• Please read this important announcement HERE
The XPB Stage 1 underway.
bexrbetter
Well-Known Member
Messages
4,560
Ratings
6,665 176
Location
Brissy and Chengdu, China - Panda country!
Country
Country
#1
The XPB, "Extraordinary Plane Build", is termed so because I believe this will lead to a kit manufactured to a price and build speed not seen very often in the world of light aircraft.
I will repeat that this is very much work in progress to develop the build system first, the plane itself is of secondary importance at this time but of course that is the ultimate aim. At anytime I reserve the right to run into a dead end, be completely bamboozled, and completely change what you might be seeing in these early days.
Here I present the basic theme of stage 1, the frame construction method. Please note that I am actually building this now and as I feel I have proven each step's foundation to myself first, then and only then will I post the results. I would expect to have a freestanding frame complete by this weekend. "Freestanding" means the frame stays together by itself without and fasteners (rivets or bolts etc).
During stage 2 you will see my answers and methods for fastening.
I currently have everything I need in materials, extrusions, modules, braces and laterals in the factory, just taking longer than expected to set up some tooling and people.
kasper
Well-Known Member
Messages
1,700
Ratings
1,659 36
Location
Armidale
Country
Country
#4
Now I get the need for the rectangular extrusion to have the web creating the '8' shape - elegant solution to the issue of retaining structural strength where cutouts for inserts are to go.
Will be interesting to see how much jigging you will need as you move into fixing the joints to retain alignment along then length of the fuselage.
bexrbetter
Well-Known Member
Messages
4,560
Ratings
6,665 176
Location
Country
Country
#5
The cutouts are in the 'anti-buckling' sheaths only and irrelevant as the load paths are bypassed through the surrounding gussets that come later. That's on the top longeron, the floor itself is one huge gusset (with appropriate additional gusseting) in the big picture, i.e. no stress risers.
Note this is sample of layout only, not part of actual build ...
Will be jigless.
Oh you might have to give a push and a shove and check with a tape measure for square before the first couple of rivets are added, but as long as you make sure left and right sides are identical (easily done, just lay your second side on top of the first) then you have a jigless foundation.
bexrbetter
Well-Known Member
Messages
4,560
Ratings
6,665 176
Location
Country
Country
#7
Well I should have spend the time sorting out a few other things, but being an excitable chap I couldn't wait to see my concept tested ... and as you can see for yourself, it does.
There's a couple of little niggly bits I need to sort out, but the main technique is sound.
The assembly as you see it here, is completely free of fasteners and only held together by the ratchet strap at the front. It takes less than 5 minutes to assemble this lot
onetrack
Well-Known Member
Messages
948
Ratings
1,146 16
Location
Perth, W.A.
Country
Country
#8
It looks good - but being a picky kind of bloke - aren't the keyway cutouts in the extrusions substantially weakening the strength of the extrusion? - as compared to, say an all-welded design?
bexrbetter
Well-Known Member
Messages
4,560
Ratings
6,665 176
Location
Country
Country
#9
Hi onetrack,
No, and you might want to read post 5 above in it's entirety where it's not only explained, but visuals as well.
Here is a "not to scale" visual approximation of the schedule where the braces meet, there is no weakness but you are the 3rd person to mention it so if that trend continues and it becomes "lore" then I will consider deferring to a couple of backup plans that achieve the same result , but not as elegantly.
It's of interest to me to understand what people perceive though, correctly or incorrectly, it is part of the process.
onetrack
Well-Known Member
Messages
948
Ratings
1,146 16
Location
Perth, W.A.
Country
Country
#10
Ahhh .. O.K., I get the picture now. I did read post #5 in it's entirety, but I couldn't fully grasp the section shape of the extrusions in the diagrams in post #5.
The last diagram makes it very clear, and I now understand what you were explaining in the first two sentences of post #5.
eightyknots
1st Class Member: $50/year to support the site
First Class Member
Messages
3,823
Ratings
1,219 51
Location
Wairarapa
Country
Country
#11
Hi onetrack,
Nice and clear ...and elegant too. I like it!
I hope that you can adapt the same technique for the wings: I expect that the wings are likely to be constant chord, rather than tapered! There are many good constant chord wing aeroplanes so that is not a major issue at all.
Next question: is this going to be a low wing plane or a high wing?
Kyle Communications
Well-Known Member
Messages
4,433
Ratings
2,242 56
Location
Burpengary
Country
Country
#14
The system looks very do-able for almost anyone and would go together quite fast. Alignment would be quite easy too with cnc drilled support plates. What about the extra weight with all the gussets and bracing also I suppose it would depend on the actual tube thickness and associated strength. I like the look of it all so far Bex...good job
Downunder
Well-Known Member
Messages
1,915
Ratings
1,366 34
Country
Country
#15
Ultimately I guess this needs to comform to the 51% rule.
It's one thing to make it fast and easy but it must conform to rulings and kit approvals.
Something to be mindful of anyway.....
There is also a point where the cost of extensive prefabricated parts starts to eat into the cost and value of a kit.....
Not trying to put this project down. I really like innovative stuff like this!!!!
old man emu
Well-Known Member
Messages
2,295
Ratings
2,103 41
Location
Narellan Vale, New South Wales,
Country
Country
#16
I would imagine that a box of pre-cut assorted lengths of material would not constitute a great proportion of the whole airplane. Just try to tally how much of an airplane the builder actually makes - and make sure you add in all the instruments, electrics, pumps etc.
What is the actual wording of the 51% rule, anyway?
That's probably why it's a goer being made in China.
OME
bexrbetter
Well-Known Member
Messages
4,560
Ratings
6,665 176
Location
Country
Country
#17
Low wing, a bit KR2/Joeyish :)
There's a number of craft with this basic foundation, I've reviewed quite a number. Mines better(!) but that's only because others have been refining theirs for the last 100 years and gave me a head start, so credit where credit's due.
At the end of the day, it's a just a fancy truss.
The scales don't lie, at the end of the day that's all that counts.
Very misunderstood rule, doesn't help the FAA have reviewed it a few times. In simple terms you must prove you are and have performed build items that prove you understand and are capable of holding a Repairman's certificate. This does not mean that you have to physically do 51% of the build, it means you must have a clear understanding, practical hands-on experience and be capable of repairing more than 51% of the planes modules.
Example is rivets, the craft may have say 5000 rivets, you don't have to do 2501 of them, you only have to do a nominal amount, lets say 200, to prove that you have the knowledge and capability to repair any one of those 5000 and that you could have done all 5000 yourself. So lets call that 10% of the plane build you are accredited with, and so it goes throughout the plane.
This is how the various companies do the 2 week build program where all the staff help you build it, you're not building 51% of the plane, you're being trained hands-on for understanding of, and to be capable of repairing more than 51% of the crafts modules as it's being built.
old man emu
Well-Known Member
Messages
2,295
Ratings
2,103 41
Location
Country
Country
#19
In simple terms you must prove you have performed build tasks that prove:
1. You have a clear understanding of each process and practical, hands-on experience and,
2. You are capable of repairing more than 51% of the plane's modules.
This is how the various companies do the 2 week build program. You're not building 51% of the plane. You're being trained, hands-on, for understanding of, and to be capable of repairing more than 51% of the craft's modules.
Hope you don't mind the editing re-write, but I think that clarifies the spirit of the 51% rule.
OME
