facthunter
  1. You probably haven't put them it into a situation where it matters. Nev
  2. MOGAS in this instance is a BRAND NAME just to add to the confusion. Google it, but it was mentioned. Jack Vevers. (Vev, when he posted here), worked as a fuels technologist. I'm not suggesting any connection to the Brand but I think he would pick a supplier he knows is OK.. Nev
  3. Flaperon equipped aircraft should be a separate endorsement in my opinion.. . There's enough difference to warrant it.. Nev
  4. Us has entirely different terms for these things. What are you ON about Turbs? Haven't you got something better to do? Nev
  5. Most of our fuel is from Singapore. TAPIS? Nev
  6. I'd be keeping an eye on all this stuff. Any "0" ring must not be able to slip out of it's groove. How long does that PLASTIC last? Does it get brittle.? Nev
  7. When I say "MOGAS" it's generic ie fuel sold for motor vehicles with spark ignition. IN Brazil, Cropdusters were operated on 100% ethanol. Nev
  8. IF the engine is inclined to detonate at all you try to make sure that doesn't occur as the engine will get hotter. lose power and destroy Itself. WHY do YOU have to be SO super condemnatory of anyone who thinks differently to YOU? AIR -Cooled engines at higher loads are particularly sensitive to overheating. CAUTION is justified in this matter. A lot of what you advise is NOT safe. Nev
  9. I don't really think going to a different Plane would be a great problem. It's more important to get a good instructor. (experienced, understanding and Patient). Planes are JUST planes and if you keep going you will fly more types. It gets your brain cells working and out of your "comfort zone" which might do you good. Nev
  10. There's a lot LESS lead in it (100LL) than in the early days where 130/145 was used in DC 3's and bigger. A bromine additive scours the Lead and leaves a tell tale white in the exhaust pipes. A lot of RACE Cars used it. The most sludge&Gum filled engines I ever saw were Jacobs Radials in a Grumman Ag Cat running on Mogas.. I've run chainsaws and two stroke Scotts on 100LL and they run very clean with no carbon build up and start easier. I think the Later 89 MOGAS is more for Injection motors. With Carb Motors you need more choke/priming when starting. Nev
  11. It's no fun flying in the heat for a lot of reasons unless you climb up a bit but Planes don't like climbing om hot days. Nev
  12. Yes the Ground effect can be a bit of a life saver if you stay in it. Hot air over a sealed strip can let you down too. Air density is less. Makes for HARD landings. Nev
  13. My wife used things like Lonely planet to get detailed information when we used to go to Places off the beaten track.. Asking HERE might be effective to a certain degree. That reminds Me where is Franco Arri? Anyone know? Nev
  14. We will inevitably experience these things if we do much flying. Light wing loaded stuff is more difficult to handle in these circumstances..( Hard to keep it on the ground) Spoilers save the day sometimes. Not available generally.. The main thing is to keep control and don't be shocked into doing nothing, and becoming JUST a passenger. USE all of what you have going for you.. Nev
  15. It has to be an instant response or you are in deep trouble. No 1/2 measures. Trees and large buildings etc cause mechanical turbulence, and is not as severe Generally but off-putting if you aren't ready for it. Just increase speed for that one and go around if it gets pear-shaped. Nev
  16. Wind shear near the gound is hard to predict and can have wide ranging effects . We are going to have to deal with more of this as the weather seems to be becoming more extreme more often. A gusting wind change associated with a sea breeze or cold front is common in some places. Hit the Power and loosely hold the attitude. Do NOT chase the airspeed. IF you have been lifted UP chance are you go down soon. Be ready for it. Downburst from nearby storm s used to cause Jet losses till the training changed for late approach situations. MAX power is the first action. If you are interested there's a lot of info on reaction times on engine failures at about V 1.( go or stop). where it's very critical.. Balanced field Length. Nev
  17. 10 quid was 2 weeks wages then. You couldn't just JUMP on one and ride it away. They were part dismantled and tropic inhibited. Nev
  18. You won't see a Hercules banking steeply. Transports don't have high load factors. Faster planes have to bank more steeply with the same turn radius Just like motorbikes do. Nev
  19. hardly likely to be a "roaring" success and there was no shortage of merlin engines back then. Nev
  20. Why intentionally LOAD yourself up in a critical situation.? NOT a good idea. Demonstrating something is wasting flight time. That's better done pre flight. IF it's at a pre test situation OK but not a learning one.. Nev.
  21. Lot of work to be compromised by an easy to get NOW cylinder. The MASTER rod has to be in ONE of those cylinders putting much more stress on that One cylinder. At the revs it would be capable of the OHC is not required. The porting won't be in the optimal place. The timing chain covers restrict airflow which is now from the side of where it was in the bike. Every part should be designed for the WHOLE with an aero engine. Has it got two plugs/ cyl? It's bloody hard to produce a successful radial. The Werner didn't work. and I really hoped it would. This one has much less chance. Scavenging the OIL is difficult in a radial. . Any hydraulicing and it's over. How are the lower cylinders drained of oil in the OHC part NOT easy to do. "A' for effort but it's most likely wasted.. Nev
  22. I don't like the steep turn onto final bit. and I would have let you DO your thing as that was what he was asking you to do initially. You end up not knowing what HE wants, and we all want to please our Instructor don't we? Nev.
  23. Don't rush to do your first solo either.. despite the BIG DEAL feel. It's just one step on a long ladder.. Your PPL. or Certificate is just the beginning also. This is a general comment Brendan. The day you or anyone think you've learned it all is the day you start becoming dangerous. Nev
