  8. IF Cronyism bothers you go back to the early AUF Days. It was WHO you KNEW. to live the good life. Life is very finite. We don't have the time to start a NEW RAAus . Copy places that work, like NZ. .Nev
  9. One advantage of having flown ultralights is you stop complaining how difficult some cars are to get into.. Did I tell you about the LOTUS I saw (and Heard) the other day. Now THAT is Lust. Nev
  10. Douglas DC-2 .Too. Everything's tailwheel. Nev
  11. Borrow an adjustable reamer to enlarge the Hole and remove the sharp edges with the right sized ball rotary burr or a scraper. Nev
  12. Bit of money spent there. Obviously the Gear WAS down and LOCKED. Problem Just Indication?? Nev
  13. Being in the circuit or doing an approach and go is a different matter. Your aerodrome circuit is YOURS. Nev
  14. They don't work well WITH a tube either. Nev
  15. There MUST BE a correct fit. Nev
  16. Nitrogen to all intents and purposes is INERT. It only combines at extremely high temps, which is fortunate as it is 78% of the earth's atmosphere. Nev
  17. Nitrogen Power? Nev
  18. That's why you don't grab the shroud of a CO2 fire extinguisher when discharging it.. . It freezes. Nev
  19. Jet engines lack "Character".Nev
  20. You shouldn't have to do that and how is anyone else going to Know where you are? You can fly parallel and call "abeam" Nev
  21. Controls have good feel (Rods) Rudder could be bigger, Treat stalling with respect, It can Bite, Handbrake could be "different". Are you 3 pointing or wheeling it on? Solo it is different to 3 point than with 2 onboard. Stop swing early and positively Rudder works a lot better when power is on. Practice bounced well controlled go arounds. IF you're not happy go around. Get used to having a RUDDER. and USING it. Nev
  22. Do it quick and no one notices it and it has been known to rain Cats and Dogs. but when a cargo plane blew up over Japan, it rained Datsun Cogs. Nev
  23. You'd think he'd get enough of it in his DAY job? Nev
  24. What impression did you have of the aeroplane? I did my initial training on one. The best way to get rid of the cat is roll inverted and it will fall away. Don't worry about the cat . They always land on their Feet and find their way home. Nev
  25. Dunlop bult the Pump and I only experienced one (Partilal) failure and never heard of any others. It's a 4 stage pump to 3600 Psi. . Air brakes on a Plane are a bastard to use. They had antiskid called "Maxaret" Nev
