• Please read this important announcement HERE
My Savannah S model rebuild Blog
Kyle Communications
Well-Known Member
Messages
4,433
Ratings
2,242 56
Location
Burpengary
Country
Country
#1
Hi all
I have just purchased a Savannah S model that had a unfortunate mishap earlier this year. It had been written off so I bought it to rebuild it and to make it better ( in my opinion ) and I will then use it as my own aircraft. The "Girlfriend" my XL will then be sold and I will use that to buy the next project to build. The airframe and engine has 350 TT.
I expect this to take somewhere between 12 and 18 months to do depending on the other projects I have going on. But I really miss working on a aircraft I find it challenges the mind and is such a stress reliever.
I have just done the over 2000 km round trip to pick it up and bring it home and it will be a week or so while I clean up my mess of a garage to give me the room to do all of this. I will post plenty of pictures of the progress and what I am doing. This also is for my requirement now with documentation etc for the new Tech manual rules.
The fuselage is broken in the rear and the rudder is damaged. The wings are pretty damaged but the ribs are pretty much all ok and I can get spares if any are damaged. The main wing spars look damaged at this stage but wont know the full story until I get the skins off. The engine needs the gearbox and mainshaft and crank checked but thats no drama either. The main cabin frame and centre main cockpit section all look good so far. It needs a new firewall and noseleg and a few other bits in that area but they are easily made
The plan is to make new wing skins the top skins and the front D skin will be 0.020 the underneath and flaperon skins will remain 0.016. The large flat fuselage side skins will be 0.020 but the top.bottom and curved sides will remain 0.016. The main wing spas if they are stuffed which I believe they are I will build new ones. The main web is 0.025 and I will make it 0.032. These sheet thickness mods should add enormous strength to the airframe but only add around 3kg to the total weight
Thats a hell of a lot of holes to drill you say? I will buy the sheet material all 6061T6 of course but I am drawing up the skins and the spas and I will get them lasercut locally so the sheets will all end up like what you get in the kit and also as accurate with all the holes lasered and you just need to do the riveting. At this stage I will buy from ICP probably 3 frames for the fuselage rear that look damaged and the rudder I will de-skin and either fix the frames or just fold up new ones to the correct size
I will upload some photos shortly
Mark
rotax618
Active Member
Messages
147
Ratings
80 2
#4
Great project Mark, from the outside the wing spars look to be bent where the outer spar extensions join, if that turns out to be the case the wing rebuild should be easy, unlike Danny's where someone took to the spars with a jigsaw. Will call up after Xmas and give you and Danny a hand now I have new knees.
rmorton
Active Member
Messages
230
Ratings
69 1
Location
Crozet
Country
Country
#7
Hi all
Mark
Who are you trying to kid we all know a real mans garage can't be cleaned up in any less than a life time!
Looking forward to seeing this one progress. The damage looks bad but I guess when you start to strip it back it soon becomes what can be salvaged and what needs to be replaced.
Kyle Communications
Well-Known Member
Messages
4,433
Ratings
2,242 56
Location
Burpengary
Country
Country
#8
Ouch...cowboys, eh?
Stall or pancake in, then struts folded on impact????
Hi Bob
I spoke with the owner about the crash and it seems when he took off he peeled around fairly quick to the left just after takeoff on his homestead strip and wind shear...probably a big tailwind burst arrived and the aircraft then dropped out of the air with the left tip hitting the ground the tail then hit and then the right tip hit then the nose came down and broke the prop and bent the nose leg sideways. The cowl only has a very small smack on it underneath which will take about 30 mins to fix. He also said he could not believe when he got out and looked himself over that he pretty much didnt have a scratch on himself. The complete centre cockpit looks fully intact and no damage at all and not bent in any way. He said the strength of the aircraft and how the cabin protected him was amazing.
I think it actually looks worse than it really is. I built my XL in my big garage and even full assembled it in there to set all the angles of the struts and surfaces. Over time though I have accumulated much more "crap" also the mother in law now lives in a granny flat that was built in the back yard so a lot of her stuff is stored in my garage so all of that will have to go back into her shipping container which I have to rearrange to fit all of that stuff into and I just have to bite the bullet and get rid of all the stuff you accumulate as a radio business owner...radio business guys become hoarders of spare parts..every radio guy I know is the same
So starting the throwing out process today and will get the wings off the trailer and find a place for them. I will pull the motor out and take the tailplane and fin off then I can easily handle the fuselage then. Got to build another work table for it and do the cleaning up so this is my job for the next week. I am on holidays now for 3 weeks but will be away up at my farm after xmas for a week or so. I am really looking forward to this project
Mark
rmorton
Active Member
Messages
230
Ratings
69 1
Location
Crozet
Country
Country
#9
12901284_10154125234134189_8719621588804162305_o.jpg 13528300_10154362616609189_5751909998671826485_o.jpg I really admire an optimist. I have been trying to clear my garage for 7 or 8 months now and it never seems to get any emptier. I now have a dead line as we order the kit on the 28th of this month and in theory all being well it will arrive one week later.......
rmorton
Active Member
Messages
230
Ratings
69 1
Location
Crozet
Country
Country
#14
HAHA youve more to do than me!! much more room than I have though, spent most of my time moving the same stuff from one side of the garage to the other to tile the floor, which is now almost done bar some grouting.
IBob
Well-Known Member
Messages
1,165
Ratings
658 12
Location
Wairarapa
Country
Country
#15
Hi Bob
Mark
Thanks for the explanation, Mark.
I was trying to figure out how he got both wingtips like that.
You'd have to hit awful hard to fold the struts, which would then imply main UC and central fuse damage, so doesn't fit with the UC and fuse condition in the pics.
During my time in Oz, (70s) it impressed me that any parachute malfunction had the whole drop zone trouping out to where the offending canopy fell, with a group attempt to figure out what had happened.
I never saw that in any other country.
Kyle Communications
Well-Known Member
Messages
4,433
Ratings
2,242 56
Location
Burpengary
Country
Country
#16
The U/C you see is a spare new one he put on there so he could keep it on the wheels so I got that as well. The original is bent on the right hand side. I have it here with me so that took the brunt of the third hit with the right side wing tip. The 4 wing struts are straight no sign of bending at all but need a much better look. Flaperons are bent as well but again not really a big deal. Realistically its not that badly damaged. I just got it off the trailer and put it back on that new U/C so I can wheel it around. I have had a look in the back and its what I expected. New longerons and 3 frames possibly 4 in the rear then new sheeting on the rear. I can easily fix the rudder. The fin and stab are fine although obviously I will be checking them. The complete cockpit assembly module both internal and external is pristine and no evidence of stress but once the back comes off I will be able to see more
IBob
Well-Known Member
Messages
1,165
Ratings
658 12
Location
Wairarapa
Country
Country
#17
Looks to be a really interesting project, and probably very worthwhile, given your fabrication facilities.
One area that continues to intrigue me in the design is the fuel tanks central supports:
Obviously they don't fall out due to impact or heavy landings, or we'd know all about it by now. But there seems to be not a lot holding them in!
IBob
Well-Known Member
Messages
1,165
Ratings
658 12
Location
Wairarapa
Country
Country
#19
There is a bracket on each side at the front of the tanks anchored under the wing sheeting and a flat plate about 100mm wide supporting the weight of each tank that goes across the whole tank
It is the flat plates across the centre of the tanks I was referring to: at one end they sit on top of a rib flange, which is fine, but at the other they go between flange and wing sheet, and are effectively held up by 3 rivets (or a rivet and 2 small screws, if your cover is screwed on).
