Viking 130hp Honda Engine.
waraton
Active Member
Messages
100
Ratings
244 3
Location
NSW
Country
Country
#1
Has anyone had any dealings with this company. Their website says Zenith aircraft are using them. 14k usd and will replace the 3300 on a Jabiru with little modification. I love Honda products and would be interested to know about any
Australian experience .
I copied this picture from the Viking website.
waraton
Active Member
Messages
100
Ratings
244 3
Location
NSW
Country
Country
#4
Use the search function in the top right......
Plenty of info in many threads....
No Australian experiences during the last 12 months and mostly opinions otherwise. I would like to know if they are in the air and how they are performing in our conditions.....please!
Bats
Well-Known Member
Messages
179
Ratings
215 10
Location
Brisbane
Country
Country
#5
There is/was one flying in a Morgan out of Jacobs Well. I guess until we have reasonable numbers of them flying and piling on the hours, there is an element of trust involved and that's where the opinions come in.
bexrbetter
Well-Known Member
Messages
4,550
Ratings
6,652 176
Location
Brissy and Chengdu, China - Panda country!
Country
Country
#10
Waraton, you know this is a kit that gets bolted up to a USED engine?
I have no problem with that at all, thumbs up in fact, just understand it's not a new engine. They have wreckers setting aside any sub 40,000Kms for them.
The price seems a lot to me for a kit added to a $1000 engine, but on the other hand, I can't point you to anything better either of the genre.
Many were eagerly awaiting Raven's Honda kit, but there was a family sickness and I'm not sure that's done yet, you could email him. Raven has an excellent record.
Raven Rotorcraft Redrives: Geo-Suzuki Engine Conversion for Gyroplanes and Ultralights
Messages
91
Ratings
120
Location
Mount Macedon, Victoria
Country
Country
#11
I have seen a Viking fitted to a Zenith 601 in Australia. I thought it was somewhat lower power, 110 HP, but I think they have made various changes to the electronic controls so the higher power might be attainable now. The installation looked very neat and the owner was happy with it, but it was fairly new at the time. I also know a few Sonex builders in the US who are fitting them and one of them should be flying within the next couple of weeks. It's not a simple bolt-in installation. For a start the engine is considerably heavier than a Jab 3300 (about 20 kg heavier installed) and you would need to do a lot of work on the cowling and fitting radiator etc. The engines are not actually new, but salvaged low-distance engines, which is OK. The Viking web site claims that the engines have less than 5000 miles although one I know of had closer to 20,000 miles, still sort of OK. I read one account of a builder who was drip-fed the engine parts over a 2 year period, hopefully not the case now. It may be that Eggenfellner has turned a successful corner. If he is wonderful to deal with for the next 10 or 20 years he might eventually wipe the slate clean.
Bats
Well-Known Member
Messages
179
Ratings
215 10
Location
Brisbane
Country
Country
#13
or have a look at the aeromomentum, built on a suzuki crate engine
I reckon someone is going to get this right sooner than later - Viking may even have done so on a technical level for all I know, it would just take a lot to convince me to do business with them. There is a lot to admire about the new generation of small car engines and there is already some cross over in for example Honda outboards, an application that is not dissimilar to aircraft usage in that the engines are frequently run at 75% plus power for extended periods and they have an excellent reputation for reliability and longevity..
waraton
Active Member
Messages
100
Ratings
244 3
Location
NSW
Country
Country
#14
Hope so Bats, it sounds a bit like a pipe dream doesn't it, affordable, reliable and longevity. I started flying in the mid 80's, almost 40 years later lots has changed and lots not. Why can't we have it all, its 2017 for fsake. Why is it so hard? At least this thread has got a few flyers I spoke to today asking the same questions.
Litespeed
Well-Known Member
Messages
988
Ratings
1,062 26
Location
Sydney
Country
Country
#18
The Aeromomentum Engines are brand new factory built engines not a recycled one- so makes a good price point for all new.
All of them look pretty good but I think I would probably either stick to a 2nd jabiru or by a redrive and do the same as above.
As a different slant to look at would be this- use a K1200rs motor from BMW bike- 1200 cc 130hp, big flattish torque curve, mega reliable, already injected and a car style/rotax like redrive will bolt straight on.
The motor is already on its side and very compact, very easy to work on and a brick reputation.
A motor would be from $1000-$2000 for a real good one.
I know these are not common due to weight over the twin but when compared to a car motor they can make a lot of sense.
OR just do a BMW twin and be happy.
Just a thought
Litespeed
Well-Known Member
Messages
988
Ratings
1,062 26
Location
Sydney
Country
Country
#19
Here is the only K BMW motor I could find already done- should make a fast sonex. Note the strange set up used- redrive is at rear of motor and goes over the top of engine. This is not needed but his choice.
Here is comment from site
SkyoteLog: May 2016
Here is Les Kanna's gorgeous BMW K-1200 motorcycle engine powered Onex. The BMW provides 100+hp in a plane which normally flies with 80hp. The bottom cowl has been removed which gives us a peek at the engine
This is a real hot rod which flew for the first time this spring. This is way out on the end of the experimental limb of sport aviation. This is the only installation of this engine that we are aware of. It now has over 40 hours and all of the landings have been at the intended destination! So far, so good. Silky smooth! Did I mention fast?
bexrbetter
Well-Known Member
Messages
4,550
Ratings
6,652 176
Location
Country
Country
#20
Never heard of aeromomentum...engine looks pretty good
Chinese built Suzuki G13 engines. 3 major engine manufacturers here make them still, as well as others.
Millions of them here (literal figure), one of the largest produced engines in the world. Your jaw would drop if you saw the piles of them at wrecking yards.
Seem to be bulletproof, mostly fitted in taxis and in low geared mini delivery vans or mini tray tops, get the azz thrashed out of them, always overloaded and China's pretty hilly.
This is me ..
Suzuki G13 weight warning.
