about time for an update, the 1000Hr inspections, overhaul and upgrades continue, fortunately, or unfortunately, we have had a great ski season, and i have spent to many weekends at the snow and not working on the aircraft.
Some time ago, i removed the lift strut attache plates due to suspected corrosion, and sure enough, after removing them, i have found some corrosion, noting to deep, but enough to warrant repair, due to the critical nature of these components to flight safety.
these are both sides of the upper and lower lift strut plates, on the right hand wing. the Upper piece, with the bevelled edge, also has a nice deep gouge across its width, im not sure how it got there, as i could not see anywhere it was resting on anything..
the material is 2024-T3 according to a rockwell hardness test and 0.110 inch thick.
new parts have been manufactured using 7075-T6 material of 0.125 inch thick, as there was nothing limiting its thickness, and 7075-T6 while more brittle is significantly stronger than 2024-T3
the lower plate was remade of 2024_T3 of 0.125 thick, but machined down to 0.110 where it nests between the plates of the lift strut itself. so at its thinest point, the total thickness is 0.015 thicker, and a mix of 70705-T6 and 2024-T3 material.
hopefully a good alodine treatment and chromate primer will keep new corrosion at bay, i think its caused by moisture trapped between the plates of the wing and lift strut joins.
