Guest skydemon Posted May 26, 2006 Share Posted May 26, 2006 G'day all, I am just having a read through the flight guides on auf.asn.au (in particular emergency procedures) and I notice there are some discrepancies between what is published and what I was taught. from http://www.auf.asn.au/comms/safety.html : <div ="quotation"> When a non-instrument rated recreational pilot realises that he/she is likely to be in difficulties (very low on fuel – lost or in failing light – low cloud and rising terrain) or that the difficulty has arrived (the engine has failed), the top priorities are to (a) fly the aircraft (b) continue flying the aircraft whilst running through the pre-planned emergency drills and © decide the best landing area. During this period an assessment must be made of the probable outcome in terms of possible injury and/or survival following the landing. * If the aircraft is normally controllable, visibility is OK and the area is clear terrain with normal rural population density and road infrastructure, then the landing will not be life threatening and, if unable to remedy the fault on the ground, the pilot won't have to walk far to find assistance. In this circumstance most ultralight pilots would not consider communicating any form of alert except, perhaps, to advise an accompanying aircraft. * If however the pilot is experiencing control difficulty, or the terrain is rough and/or heavily treed, or in a more remote area, then it is most likely that the landing cannot be carried out without risk of injury and the ultralight pilot would be well advised to initiate a distress broadcast – a MAYDAY call. In between these two extremes there are circumstances which make some form of alert or urgency communication advisable, even if the pilot doesn't want to ask for help or feels a bit embarrassed about it. (But – in my book – better red than dead). The frequency chosen, at the pilot's discretion, depends on circumstances and should be that which is most likely to provide a quick response or rapid assistance at the scene. One option is the local CTAF if other aircraft or a Unicom operator are known to be on frequency. Otherwise if the pilot is not in contact with Air Traffic Services, the norm for ultralight aviation, the first choice response station will usually be Flightwatch, on the area frequency. A third option is the international VHF distress frequency of 121.5 MHz which is continually monitored by RPT aircraft. However, I was taught to ALWAYS transmit a mayday call if in a situation such as an engine failure on the local center freq (in my case 120.0) and squawk 7700 (this is assuming I am not within gliding distance of an airfield), but going but what was quoted above it is ok to exclude a mayday call completely assuming you are confident in landing the plane without incident. It also does not mention having to squawk 7700 when in distress. Any comments? Link to comment Share on other sites More sharing options...
Admin Posted May 26, 2006 Share Posted May 26, 2006 Posted on behalf of a guest: AVIATE, NAVIGATE then COMMUNICATE. There's far better value in lining yourself up for a nice landing than worrying about who to call. In theory if you are already on the appropriate frequency for your area all you need to do is transmit when in trouble. Valuable time can be lost when trying to dial up an alternate frequency, especially if you've got one of those fiddly Microair's or similar. If time is tight, it may be quicker to set off your ELT first - you can always cancel it later if you land ok. Better to be safe than sorry. If you can, always lodge a flight plan too and activate flight following if appropriate. 7700 is probably not on the RA-Aus website because of the relatively limited number of U/L aircraft with transponders fitted. Michael, looking on the website at the Jabiru's that you've been flying, they appear to be the exception to the norm and are fairly well equipped with transponders, etc. This isn't usually the norm. Link to comment Share on other sites More sharing options...
Guest Stkin0 Posted June 20, 2006 Share Posted June 20, 2006 hi ian the gazelle that i train in and 7 others are all fited with transponders Link to comment Share on other sites More sharing options...
Admin Posted June 20, 2006 Share Posted June 20, 2006 Hi Steven Its interesting that you point out that 8 Gazelles that you know of have transponders. This is probably, as a guess, due to so many Gazelles having been VH registered at some point in their life. Link to comment Share on other sites More sharing options...
