facthunter
  1. The Current USA Gov't have to accept FULL responsibility for the way they have "chosen" to treat former loyal allies and broken existing agreements, unilaterally Them's the facts of the Matter. Nev
  2. spacey...A plastic hand pump on special? Nev
  3. Welcome to SIN CITY. Maybe Gympie? Nev
  4. AVDATA are a Monopoly debt collecting show that profits from getting the Money for the Aerodrome Operator but you should be offered an alternative way to pay DIRECT, and reduce the cost to you. I suggest this situation is ILLEGAL and should be tested. Aircraft operators have Never signed a consent form with AVDATA. They don't listen to your statement that the Plane couldn't be yours. Make a STAT Declaration , Don't PAY THEM and let them charge you for Perjury. Nev
  5. For Low level aeros, you use QFE which reads zero when on the ground. AVALON has an elevation of 35 feet AMSL Nev
  6. 92 was the first year at Avalon. There would have been airshows at other Places before then. Pt Cook . I think I can recall going there and Williamstown NSW and Richmond NSW.
  7. What People will do to get noticed.. Nev
  8. Yes that's a typo. It was called Airshows Down Under at one stage. First time at AVALON, 1992 , Was nearly washed out. the Last time I went I flew my Citabria in. I Followed a "Black" Catalina that I could almost keep up with. Nev
  9. Probably would have cleared the ground on a "cooler" day An incorrectly set altimeter can cause this. ATSB are investigating. Hope the Pilot recovers OK. Nev
  10. Called "Diesel on Gas" Added more Power and probably needed a bigger radiator. Cleaner burning. Nev
  11. I would NOT advise that, though I understand the anger. Nev
  12. No you are not, but what Maintenance is associated with the airspace? In CTA you are using paid People so can be justified. Nev
  13. RV's have gone right into this. I think it mostly relates to Flutter. Roughly the True Airspeed is +20 at 10,000 Ft Nev
  14. I think ALL are welcome, but Ultralights will never be pre eminent. NATFLY doesn't have HEAVIES, nor should it. Nev
  15. I think I'd rather visit HARS. Nev
  16. Do wars only get fought on fine days? Nev
  17. There's Plenty of servos in VIC that don't have LPG anymore. Vic used to have the Most extensive coverage of any state. Nev
  18. Normally by today I would have had a lot of "Interesting planes fly over HERE on their way. Not ONE so far. Something's different. Nev
  19. In the 70's I got a free (industry) pass for the times I went there. I recall on one occasion Lots of Jabiru's flew in and one time about 4 of them bent their nosewheels as they were "asked" to do a landing involving a downwind component, Not realising they could/ should have requested a landing into wind. A bit over awed with the situation? Nev
  20. Why not? Roads get washed out. Remote places, by Rail to nearest Point. Nev t
  21. Use Electrified Rail Haulage. Unload at night. Nev
  22. There may also Be Nitrous Oxides produced with WATER. Also depends on the energy the grid is fed by. Nev
  23. Balloons don't have airspeed unless they have propulsion. Their groundspeed equals the winds speed/ Velocity Speed and direction. Your stall speed will stay the same (indicated) as you go higher but your actual speed through the Air will increase approx 2 kts/1000 feet. Nev
  24. Getting it from Fossil fuels is the worst of both. Hydrogen Leaks and embrittles Metal. Nev
