red750 Posted August 20, 2022 The Tarragon was developed from the Millenium Master as was the Blackshape Prime. All-aero.com groups them together.
facthunter Posted August 20, 2022 You can't PIN them on like you can a tailwheel. With crosswind, NEVER let the upwind wing rise even with a nosewheel you can easily end up inverted. Nev 2
nomadpete Posted August 20, 2022 Thanks for the post. I have never alluded to being a great aviator, or even being particulaly good. But having watched that Oshkosh video I feel a little better about my flying. These flying applianes do not often arrive back on terra firma as gracefully as we wish them to.
Mike Gearon Posted August 20, 2022 That was a bit addictive. 😀 I kept wanting to move on and couldn’t. Watched them all. 12 hours ago, facthunter said: You can't PIN them on like you can a tailwheel. With crosswind, NEVER let the upwind wing rise even with a nosewheel you can easily end up inverted. Nev Yeah.. that upwind wing is something I can let slip. Feed it out on takeoff and feed it in on landing. Particularly into wind aileron as the aircraft slows. Landings…..I think they serve to keep us humble when our ego gets a bit ahead of the aircraft. PIN. That is a huge benefit. Pin the bastard down and work on not letting the little wheel get a chance to lead the way.
facthunter Posted August 21, 2022 You can't pole forward with a tricycle too much early or it may well wheel barrow.. With a tailwheel the prop clearance with the ground is also limiting. Hard braking with a Tailwheel at low speed is a NO No.. It will go on it's nose. Nev 1
red750 Posted August 30, 2022 Here is a video of some of the problems , especially for VFR pilots, when landing in the high volume traffic pattern at Oshkosh. Hopefully the link from Facebook works. Video: Why planes crash at Oshkosh
